Results 1 to 15 of 15
Thread: Snow Day?! LowBuget Benching / Domino ALC Guetto Mods / Q9650@5000Mhz
    Xtreme Addict Jor3lBR's Avatar
    Jul 2007
    Arizona - USA
    Talking Snow Day?! LowBuget Benching / Domino ALC Guetto Mods / Q9650@5000Mhz
    Hey Guys,
    Just wanted to share some results from yesterday when I decided to have some fun with $61 WC system from CoolIT and show it's possible to have fun in the snow inside the house
    Now to the guetto mods and later benching session:
    [Domino A.L.C. Guetto Mod]
    Parts Used:
    1 x Wife's Domino ALC WC System - $61
    1 x Used Swiftech MCR 220 Rad - $20;
    2 x 120mm Lian-Li Medium Fans - $Free (came with my case);
    Some 1/4 Tubing and Fittings - $5
    Fill port - $3
    Snow - $priceless
    So I first started by cutting the original tubes and attaching the new tubes with the MCR 220 in the windows pulling cold air from outside thru the rad. Fill the rads with much water as possible because to fill this thing is a pita because of the tiny pump! The rest you can do thru the Domino rad mini fill port that I replaced with a 7/16 tubing.
    This is the before:_____________________________________
    After:__________________________________________________
    Now for some temps comparison:
    Unmodded Domino
    Water Temps always above room temp.
    Idle - 30-33oC
    Load - 65oC-72oC
    Modded Domino
    Water temp always below room temp.
    Idle - 14oC-17oC
    Load - 37oC-42oC
    That's 16oC difference on Idle and 30oC on Load
    Pics with temps on same setup used to compare temps:_____________________________________
    CPU: Q9650@4352Mhz 512x8.5
    Mobo: Gigabyte EP45-EXTREME DDR2
    Cooler: CollIT Domino A.L.C.
    Ram: 4gb G.Skill Pi 9600
    Video: ATI HD4850
    PSU: SilverStone OP1000-E
    Voltages:
    1.32 vcore / 1.30vtt / 1.44mch
    Idle stock Domino:
    Load stock Domino:
    Idle Guetto Domino:
    Load Guetto Domino:
    [Low Budget Benching]
    Now for the fun part I was able to boot the Q9650@ 4999-5000Mhz with the modded Domino A.L.C and do some 4905Mhz 3D benching and some soft stability tests (no tweaks wazza, cache memory etc) etc:
    [3DMark01/SuperPi32m/wPrimeStability/Everest @ 4905Mhz and ATI HD4850]
    @4905Mhz
    @4860Mhz
    Hope you guys enjoyed
    //RETIRED-o00o--°(_)°--o00o-OVERCLOCKER//
    Banned
    Feb 2008
    Buffalo, NY
    Nice work, and some monstrous FSB for a quad!
    Memory Addict
    Aug 2002
    Brisbane, Australia
    wow nice work indeed! funny your after load temps are over a bit higher than my room ambients yesterday (~34c) LOL
    Nov 2007
    Toronto, Canada
    amazing results. Who says winter sucks lol.
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
    Xtreme Cruncher
    Jun 2008
    pacific NW usa
    thats just amazing! good job there.
    ............................ImAcOmPuTeRsPoNgE............................
    [SIGPIC][/SIGPIC]
    MY HEATWARE 76-0-0
    Jul 2007
    ARIZONA
    lol a 5.0 quad photo shot ! well done, really like the getto coooolit job
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Nov 2007
    nice fsb for quad
    Jan 2009
    Very good results,awesome fsb either
    2600k@4.8Ghz
    Asus P8P67 dlx (1254)
    G.skill RipJaws X 4X2GB 1600mhz CL8-8-8-21
    HD5450
    Samsung HD103UJ X3
    Intel X25-M 80GB SSD
    Hec Zephyr 650W
    Antec P182
    Aug 2007
    Germany/Bavaria
    Very nice FSB, congrats for 5 GHz!
    The Initial value finished
    PI calculation is done!
    Quote Originally Posted by Zeus View Post
    Software tweaks are not for sale.
    Mar 2008
    Really creative
    Nice benching session there,Q9650@4.9ghz wprime 32m under liquid is not bad at all,pretty good i reckon
    Intel E8600 E0@420x10(H20)/Abit IP35 Pro/Team Xtreem DDR 2 1066mhz D9GKX@420mhz,5-4-4-11-2T /Crucial Ballistx Tracer DDR 2 800mhz 16FD3@420mhz 5-4-4-11-2T/Gigabyte GTX260 SOC@720/1512/1300/LG SATA DVD-RW/WD 320GB +Segate 1TB/Corsair HX520W/Enlight Lian Li OEM PC7A casew/W65A Side panel
    Liquid cool: Dtek Fuzion V2,Swiftech MCR220,Swiftech Radbox,Swiftech Micro res,Nirox P2800 modded pump,Generic 1/2" ID tubing,3xYate Loon mid speed
    Note:E8500 is 9.5x but cpuz got issue and X2 4600+ is oc with stock cooler,max validation and never push
    9.204's PI
    Feb 2008
    Denmark / Aarhus
    At normal room temp is it worth getting a domino instead of a Scythe Mugen I ?
    Desktop I5-3570k, 8GB Ram, GTX 560, Silverstone TJ08-E, Crucial M4 128GB, 750W Silver Power, ASUS P8Z77-M
    Laptop ThinkPad W520 2720QM /2 x 4 GB ram / Quadro 1000M / Crucial M4 128GB + 500Gb Hdd / FHD Screen / Intel WiFi Link 6300 AGN WLAN / 9 Cell Battery
    Laptop 2 New Macbook Pro Retina / i7 QuadCore / 650 GT / 16GB Ram / 512 GB SSD
    Server: Athlon II X4 640, ASROCK K10N78, 8GB Ram, LSI MegaRaid 8 port, 64GB Vertex 1, 5 x 1 TB WD Raid6, 3 x 3TB Seagate Raid5
    Jul 2007
    Arizona - USA
    Post
    Quote Originally Posted by Mech0z View Post
    I would sincerely thing the Mugen would outperform an un-modded Domino by a little. It is cool because it's quiet and simple to use but the single rad cannot dissipate to much heat as a PA or better rads. If you into modding adding a bigger rad will make it very effective I added a Swiftech 220 Rad and at room temps it can hold a Q9650@450 Priming.
    The original Domino will beat my Sunbeam Core Contact Freezer but I doubt it could beat a Mugen or a TRUE.
    Mar 2006
    Nice chip and nice ram!
    Assistant Administrator systemviper's Avatar
    Nov 2007
    Newtown, CT
    as always , very impressive
    HWbot - Team: XtremeSystems
    XS cruncher - Team: XtremeSystems
    OCN Feedback
    HEAT
    *** Being kind is sometimes better then being right.
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    extremely impressive numbers for a quad core chip Jor3lBR .. im curious what is the stepping of your q9650 ?
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
