XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 02-16-2009, 04:12 PM   #1
chew*
No rest for the weary
chew*'s Avatar
4.4gig Phenom 2 validation done on Air
It's dirty, it's ugly and I downclocked quite a few things but the important thing is it was done on air albeit cold air, it was done with all 4 cores and it was done with 1.55v
Temps were ballpark 25C at the core.
http://valid.canardpc.com:80/show_oc.php?id=509917
__________________
heatware chew*
AMD is Back in Black Lifes more fun at -190C
How To Behave On An Internet Forum
http://www.thewavingcat.com/2008/02/...eed-the-troll/
http://www.livestream.com/chewsdisasterarea
Originally Posted by Sampsa View Post
1) Normal ES: Available to partners and press before the product actually launches. These are usually close to retail parts, maybe one stepping/node before retails. From my experience (I've had access to AMD & Intel ES CPUs before the official launch around 8 years) normal ES CPUs are actually usually worse than retails because manufacturing process develops all the time and retails keep getting better. Every Phenom II press sample (not even marked as ES but couple weeks earlier than retail parts) I've tested so far have been worse than normal retails.
chew* is offline   Reply With Quote
Old 02-16-2009, 04:16 PM   #2
EnJoY
XIP
EnJoY's Avatar
Send a message via ICQ to EnJoY Send a message via AIM to EnJoY Send a message via MSN to EnJoY Send a message via Skype™ to EnJoY
You are the man!
EnJoY is online now   Reply With Quote
Old 02-16-2009, 04:47 PM   #3
Oats
Nice clocks for air
Oats is offline   Reply With Quote
Old 02-16-2009, 04:47 PM   #4
Marco André
Marco André's Avatar
Hi chew*,
You reach that speed from Bios or by software? Nice chip
__________________
Originally Posted by To(V)bo Co(V)bo View Post
This is gonna be way more fun than my wifes tits.
Marco André is offline   Reply With Quote
Old 02-16-2009, 04:49 PM   #5
chew*
chew*'s Avatar
Originally Posted by Marco André View Post
Hi chew*,
K10 stat, boot into windows at 3.0 1.55vcore.
__________________
heatware chew*
Old 02-16-2009, 08:11 PM   #6
cky2k6
cky2k6's Avatar
Is it me, or do these chips seem to clock pretty poorly on air compared to how beastly they are on ln2? Seems a chip that does 6.7ghz shouldn't have much issue with a validation well into the high 4ghz range at least. Do they get unusually hot, or is there another reason for this diparity?
__________________
Core i7 920 3849B028 4.4ghz cooled by gtz | 12gb gskill ddr3 1600 | Sapphire HD4870x2 cf cooled by xspc fc | Asus Rampage II Extreme | 600gb Velociraptor Raid 0 / 1tb + of storage | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
cky2k6 is online now   Reply With Quote
Old 02-16-2009, 08:14 PM   #7
chew*
chew*'s Avatar
They don't like heat as in 60C, and scale much better cold. This is just a guess, but a side effect of getting rid of the coldbug makes them less tolerant to heat. I personally will take a heat bug over cold bug anyday
__________________
heatware chew*
Old 02-16-2009, 08:16 PM   #8
x-powerx800pro
Champion
x-powerx800pro's Avatar
Very GOOD ,I have to 0852GPFW air-cooled only 1.55V under 4.2G been under 1m. Interior temperature of 25 C
x-powerx800pro is offline   Reply With Quote
Old 02-24-2009, 05:48 AM   #9
Stefan Payne
What about the internal Northbridge inside the processor?
How was it clocked??
Stefan Payne is offline   Reply With Quote
Old 02-24-2009, 05:53 AM   #10
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Very impressive! I can barely get 3.8GHz out of mine, hoping it'll be a nice LN2 chip though.
They just don't like getting hot. They scale less with voltage and more with temperature. Whatever AMD changed in the manufacturing process, it made them clock about equal on air with Phenom + 200MHz but a hell of a lot of fun on sub-zero cooling.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 02-24-2009, 07:44 AM   #11
chris.y2k.r1
I've noticed the same thing, if you can keep the cores under 40c with water or air you can get some pretty amazing clocks...
