Screen shot:Code:ATI CrossFire Xtension v1.0 by AgentGOD ----------------------------- Home pages: www.epichardware.com & www.ultimate-filez.com Donation: www.ultimate-filez.com/?page=donate Description: Ever ran into a problem where you could not use your big, multiple ATI GPU setup on a new game? Don't worry, many people have had the same issue, and up until now, the only solution was to wait for an updated build of the Catalyst drivers, which usually takes over a month! Now, that problem has a solution! ATI CrossFire Xtension allows you to create custom profiles that will force CrossFire (ATI multi-GPU solution) support on non-supported, or new, games and applications. Requirements: -Microsoft .NET Framework v2.0 (minimum) -An non-crossfire supported Direct3D/OpenGL game (usually) -Two or more ATI graphics cards (dual-GPU on single PCB counts) -Windows XP/Vista (32-bit or 64-bit) Instructions: Extract the program to its own folder, then run the program. Add a game/application to the program to create a profile for that game/application. Be sure to select the correct rendering method! If you aren't sure which one your game uses, you can always check Google! Then, launch the game by selecting, then double-clicking the game, or click the Launch button. Your profile settings will be saved upon quitting the program, or you can manually save by hitting the Save button. The profile will be saved as "ATI_CF_Xtension.ini" in the same folder. Enjoy! Credits: ---------- AgentGOD - coding the program ATI/AMD - for the HD 4870 X2 TricksOfDeath - UI revisions NickF - bug testing Copyright © 2009 [E]pic [H]ardware & Ultimate Filez
Download link:
http://www.epichardware.com/bin/ATI_CF_Xtension.rar
