I am Xtreme
Modded Biostar TPower I45 BIOS
Yep, I said I would, and now I have had a little chance to play around with the TPower here is the first mBIOS for it
Changes
- Updated built-in Memtest 86+ module to V2.11
- Changed some default settings
- Default vDIMM is now 2.064v
- Replaced P6 Microcode module
Some may be wondering why default vDIMM is 2.064v. The answer is simple, I noticed GKX and GMH Micron D9 modules don't play nicely with the TPower on stock voltage, even though their fine in my P5Q Pro, so to circumvent the no boot problem with these modules I upped the default vDIMM a bit.
How To Update The BIOS
1. Place a floppy in the drive and run Dr. DOS
2. Place AFUDOS and TPower2.rom on the floppy
3. Restart and at the DOS prompt type the following;
AFUDOS.EXE /iTPOWER2.ROM /PBNC /N
Thats it! Just hit enter and let the utility do its thing.
The BIOS has been tested and it all works perfectly, just remember to load setup defaults after the flash. The package includes all necessary tools to update the BIOS via floppy disk.
DL LINKY
- You may not post replies
- You may not edit your posts
Forum Rules
