XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > AMD
Reply
Old 02-25-2009, 01:50 AM   #1
Benny Lodewijk
Team ID - Indonesia
Benny Lodewijk's Avatar
Send a message via MSN to Benny Lodewijk Send a message via Yahoo to Benny Lodewijk
Phenom II X3-720BE List Capable to running 4 cores or not
Guys, after testing several Phenom II X3-720BE, i found that not all version/batch of this CPU can do 4 cores. So, i started to make this list to share which batch can and which batch can't.
Motherboard using GIGABYTE MA790GP-UD4H
List of batch
* 0904 BPAW ------> can't boot at all when ACC Enable, show F2 in debug card
* 0904 BPMW-------> Boot OK, detect as Phenom X4 and then stop, debug card shown 83 code.
*0849CPAW --------> Boot OK, and act normal like Phenom X4.
Share your experience here !
__________________
Visit Team ID Official Blog
Benny Lodewijk is offline   Reply With Quote
Old 02-25-2009, 02:07 AM   #2
chew*
No rest for the weary
chew*'s Avatar
Benny that would suggest that they appear to know about the issues and have put a stop to it? At least if you go by the date codes.
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is online now   Reply With Quote
Old 02-25-2009, 02:16 AM   #3
Benny Lodewijk
Team ID - Indonesia
They already know about it that's why not all Phenom II X3 can do 4 cores. If they don't know about it all Phenom II X3 will be capable to run 4 cores.
__________________
Old 02-25-2009, 02:34 AM   #4
Benny Lodewijk
Team ID - Indonesia
Update from 4 pcs BPAW 0904 i tested, only one can works 4 cores ... no now is not stepping problem.. it's your luck !!!
__________________
Old 02-25-2009, 03:31 AM   #5
mcbalaban
mcbalaban's Avatar
That would seem to be the right way of doing it for AMD.
Use faulty cores and put some good ones in the mix to spice things up and boost sales.
Nice find.
__________________
  - Do you like our owl?   - It's artificial?   - Of course it is.   - Must be expensive...   - Very.
PhII 955BE, GA-MA790FX-UD5P, 2x2GB Firestix, HD 4870X2, 2x500GB RAID-0, Corsair 850TX
mcbalaban is offline   Reply With Quote
Old 02-25-2009, 03:41 AM   #6
uF4No
uF4No's Avatar
I have a 0903 GPMW but can test it until weekend. i'll update then.
__________________
Rig: DFI LANParty UT nForce4 Ultra-D rev. AD0, AMD64 Opteron165 @2900MHz 1,44v CCBBE 0615EPMW WCed, Kingston HyperX 2x1Gb DDR400@530MHz 3-3-3-8, Sapphire Radeon 3850 512Mb, WesternDigital 500Gb + Maxtor DiamondMax 10 200Gb, Tacens Valeo Smart 560W
Water Cooling: Swiftech Storm Rev.2, Danger Den D5, Black Ice GT Stealth 240, 2*YateLoon Mid
uF4No is offline   Reply With Quote
Old 02-25-2009, 05:34 AM   #7
Shrekogre
my 0904 bpmw can though. i think all boils to luck
Shrekogre is offline   Reply With Quote
Old 02-25-2009, 06:48 AM   #8
Benny Lodewijk
Team ID - Indonesia
Can wait to see the result.....soon i will receive some X3 CPU again and gonna test it one by one
__________________
Old 02-25-2009, 06:51 AM   #9
ecat
I am Xtreme
Registration here took a while to complete, no biggie
904 CPMW
http://valid.canardpc.com/show_oc.php?id=510443
Edit:
4th core fails to run Prime95 at 1GHz, I didn't try any lower.
ecat is offline   Reply With Quote
Old 02-25-2009, 06:54 AM   #10
haylui
all my AMD system are single core
__________________
RIG 1:
AMD PHENOM II X3 720BE (unlockable into quad core)
batch no.: 0906 FPMW
ASUS M4A785D-M PRO
COOLERMASTER HYPER N520 HSF
TEAM ELITE DDR2 800MHz 4GB KIT
XFX HD4650 512MB DDR3
Maxtor 6Y080L0
WDC WD2500KS-00MJB0
AndySon G480W PSU
haylui is offline   Reply With Quote
Old 02-25-2009, 06:54 AM   #11
Benny Lodewijk
Team ID - Indonesia
904 CPMW
Thanks for sharing and welcome to XS !!
__________________
Old 02-25-2009, 07:08 AM   #12
Shrekogre
http://valid.canardpc.com/show_oc.php?id=514954
0904bpmw
Old 02-25-2009, 07:17 AM   #13
jlacy76
I have the CPMW, How stable are these with these boards?
__________________
Ga-Ma790x-ud4p/F7 bios - Lapped x4 720 BE @ 3696 1.55
Xigmatek S1283 - 8gb Corsair 800 @922 5-5-5 - Win 7 (64)
jlacy76 is offline   Reply With Quote
Old 02-25-2009, 12:21 PM   #14
superpyton
superpyton's Avatar
Tried X3 720 0851 FPAW on Biostar TA790GX A2+ (BIOS: 78DBA113) - after turning ACC to Auto my computer won't boot .
