03-07-2009, 05:10 PM
#1
Mr. Swiftech
Swiftech MCW7000-T for Corei7 announced
I am glad to announce that Swiftech will soon be releasing a new liquid cooled thermal head for Intel Core i7.
The unit will be the most powerful consumer product made by Swiftech to this date and will be powered by a custom 62 X 62 mm Tec Modules with a Qmax of 417W at 24volts, and 28.5 A ImAX.
Here is a rendering of the device:
The housing will be made out of of Delrin, and the base plate will feature Swiftech's 0.6mm diamond Pin matrix. The product will be fully gasketed for condensation prevention (gaskets in the above pic are rendered in transparency).
Expect the device within 6 weeks. There is no pricing information at this time.
__________________
CEO Swiftech
03-07-2009, 05:28 PM
#2
CES 2010!
Subscribed for future updates. this looks awesome!
--Chris
__________________
SOGOs > BOGOs
Originally Posted by SparkyJJO
Central heat is for wusses. If you're cold, you don't have enough PCs
03-07-2009, 06:26 PM
#3
I am Xtreme
Do you give out discount vouchers for the meanwells for this thing ?
I mean...$200+ for a psu ? Due to the current rating it's got to be SE 1000-24.
03-07-2009, 07:41 PM
#4
I am Xtreme
sub sub
03-07-2009, 09:53 PM
#5
Any images on the internals of the waterblock for this. I see you guy's went with a side by side barb. Does that mean there's an internal plate for dispersion, or is it just a 90* bending channel?
03-07-2009, 09:56 PM
#6
well the money your going to spend on this and psu, rad, etc to keep the it cool and the heat out of the loop
i would just get a phase
03-07-2009, 10:16 PM
#7
I hate all the noise of phase myself, and I already have the radiator's and the PSU. I would rather run water chilled than phase anyway's. At least them i don't have to run it all of the time, and worry about it frying if I don't.
03-07-2009, 11:59 PM
#8
my phase is quiet if i only want -40c, -60c it is loud good case insulation and lots of quiet fans and there fine for 24/7 use but tec and phase are not even in the same class!
__________________
De oppresso liber
Nous Defions
Nothing follows
cpu PXA310 memmory 197.36mb
03-08-2009, 12:30 AM
#9
thats my point i dont think your not going to get any where near phase temps
and the heat its going to put out, to maybe to just get 0c
but well just have to wait and see what it can pull off, if its eben worth it
03-08-2009, 03:39 AM
#10
well it would be a really nice 24/7 setup but it is more money than a phase but it has the potential to be a really quiet system if he does a fan mod on the meanwell psu, also if one plans on cooling anything else on that water loop he will need atleast 5x 120 rad capacity if he puts some gtx 295s on there id say double that to 10x 120 rad's to keep cool and quiet but... that would be a really awsome setup!!! and it could be big time quiet think how 10x 120rad's would look with 2 gtx 295's and that water block with a i7 at 4.5ghz 24/7 and soundless
Gabe would you please post up the results of your tec when you get them up
__________________
De oppresso liber
Nous Defions
Nothing follows
03-08-2009, 03:45 AM
#11
I'm glad to see that CPU waterblock.
Thank you Swiftech.
__________________
Case: ThermalTake Tai-Chi VB5001SNA | Mobo: ASUS Striker II Formula | CPU: Intel Q9650 | Graphics: 2x285GTX | DIMM: 8GB Corsair Dominator DDR2 1066 | PSU: Enermax EGA850EWL | HDD: 2x60GB Mtron SSD 3525 - 2x300GB Velociraptors - 1x 7K2000 Hitachi 2ΤΒ - 1x WD20EADS 2TB | HDD Cooling: Coolermaster CoolDrive 6 | Scanner: HP Scanjet G4050 | Router: Linksys WRVS4400N | Color Laser Printer: Konica Minolta 2430DL | Sound: Logitech Z-5500 Bose speakers | Monitor: Samsung SyncMaster 244T
03-08-2009, 05:25 AM
#12
I am Xtreme
They said it was based on the pin matrix which they used in the 6500 so at an educated guess I would say it is the same as a 6500 internally just a little bigger to allow for the larger TEC.
This isn't water chilled it is direct die TEC cooling of the CPU and if the TEC happens to fail if you havent set shutdown in the bios you will lose your CPU as well.
The 6500 costs $160 from swiftech I can't see this unit going sub $200 with $200+ for the PSU - over $400 for only 2 parts of quite a system requirement list. Vast majority would be better off modding a window A/C to a water cooler and very much cheaper too.
If you have to go all the way to set this unit up i.e. hotside loop, CPU loop, rads etc Phase rely looks inviting especially when you consider with this unit you will probably only go sub zero when the CPU idles.
03-08-2009, 04:06 PM
#13
Anyway to control the temp of this block like the Coolit systems?
03-09-2009, 11:06 AM
#14
This Swiftech MCW7000-T sure looks like a tempting candidate to get into T.E.C. cooling. The first question that I have for Swiftech (gabe) is what power supply are you using or recommending? I noticed for the LGA775 you list the Meanwell S320-12 Power supply. Would you recommend this power supply or a more powerful one?
