DFI Lanparty JR X58 T3H6 review (56k warning)
Hello everyon
, about late last year everyone will remember JR P45, JR 790GX from DFI and i thought everyone will love it, well now DFI make it again on X58 platform with JR X58-T3H6 so come to see what happen with it
Motherboard Pictures
Package&Bundled
Board Layout
With the small size of the board devices will be installed on many but with the smaller size in Prati reasonable is not surprised that the engineers have been moved take some of the equipment below is the PCB to reduce jamming of the device and it would make it easy to design as well.
6 Phase CPU PWM, well PWM controller chip it is made in Thailand
6x DDR3 Triple-Channel, Support DDR3-1066/1333/1600 and 1800MHz(OC), up to 24GB
Northbridge Heatsink, At this time it seems the design of the thermal suite to the northbridge cooler from DFI will become the standard to their own. To be designed as two pieces which we can lift the top fin set out above to facilitate the adjustments that thermal suite is set to custom cooling with water or in Extreme mode as a DICE or LN2
Southbridge ICH10R , EZ Switch and 6x SATA3.0, support RAID0, 1, 0+1, 5 and Digital segment Debug
Expansion Slot, 2x Pci-e x16(gen 2.0) support CrossfireX and SLI , 1x Pci-e x1, 1x PCI 32bit
ClockGen Chip
Sound on board Realtek ALC889 8Channel
Back I/O Panel
>>> Bios Screens <<<
Sorry For My English
OverclockZone Team
THAILAND
- You may not post replies
- You may not edit your posts
Forum Rules