__________________
Athlon II X3 425 @ Phenom II X3 B25 3GHz (11,5 x 261) 1,1V
ASRock M3A785GXH/128M BIOS 1.70
Micron OEM D9JNL 2x2GB 1066MHz CL7 @ 1392 MHz 6-6-6-18 1T 1,77V
Athlon II X3 425 @ 4496 MHz on air
superpyton is offline   Reply With Quote
Old 02-25-2009, 01:41 PM   #15
ecat
I am Xtreme
Happy to be here, from my earlier lurking this is the place that puts the fun back into PC's
Old 02-25-2009, 04:42 PM   #16
Benny Lodewijk
Team ID - Indonesia
Same symptom with my first 0904 BPAW batch
__________________
Old 02-25-2009, 04:50 PM   #17
Cpt.Planet
Simon says EnJoYs a nub
Cpt.Planet's Avatar
Send a message via AIM to Cpt.Planet Send a message via MSN to Cpt.Planet
Sounds like AMD was disabling crippled/non working cores on some cpus to sell as X3s
__________________
Originally Posted by 3oh6
damn you guys...am i in a three way and didn't know it again
Follow TechREACTION on Twitter
Cpt.Planet is offline   Reply With Quote
Old 02-27-2009, 09:24 PM   #18
junkmonk
this is a very good idea. i'm looking at picking up a x3 720 to unlock the 4th core, and would love it if more people posted their results. also, which motherboards are required for this 'hack?'
junkmonk is online now   Reply With Quote
Old 02-28-2009, 03:52 AM   #19
staxm
staxm's Avatar
720BE 0851 FPAW @Biostar 790GXB A2+
2800MHz
3600MHz
__________________
Team Serbia
staxm is offline   Reply With Quote
Old 02-28-2009, 09:44 AM   #20
Veedo
Veedo's Avatar
got my 720 in yesterday, so far i am unable to load windows with 4th core enabled. its a 0904 CPMW. doesnt seem like an out of this world clocker either, so far i am unable to get it stable over 3.3ghz in windows. it is my first phenom though, so i might be missing something.
this was done on a asus m3a79 - t deluxe
__________________
m3a79-t | 2 sets of 4gbpq | phenom II 720be cooled by TRUE | hd4850
corsair 550vx | 6400aaks raid 0 5000aaks raid 0 | Lian Li 1100B
Veedo is offline   Reply With Quote
Old 03-01-2009, 04:46 PM   #21
ah_khoo
ah_khoo's Avatar
Send a message via ICQ to ah_khoo Send a message via AIM to ah_khoo
0904bpmw + dfi 790fxb, enable to unlock the 4th core but can't get it prime stable, 3d stable thou....
__________________
Always Make the Difference
| AMD Phenom™ II X4 B55 with Hyper 212+ | 790FX-GD70 | TW3X4G1600C9DHX | 2 * EAH3850/G/HTDI/512M with AK-VC03-BLUV @ X-Fire | Xonar DX |
| WD6401AALS + WD400BD + DH16NS10 & GH20NS10 | P243W | ProMedia GMX A-2.1 | Toughpower Cable Management 750W |
| SST-TJ09B-W + 2 * ALD-V01 | Eclipse II + MX™518 | Windows 7 Ultimate (64-Bit) |
ah_khoo is offline   Reply With Quote
Old 03-01-2009, 04:48 PM   #22
AgentGOD
AgentGOD's Avatar
Try lowering your OC :-P Or raising vcore. The forth core is obviously a weaker core.
__________________
.:: Gaming PC Specs ::.
Case: Antec Nine Hundred
CPU: Intel C2Q Q9650 @ 4.0 GHz (9x445), 1.31v (cooled by Xigmatek HDT-S1283) [IntelBurnTest{Linpack} stable]
GPU/Monitor: Visiontek HD 4870 X2 @ 800 MHz/4000 MHz +SyncMaster245BW 24"
Motherboard: ASUS P5Q Deluxe (BIOS 2005)
Memory: 8 GB (4x 2 GB) OCZ Reaper HPC DDR2 1066 @ 1069 MHz, 5-5-5-18, 1.90V
Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
PSU: OCZ GameXStream 700W
O/S: Microsoft® Windows Vista Ultimate X64 SP2
.:: HTPC Specs ::.
Case: Silverstone LCB13B-E ATX
CPU: Intel C2Q Q6600
GPU/Monitor: Gigabyte Radeon HD 4350 +Philips 42" 1080p 120Hz
Motherboard: Gigabyte GA-EP45-UD3R
Memory: 4 GB (2x 2 GB) OCZ Reaper HPC DDR2 1066
Hard Drive: 2x Western Digital Caviar Black 1 TB (RAID 1)
Sound: 7.1 surround through HDMI
PSU: OCZ ModXStream Pro 500W
AgentGOD is offline   Reply With Quote
Old 03-01-2009, 05:07 PM   #23
ah_khoo
ah_khoo's Avatar
have tried that @ 3.0GHz sir, but still once i click on start (prime95 or occt), i'll get a system lock up. i think i already gave up on getting it prime stable.
__________________
Old 03-01-2009, 07:03 PM   #24
Apoptosis
legitreviews
Apoptosis's Avatar
I ordered in a Phenom II X3 720 from Newegg on 2/26/2009 and got in a 0851 FPMW stepping and can enable ACC on the MSI DKA790GX Platinum motherboard with BIOS v1.6. If I set ACC to 'per core' I can see four cores, but in Windows it only shows up having three... Frustrated!
I posted the BIOS screen shot and OverDrive pictures here - http://forums.legitreviews.com/about20248.html#p139522
Apoptosis is offline   Reply With Quote
Old 03-01-2009, 07:12 PM   #25
Methious
Methious's Avatar
Send a message via MSN to Methious
I tried my Phenom X3 720 on the Asus M4A78T-e and it was a no go no matter what setting.
__________________
Asus P6T Deluxe /Core i7 965 Extreme
Dominator 6GB 1866 @ 1920
2x Raid0 VelociRaptor 2x Raid0 SaS Savvio 15k.1
Quad SLI GTX-295 when I'm feeling froggy
SLI'd GTX-285 for every day use.
ThermalTake TP 1200
Mouse With A string on it's Tail
(To cheap to buy a mouse)
Methious is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
