XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 02-06-2009, 12:00 PM   #1
fgw
fgw's Avatar
RivaTuner plugin supporting GT2xx and HD4870 Voltage Tuning
finally here is a first release of my RivaTuner plugin wich allows voltage control on vga cards equipped with a Voltera VT1165 VRM controller.
as far as i know this are: GTX260 65nm, GTX280, GTX295, HD4870 and HD4870x2
this VT1165 plugin is an enhanced version of the VT1103 plugin already included with RivaTuner and supports the previously available monitoring features plus some added functionality:
already included in VT1103 plugin
  • vrm output voltage
  • vrm output current
  • vrm temperature for up to 5 phases
added the functionality
  • change vrm output voltage on the fly
  • monitor status of OCP
  • monitor status of OVP
monitoring of OVP and OCP might be useful for hardmodded cards to verify if either of this safety features is activated or not.
to integrate this in a RivaTuner plugin has the advantage of utilizing the available RivaTuner functions to access the VT1165 directly. there is no need to manually scan for a device, write down register addresses and enter this values somewhere else, besides in RivaTuners scheduler to apply the settings at startup.
also you don't need to care about which one of the registers is used in which mode, as the plugin will detect the currently used register itself and apply the settings to this register. so to completely setup your cards all you need to do is to bring the card in the mode you want to change (idle, 2d, low 3d or performance 3d) or what ever it is called and change the voltage as required. there are not more than 4 modes available. most cards don't use all of them. my gtx295 is using only one mode. usually i would assume putting the card under load (atitool 3dview would be fine for this) and change the voltage then. i cant see a reason to change any other modes, but its up to everybody to do so.
you do all of this at your own risk! don't blame me if you overvolted your card too much and thus burnt it. this is a very powerful and dangerous tool!
also i would not have been able to create this without the help of Unwinder, the creator of RivaTuner. although he did not take part in the devolpment, he put some valueable info in the "evga voltage tuner" thread here in the forums and also kindly answered all my boring questions!
that said, lets roll ...
the plugin can be found here: vt1165.zip
as the plugin is created with visual studio 2008 you need to download and install microsoft vs2008 runtime components. this is just about 1.7MB and can be found here:
Microsoft Visual C++ 2008 Redistributable Package (x86)
here is a step by step guide on how to install and use my plugin:
experienced RivaTuner users wil most likely know almost all of this already and just look at the few points below and at some screenshots at the end:
  • download the plugin vt1165.zip
  • download and install the Microsoft Visual C++ 2008 Redistributable Package (x86)
  • download and install the latest version of RivaTuner
  • start up RivaTuner once to let it configure its database and exit RivaTuner again (rivaTuner might get started directly after ths installation. if so, just let it configure its database and manually exit again.
  • copy VT1165.dll into RivaTuners plugin folder. this is PlugIns\Monitoring within RivaTuners installation folder. on my system this is: C:\Program Files\RivaTuner v2.22\PlugIns\Monitoring
  • run VT1165.reg found within vt1165.zip. this changes a single registry key to activate the plugin. don't do this in the gui as there is a bug within my code that might crash RivaTuner. i have not yet sorted this out. use VT1165.reg as a workarounf in the meantime to activate the plugin for the first time!
finally start up RivaTuner again.
the plugin checks upon startup if a card is supported and pops up the following window for each card unsupported card:
so if you see this, you are out of luck!
if everything went right and your card is supported the following window should pop up:
click on the small button besides Customize...1 to open up the menu and then select Hardware monitoring 2 to bring up the Hardware monitoring window.
depending on the version of RivaTuner you are running, a warning might come up first:
clicking on the [UP] button will increment the voltage. if you are running on two identical GPUs and have selected Apply settings to both GPUs at the beginning, voltage for both GPUs will be increased simultaneously, as you can see in the following screenshot. clicking the [DOWN] button will decrease voltage respectively. the currently selected voltage is displayed in the VRM Voltage Control window immediately as you click the button. the graph might follow with a delay depending on the update rate specified in Hardware monitoring setup, usually 1 second.
if you want to make the settings to be applied automatically on startup, simply use the values displayed in the [b]VRM Voltage Control[b] window besides Parameters: when setting up a scheduler entry in RivaTuner under the Scheduler tab.
running on a system with either a single GPU installed or if there are two GPUs of different type installed, you should have selected Apply settings to first GPU only at the beginning. this results in changing the voltage for the first GPU only. in this situation, there is currently no way to change the voltage for the second GPU. as soon as RivaTuner V2.23 gets released, this restriction will be lifted, and all GPU's can be modified individually!
if you selected the wrong mode on startup, just close the Hardware monitoring window by clicking the [x] button and reopen it again. you will be prompted to select the mode on every startup.
finally, two new graphs are available that might be of interest for some hard core overvolters using hard modded cards. this two graphs show the state of OVP and OCP. if OVP or OCP is inactiv (normal) the graph shows a steady line at 0. if OVP or OCP gets activated the graph jumps up to 1 signalling OVP or OCP condition.
as i have not hard modded my card i was not able to verify if this works as expected. so if any hardcore overclockers are out there and suspect OVP or OCP is kicking in on their cards, please use this plugin and report back. also i had just one gtx295 at hand so i was not able to verify the functionalty on different cards. please report back if you run into any problems or have any further questions or feature requests. but keep in mind, my programming knowledge is somehow limited and dont expect miracles.
once again: remember this tool allows you to change voltages to very dangerous levels for you GPU, so be careful and don't blame me if you burn your card. you do all of this at your own risk!