__________________
Daily Desktop 1: Custom Built - Modified Data General Server Case
Asus Maximus Extreme | E8600 w/ Enzo Saphire | 4870x2 + 4870 - 3 MCW60s - X2 w/ Caldera | 4GB Supter Talent Project X DDR1600C7| OCZ GameXtreme 850
2x Samsung SATA2 Spinpoint 750GB Stripe | RADS - 2 PA320s w/ Metal 18V Deltas and DIY pump/res combo
Daily Desktop 2: ThermalTake Kandalf
Asus M4A79T Deluxe | 955BE | 4GB OCZ DDR 2000 8 8 8 30 | 4850x2 + 4850 | CPU on H20 w/ Apogee GT | 4850 on MCW60 l DIY Pump/res Combo | RADS - Swiftech 320mm and 240mm
All Parts for sale - PM ME
chris.y2k.r1 is offline   Reply With Quote
Old 02-24-2009, 08:14 AM   #12
chew*
chew*'s Avatar
I had dropped everthing down, cpu-z validations are all about cpu frequency.....its not about how preety your settings are to get there you don't get a cookie for having the 10th fastest cpu with a very high NB, you do get a cookie for the fastest cpu mhz though
Cold air helps alot, having a heatsink with some mass to it that can retain the cold air better helps as well, I did that on the OCZ vindicator, I now have a true with quite a bit more weight to it.
A TRUE copper would more than likely hold the max air cpu-z throne with some cold air over anything out there due to its mass.
Increasing voltage just ticks them off and adds more heat, there is a fine line between voltage/ temps.
__________________
heatware chew*
Old 02-24-2009, 08:53 AM   #13
Stefan Payne
That's what I don't understand 'cause the impact on performance isn't that little, although depending on the application.
Old 02-24-2009, 10:07 AM   #14
FlanK3r
FlanK3r's Avatar
Send a message via ICQ to FlanK3r
i found 2 guys better on AIR and with 1.68 on AIR, the best is now (any guy from Japan)
http://valid.canardpc.com/show_oc.php?id=484849
__________________
PC1
AMD Phenom II x4 965 BE C3 3.4GHz@3950MHz with 1.44V or at 4032MHZ+2828 MHz NB with 1.52-1.533V stable, AMD Phenom II X4 955 BE 3.2@3.895GHz+2665 MHz NB 1.485V with new BIOS, or 3.915GHz 2678MHz NB 1.5V = 24/7 and lower voltage (max 4264Hz with 1.485V and 4386 MHz 1.55V) CM Hyper 212, Gigabyte MA790X-UD4 F3 bios, 2x2GB Kingston Hyper X 1066MHz cl 5, 2x320GB HDD,ASUS HD5770 1024MB, saphire HD3870 512MB (1950pro 256Mb 610/1480MHz),Seasonic 500W+new Seasonic 650W Aspire X Cruiser, A4tech keyboard+mouse Razer deathadder ~
4386MHz AIR x4 955
4570 MHz AIR x4 965
Phenom X4 965 C3 is finally here -next chip=Thuban
http://www.xtremesystems.org/forums/...d.php?t=229492 AMD Cinebench R10 challenge
CPU2:AMD X2 4600+ EE Windsor
PC2AMD 3000+ s754, Gigabyte K8N, 1.5GB DDR Kingston, WD 250GB, saphire x1600xt -all default clocks
FlanK3r is offline   Reply With Quote
Old 02-24-2009, 10:10 AM   #15
chew*
chew*'s Avatar
I'd be curious to see that guys setup, 4.7 is a little suspect. 4.5 is probably doable, 4.7 maybe if you covered the board and heatsink in DI or poured ln2 on it or was testing on MT everest. got a link?
Actually that is Dumo from NY city lol........he's on phase was at my house saturday
__________________
heatware chew*
Old 02-24-2009, 10:18 AM   #16
chew*
chew*'s Avatar
thats why there are other benchmarks that measure performance.......
__________________
heatware chew*
Old 02-24-2009, 11:16 AM   #17
Lightman
Xtreme News
Lightman's Avatar
Congratz chew*
Nice to see 4.42GHz on all 4 cores AIR!