__________________
| ASUS P6T Deluxe | Intel Core i7 965 3838A610 | Swiftech Apogee GTZ – Swiftech MCP655-B Pump – Thermochill P120.3 Radiator - XSPC Bay Reservoir |
| Corsair Dominator GT 6GB (3 x 2GB) DDR3 2000 | EVGA GTX 260 Core 216 | Corsair 850W PSU |
| Windows 7 64-bit |
03-09-2009, 05:09 PM
#15
I am Xtreme
You obviously havent started at the beginning of the thread - Gabe quotes this thing as needing 28.5 amps and 24volts a quick glance through meanwell list and the first supply that gives 24volts and can supply 28.5 amps is the SE 1000-24. Few suppliers I can find charge $200 +
I did PM Gabe about this he has so far declined to answer.
03-11-2009, 10:55 AM
#16
I run about a month on TEC on my Core i7 965 EX.
All is created by hand, i think 417w TEC is little overkill,
because i run my Core i7 965 @ 4.1Ghz HT enabled with temps.
And i emailed some pics of myn TEC also to Swiftech self.
I also made mountings holes for lga775 in it, so i can use it on several setups.
The building of myn TEC for Core i7 is viewable here (but it is in dutch) : Chiller's TEC for Core i7 build log
idle in windows @ -10°C
Full load on 8 treads @ +28°C and this 24/7.
Here are pics from myn mounting Swiftech model 6500 with 245w TEC module in it, here without led's :
And here some pics with led's on :
__________________
i7 975 @ 4.74 Ghz air
W3540 @ 5.14Ghz SS
Gulftown Q3QP @ 4.3Ghz air 24/7
Evga Classified E759 + E762
Dominator GT 2180Mhz cl7
Corsair hx1Kw
3dmark Vantage : 33494 (NO PhysX)
3dmark Vantage : 40910 (+ PhysX)
3dmark06: 30275
3dmark05: 40342
3dmark03: 129045
Wprime32m: 3.89s
Wprime1024: 1m57s
03-11-2009, 11:04 AM
#17
I need to buy shares in Swiftech as with its new products coming out and Gabes continuous listening to all of its users feedback,
well its the company of the future for computer cooling products
__________________
_______________
Q66@3.8ghz
Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
Nano-cooled 4770,s CF 2x ST220 rads, single loop.
ST MCP 350 modded to 355 w/XSPC top.
Originally Posted by Vapor
There's a lot less voodoo in watercooling than is assumed
The only thing future proof in electronics, is the electricity itself.
Any one who relies on only one source of information is a fool.
03-11-2009, 11:07 AM
#18
verry nice job you did there chiller
03-11-2009, 11:44 AM
#19
thanks, i worked about 2 monts on it, everything by hand.
did you also cheched the build log of it?
__________________
W3540 @ 5.14Ghz SS
Corsair hx1Kw
3dmark06: 30275
3dmark05: 40342
3dmark03: 129045
Wprime32m: 3.89s
Wprime1024: 1m57s
03-11-2009, 06:11 PM
#20
I did read but was hoping that 24 volts, 28.5 amp and 417W was 'overkill'. I guess we'll find out sometime in the next 6 weeks.
__________________
| Windows 7 64-bit |
03-11-2009, 07:53 PM
#21
Mr. Swiftech
to all posts above..
24v is the max operating voltage. Let's see if we can find a sweet spot somewhere in between 12 and 24 (sourcing the right PSU comes to mind in this respect).. and if this doesn't work to our liking, then we have other tricks in our bag.
I'll keep you posted.
__________________
CEO Swiftech
03-12-2009, 06:26 AM
#22
I am Xtreme
I think going to 12v will seriously compromise the unit with a view to overclockers.
24v meanwells are only adjustable to 22v but the current draw will too high for the supply.
a 15v turned up to 16.5v might not be too bad and have the necessary current rating.
EDIT - SE 320-15 adjusts to 18v and the TEC will draw 20amps at this which is just inside the PSU rating.
Be interesting to see how you tackle this....but am a bit confused why you had a, supposedly, custom TEC made without considering powering it first ?????
03-12-2009, 05:33 PM
#23
I am Xtreme
Wow, that was sweet....really nice work
It didn't take much from your build log with it being in dutch
But it would of been interesting if I did know I'm sure....
What is that chart of figures at the beginning ?
03-12-2009, 05:45 PM
#24
Nice, I was wondering if Swiftech would ever update their TEC block. There's been a lot of buzz on TEC lately it seems, more so than usual. Hopefully there'll be a lot of new innovations in the TEC market soon!
__________________
|| Core i7 920 C1 || eVGA X58 SLI || 3x2GB Mushkin Redline ||
|| Dual HD4890s || X25-M || Creative Labs X-Fi XtremeGamer ||
|| Turbo-Cool 860w || Tagan Black Pearl || Dual-loop Water ||
03-15-2009, 09:00 PM
#25
very nice block, i like the LEDs also.
gabe, i have the older apogee GT, i lost a couple of the hold down screws that go through the mobo to the backplate, how can i order a set of these?
i didnt see a seperate list for parts on the site, any help would be appreciated.
__________________
Case: PPC's Powdercoated TJ07
Mobo: EVGA 780i SLI (FTW Edition)
Cpu: E8500
Ram: Coming Soon
Sound: Asus Xonar D2
Psu: Zalman ZM 1000 Watt
Gpu: GTX 295 W/ DD-GTX 295 WB
HDD : 2x1 250 Caviar SE 16's
HDD 2: 1 TB Samsung 32 MB cache (Movies)
Water Cooling:
Pump: Laing D5 MCP 655 Rad: XSPC RX360
Cpu: Apogee GTZ Res: XSPC 250mm Passive
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
