03-08-2009, 06:13 PM
#1
3DMARK 2K1 low clock challenge II
Time for another 2K1 low clock challenge, this time I'm puttin up two new Tek9 slim units for the best scores  .
Listen CAREFULLY...one piece is for best single GPU score, the other is for best multi GPU score. The cpu clock limit is 4.2 jigahertz, that is 4200mhz and not a mhz over!! Any cpu is fine, any mobo is fine, any gpu is fine AS LONG as it follows the ABOVE guidelines of single GPU or multi GPU. GPU=1 CORE. Single gpu nature cap is 1200fps, and multi gpu 1400fps nature. Nature limits may change, but for now this is what we will use. Good luck. We'll go for a month or so and then see who is at the top
FINAL STANDINGS
Top 5 single and dual gpu 2K1 low clock challenge:
Single core GPU
1. 90,778 Monstru & Micutzu GTX280
2. 90,276 Hipro5 HD4870
3. 90,273 Crusty the Clown HD4890
4. 90,149 Brandybuck HD4890
5. 90,140 Hey GTX280
Dual core(s) GPU
1. 93,794 Aristidis 9800GX2
2. 93,786 gprhellas 9800GX2
3. 91,871 Achill3us GTX295
4. 91,797 Crio GTX295
5. 91,536 Poparamiro GTX295
03-08-2009, 06:20 PM
#2
So any cooling on GPU?
Great prize for such a skillful contest  Also, this may be stupid, but why does 1 unit have grooves in it and 1 unit doesn't? Just curious.
__________________
Heatware
filmbot
03-08-2009, 06:24 PM
#3
One unit is groovier  Facemill marks...
03-08-2009, 06:26 PM
#4
You won't need big cooling on high end gpu's, not sure about much older ones. You can be on ANY cooling you want.. air, phase DI, LN2..whatever. Being under the clock limit is all that matters and you need to have a screenshot + valid orb url
03-08-2009, 06:53 PM
#5
Administrator
And the nature caps.
__________________
Originally Posted by trans am
overclocking isnt dead. My cpu and motherboard are though.
03-08-2009, 07:12 PM
#6
How does Phenom II in 01'? Got a chance?
03-08-2009, 07:15 PM
#7
Xtreme X.I.P.
Ahhh... nice one again
Phenom II with 01 it same as i7, not make to much score for 2k1
__________________
Sorry For My English
OverclockZone Team
THAILAND
03-08-2009, 07:19 PM
#8
Haha, u said jigahertz. I'll swing my noob bat at it. thx bro
__________________
Under the influence of being Over the Edge!
Doomsday Rig:
TJ10ESA 1200w Zeus
Evga 790i Ultra SLI
Qx6700,6850,9650,9700 5.1ghz-5.4ghzDICE
OCZ 9-9-9-28 1.8v 2000mhz 2x1gb
Evga 9800gx2X2
BFG Ultra OC X2
150gb RaptorX6
Areca 1220 Raid 0
Xonar X2
QuadBoot xp'z-VistaUlt'z
03-08-2009, 07:47 PM
#9
I deeg. Hopefully when I get my REX back I can try. Don't have the money for LN2 at the moment so low clock testing on air sounds fun. Plus it wouldn't hurt to have a GPU unit that has brackets for newer gens (MM) and have a full KP rig
__________________
Heatware
filmbot
03-08-2009, 07:59 PM
#10
Custom User Title
So I want to use the KingPin stepup program to step up my 4.0s
He is showing both the front and the back of the units. The front has groves to allow for that first bracket for older gen cards that have really small distances between mounting. The groves allows the screws to clear the pot without causing an issue.
03-08-2009, 08:36 PM
#11
Killed by dino
Hey Vince,
Very cool, I'll play.
It may sound silly, but I want to be sure, GTX295 and 9800GX2 are single GPU or multi GPU cards for this game ?
I ask as they have two cores, but on the other hand it's one card. I know what hwbot calls it, but this is your game/rules.
03-08-2009, 09:19 PM
#12
Xtreme X.I.P.
So highest score wins? I only got a 9800GTX+ for now, but this sounds really nice
__________________
03-08-2009, 09:44 PM
#13
take me to the manbar
Whoa! this sounds amazing, i will give this my best shot for sure!
__________________
03-08-2009, 09:47 PM
#14
Xtreme X.I.P.
Sweet, I will try to join this  Was too long ago I last benchmarked the old 01.
__________________
2008 - AOCC WW #2 | MOA EU #8 | GOOC WW #1
2009 - GOOC WW #3 | MOA EU #3 | MOA WW #1 | GB TweaKing #6 | ASUS ROG OCS #2
2010 - MOA EU #1 | GOOC EU #13
03-08-2009, 09:57 PM
#15
Administrator
Originally Posted by Deanzo
Hey Vince,
Right before Vince put this thread up, he said that if anyone asked this question, they'd get disqualified immediately.
__________________
03-08-2009, 09:58 PM
#16
Administrator
But if 4 GHz PII = 4 GHz E8600, then it's good for this contest.
i7 is almost equal to Core 2 in 01 clock for clock.
__________________
03-08-2009, 10:53 PM
#17
k|ngp|n/Sham my brothers
Heh, heh, heh........I want one pot for my 295.......I'm in......
BUT why Nature limit at 1200 for single and 1400 for dual?.....I may want to put my VGA under LN2.....
........and WHEN this contest ends?.....
EDIT: Can I join with dual AND single cards so IF I win, I get both of the LN2 pots?.......
03-08-2009, 11:10 PM
#18
Killed by dino
Was that at the same time he said Mods and anyone with their names in Green have to use Vista ?
03-08-2009, 11:21 PM
#19
Xtreme X.I.P.
Hmm... never tried on same clock for i7 and C2D, so i'll try it
__________________
OverclockZone Team
THAILAND
03-08-2009, 11:56 PM
#20
Is this a set?...
__________________
Music is my LIFE!!!
03-09-2009, 12:11 AM
#21
-100c Club Member
at last support and recognition for the single GPU bencher
thanks vince
__________________
1. The first rule of Bench Club is, you do not talk about Bench Club
2. The second rule of Bench Club is, you do not talk about Bench Club
3. If someone says stop, goes limp, taps out, the the benching is over
4. No bummers in the batcave, apart from unkie dave
5. One Bench at a time
6. No air, no water
7. Benching will go on as long as they have to
8. If this is your first night at Bench Club, you have to Bench
03-09-2009, 12:27 AM
#22
Let me start with SINGLE VGA....
BUT you HAVE to say it from the VERY START, IF we can have a cap at 1200fps in Nature or not....Don't change it later on....
http://service.futuremark.com/compare?2k1=9476211
03-09-2009, 01:12 AM
#23
nice score hipro
__________________
03-09-2009, 01:58 AM
#24
a statistic
George just put a big smile on my face: at 7.50AM he finds out about this thread, one and a half hour later he posts his score with a nature 0.4FPS below the cap
__________________
Contact me at HWBOT forums
2008 - MOA EU #5
2009 - MOA Benelux #2 || GOOC Benelux/DACH #1 || GOOC EU #1 || GOOC WW #4 || Tweaking #1 (2/2) || AROS #QF
2010 - P55 OC Challenge EU #7 || MOA Benelux #1 || MOA EU #4 || GOOC EU #1
03-09-2009, 02:02 AM
#25
ODOC
exactly Pieter , i was like jeez , thats what i call keep pushing it ...
good idea Vince
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