You've beat me on that one
I can try 1 Core 4.5GHz if it get cold enough outside, but 4 cores 4.3GHz for my chip would be awesome!!
You have a gem! You need to sent flowers to Simon
I can agree 4.5GHz is doable, anything above is possible on AIR only if you live in Siberia!
__________________
RiG1: Phenom II 940BE 0850BPEW (45nm@3850MHz 64bit), Gigabyte MA790FX-DQ6 (RD790FX), 2x2GB OCZ Reaper PC8500@1145MHz 5-5-5, HD5870 1GB, 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 400GB Samsung T133 + 30GB OCZ Solid SSD, Hiper 4M880
RiG2: HTPC AMD Athlon II 250, 2GB Crucial Ballistix D9, ASUS M3A78-EM, ASUS HD4670 512MB, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
SmartPhone T-Mobile Compact V
XBOX360 Elite paired with 52'' Samsung LCD TV
Lightman is offline   Reply With Quote
Old 02-24-2009, 11:56 AM   #18
chew*
chew*'s Avatar
Originally Posted by Lightman View Post
Congratz chew*
This is the "runt" of the litter I need to send a kidney at the very least
__________________
heatware chew*
Old 02-24-2009, 01:24 PM   #19
Lastviking
Thats not with air... its someone thats have miss write it to air trust me , you can find the score in Phenom II List of overclocks(and when Dumo did write it he did write it was not air )
chew* nice with 4419mhz air valid but come back when you dont use a ES chip it will be more fair then
But its still a very great chip.
Lastviking is offline   Reply With Quote
Old 02-24-2009, 01:46 PM   #20
chew*
chew*'s Avatar
Hmmm yah well I figured the board I'm on and an OCZ vindicator with a bench setup in a room and not hanging out a window makes it break even, however I will give the m4a79 deluxe a run with the 940BE already booted it up on stock cooler at 4.0 with only 1.475V, IIRC I needed 1.55v on the gigabyte also the gigabyte refused to boot over 1.6v
In the fwiw department I have not submitted it other than to validate it for proof, really have no interest in air records to be truthfull as they are not records, just showing you guys what you can expect to see in the near future.....
Cheers
__________________
heatware chew*
Old 02-25-2009, 12:17 AM   #21
FlanK3r
FlanK3r's Avatar
LASTVIKING:hm, maybe its true :-).
But 4.4GHz on AIR is ofc impressive overclock :-). Im waiting on x4 945 and il try in classic case get 4GHz with air cooler (and ASUS M4A79 Deluxe).
__________________
PC1
4386MHz AIR x4 955
4570 MHz AIR x4 965
Old 02-25-2009, 12:54 AM   #22
Lastviking
Cheers
Its looks like the Asus board have much greater pwm than the Dfi and Gigabyte board, the dfi board also have some trouble over 1.55v-> maybe its the cpu but i think its more the board after your info.
Old 02-25-2009, 09:45 AM   #23
Blazer_
Send a message via MSN to Blazer_
Nice scores.
I will tomorror 4.4GHz, i have now "max" ~4.3GHz,
http://www.hwbot.org/compare.do?resultId=816903
And Wprime 4GHz
http://www.hwbot.org/compare.do?resultId=817230
All Air, Wprime go more..but that was "race" stat..
Tomorror if it goes ~4.2Ghz ?
Ps. Can i change my nick here ?
Blazer_ is offline   Reply With Quote
Old 02-26-2009, 08:03 AM   #24
Solid Snake
Solid Snake's Avatar
Send a message via MSN to Solid Snake
Awesome Man
Gigabyte rulzzz
nice score man on air
__________________
"We Overclock and Crunch you to the Ground" - DDTUNG
Solid Snake is offline   Reply With Quote
Old 03-03-2009, 01:48 PM   #25
chew*
chew*'s Avatar
Validations are great, they are even better with video proof....
http://www.youtube.com/watch?v=1G2wr...e=channel_page
Managed to get a little more out of it and a legit validation
http://valid.canardpc.com:80/show_oc.php?id=519461
__________________
heatware chew*
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
