my page file size is 2050-2050, whats the best for a 20gig HDD and winxp pro?
1700+ DLT3C @ 2.4 Ghz (220 x 11)
Abit NF7-S rev.2.0 with modded NB cooling
Sapphire ATI Radeon 9800XT 256MB
PC-3200 2 x 512 Corsair XMS
Western Digital 120GB 8MB HDD
"Framerate is Life!"
Wow you need to trim that page file down!
Mine is set for 100-800 and its optimal for me.
http://aumha.org/win5/a/xpvm.php
System
ASUS Z170-Pro
Skylake i7-6700K @ 4600 Mhz
MSI GTX 1070 Armor OC
32 GB G.Skill Ripjaws V
Samsung 850 EVO (2)
EVGA SuperNOVA 650 G2
Corsair Hydro H90
NZXT S340
well ok lol, I'll prolly go with 100 - 800 hehe !!!! but my default before on the minimum was 766 - 1500 something, should I keep it to default?
Also with 100 - 800 does your comp seem to slow down after playing a big game like bf1942?
No actually its the fastest setting ive ever used, it comes out of games very snappy and my memory is managed very well.
I have mine set at 100-100 on the partition with the OS, and 100-800 on the C drive. That way as soon as it goes over 100mb the page file is managed all from a seperate physical disk which is faster than making the head of the disk seek for files on the same drive as what you're using for other things.
Coupled with XP registry tweaks for speed and memory management it works very well. Check out that guide to see what works best for you.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
how do you change the page file setting??
I have hyperX PC3200 memory aswell 2 x 256, what registry, memory tweaks have you done...sorry to be a bugger but I hate it when it takes so long just to load certain programs and especially when comming out of big games like bf1942 my comp seems to have lost all it memory.Originally posted by Soulburner
Coupled with XP registry tweaks for speed and memory management it works very well. Check out that guide to see what works best for you.![]()
Right click My Computer > Properties > Advanced > Performance Settings > Advanced > Change
Go to Tweaktown.com and do a search for XP Tweaks. Go through the Guides Part 1 and 2, you will find them there.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
Don't use a page file at all never have, if you have atleast 512mb of ram there's no real reason to use it since ram is always faster than you HD. I've done many tests and I have never seen a advantage from using a paging file.
A64 4600+ X2
DFI Ultra D 11/14/05
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
So should I disable page file?, since I only have 512 ram and a 20gig HDD.Originally posted by corrupt
Try it and see what you think I only have 512mb's of ram and works great here.
A64 4600+ X2
OCZ Plat rev 2 1g
ATI HDTV Wonder
X800XL
MCE 05
P180
After playing a game like bf1942 does your computer seem to slow down? Does the paging file system have an effect on programs starting slow?Originally posted by corrupt
If you run without a swap file, you could run into problems and crashes if you have with excessive memory usage.
A better idea is to run a fixed sized swap file (to prevent fragmentation), and set it to a reasonable size. If you have 512 mb of RAM or more, then a couple hundred MB is fine. For a system with 256 mb, then 500 or so mb may be necessary. I monitored my setup for a couple of days, using the system performance monitor, and saw that I only dipped into the swap file occaisionally, and even then, never more than a hundred MB. I then set the swap file to 300 Mb - 300 Mb, and never looled back.
For those with over 1 Gb RAM, then disabling the swap file may be best.
Gaming settings
Abit NF7-S V2.0 @ 210 x12 (no mods), Air cooled, interface enabled 3:3 ratio, stock D27 BIOS
CPU: XP-M 2400+ (IQYHA 0402)
RAM: 2 x 512mb @ 2-2-2-11 dual channel
Video FX5950 Ultra @ 500/995
PSU: FSP-550
P95 stable (max) 221 x 11 same settings as above.
Actually no, setting the same min/max is a common misconception, read the article I posted.Originally posted by mluckey
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
thx soulburner!
Hi all,
I have generally found that for systems with 512mb or less of RAM, a page file is usefull (as games like UT2003 on high res etc can take up loads of mem), for these systems I use a fixed pagefile of 1.5x my systems mem (eg for 256mb RAM = 400mb page file). But for systems that have over 512mb mem ie 1gig like mine, I totally disable pagefile, it does speed things up dramatically for me anyway.
Hope this helps.
I personally run with a 1.5Gb page file, I tend to run a lot of rendering and Photoshop, so it makes sense to have one, and I may as well have it a decent size, I have about 7Gb free on this Windows XP partition anyways.
I wouldn't recommend disabling the page file altogether myself, it's Windows error message hell if you run out of physical RAM, and it has a tendency to cause all kinds of little problems in the future, in my experience.
And for the argument about fixed vs variable size pagefiles, it's not that much of an issue having a variable sixed one with an NT based OS, but I would prefer a non fragmented pagefile myself, so I use a fixed size one.
I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
OCZ PowerStream 520w | Mach II GT Cooled
What's the idea size for Win2k?
··•• m00² Modding Supplies ••··
Link? Search came up with thousands of hits.Originally posted by Soulburner
Also, unless you miscalculate your needs and hit the upper limit of a fixed swap file, you won't have any issues. If you want total safety, then leave the cap off. The performance hit is most likely swallowed by XP doing other crap anyways, so it won't matter.
Gaming settings
PSU: FSP-550
Well I use Diskeeper, and it keeps the Page File defragmented.
This setting is definetely better than a fixed size in my experiences.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
If you got a ton of ram just make a "ramdisk" using "ramdisk"and put your page file on it
GF4 MX440 - <8,629> 3Dmark01
Radeon9500Pro -<16,871> 3Dmark01 | <39,167> AquaMark3
5900Ultra - <21,127> 3DMark01 | <57,320> AquaMark3 | <7,444> 3DMark03
Radeon9800Pro - <23,791> 3DMark01
P4 3C @ 3.9Ghz | 256MB XMS3200 x2 | P4C800-Deluxe |
2100+ @ 2.35Ghz | 512MB PC3200 | A7N8X-Deluxe |
www.Badasscomputer.com Folding since 7/20/03 (Not Folding = User Error)
I would also like to learn more about this.Originally posted by Soulburner
Can u pls post a link?
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
I would guess that is the articleOriginally posted by Soulburner
Yup that's the one.
Try out those recommendations and see how you like them.
System
ASUS Z170-Pro
Samsung 850 EVO (2)
Corsair Hydro H90
NZXT S340
Thanks for the link m8!
I will try your recommendations.
Project ZEUS II
Watercooling setup:
100-800 worked better then 768, 100 did not work as good, 0 worked pretty good but windows changes it to 2mb and i get a message everytime I boot up saying i got not pf. (on 2k)