__________________
Processor: Intel Core 2 Duo E6400 SL9S9 3200MHz (400x8) - E8600 SLB9L waiting on my desk
Motherboard: AB9QuadGT Bios=17 | Vcore=1,4475V | VDDR2=2.0V (everything else at default)
Memory: Muskin XP2-8500 Ascent (2x2GB) 400MHz
Video Card: Inno3D 8800GTS (G92)
Power Supply: Seasonic S12 650W
Case: Chieftec BH-01B-B-B
Watercooling: Laing DDC XSPC Top| Heatkiller CPU / NB / GPU | Black Ice GTS 360 / 3 Scythe S-Flex SFF21E 700rpm pull with custom shroud
Temps: 34C Idle | 53C Peak Load | 26C Ambient
Last edited by fgw; 02-06-2009 at 02:14 PM. Reason: 4850 is using a different VRM controller! removed it from supported devices
fgw is offline   Reply With Quote
Old 02-06-2009, 12:06 PM   #2
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Nice! Was waiting for someone with the coding skills to do this
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 02-06-2009, 12:23 PM   #3
AuDioFreaK39
The generation of 2010
AuDioFreaK39's Avatar
Send a message via AIM to AuDioFreaK39 Send a message via MSN to AuDioFreaK39 Send a message via Skype™ to AuDioFreaK39
Thanks a bunch bro!!
__________________
EVGA X58 SLI Classified nForce 200 Limited Edition
Intel Core i7 965 Extreme 3.20GHz
Thermalright TRUE Copper w/ 2x Noctua NF-P12s (push-pull)
2 x Sapphire Radeon HD 5970 2GB [Quad-CrossFireX]
6GB (3 x 2GB) Mushkin XP Series DDR3 1600MHz 7-8-7-20
SilverStone Strider ST1500 1500W
2 x Samsung Spinpoint F1 HD753LJ 750GB (1.5TB RAID0)
Creative X-Fi Fatal1ty Professional / Logitech G51 5.1 Surround
SilverStone Raven RV02
Windows 7 Ultimate x64 RTM
AuDioFreaK39 is offline   Reply With Quote
Old 02-06-2009, 12:24 PM   #4
DMH
DMH's Avatar
Sorry but the more option is not available to me
__________________
Proud owner of an iPhone3G 16G White
SpiTweaker by Monteboy,try it
DMH is offline   Reply With Quote
Old 02-06-2009, 01:08 PM   #5
George_o/c
George_o/c's Avatar
Send a message via MSN to George_o/c Send a message via Yahoo to George_o/c Send a message via Skype™ to George_o/c
Wow, cool plugin
George_o/c is offline   Reply With Quote
Old 02-06-2009, 01:08 PM   #6
afireinside
I am Xtreme
afireinside's Avatar
Send a message via AIM to afireinside Send a message via MSN to afireinside
No go on 64 bit vista + visioktek 4850 512MB crossfire. No error message, and no plug in shows up either.
__________________
Phenom II 940 BE / ASUS M4A79 / HD5770
3808mhz CPU 2720mhz NB | DDR1088 5-5-5-15 | 975/1300
afireinside is online now   Reply With Quote
Old 02-06-2009, 01:36 PM   #7
Boogerlad
would bios volt modding work?
Boogerlad is offline   Reply With Quote
Old 02-06-2009, 01:45 PM   #8
fgw
fgw's Avatar
sorry my fault, mixed up the screenshots when merged them during editing! you need to rightclick on one of the output voltage graphs to get to the correct setup menu.
updated the screenshot in my post.
__________________
Old 02-06-2009, 01:50 PM   #9
fgw
fgw's Avatar
just got a reply from Unwinder, 4850 is using a different VRM controller, thus not supported!
as mentioned in my posting, i just tested this with my own gtx295 and got the list of supported devices from various other posts. unfortunately, the 4850 series cards are not supported!
__________________
Old 02-06-2009, 02:00 PM   #10
fgw
fgw's Avatar
may be, have not tried it so i cant tell.
but when you are talking about tools like nibitor, most likely not as you can change only the selection of preset voltages, but not the voltages itself as the plugin does.
modding the bios with a hex editor might work, but thats a different story and beyond my knowledge.
__________________
Old 02-06-2009, 02:05 PM   #11
kemo
Send a message via MSN to kemo Send a message via Skype™ to kemo
I haven't heard of anyone that got HD4850 Softmode work with rivatuner
__________________
Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
Asus X58 P6T
6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
XFX HD5870
WD 1TB Black HD
Corsair 850TX
Cooler Master HAF 922
kemo is offline   Reply With Quote
Old 02-06-2009, 02:07 PM   #12
mikeyakame
mikeyakame's Avatar
If you need someone with x64 to recompile and check the source just shoot me a message. Probably just needs a few adjustments made for 64bit pointers, though RT is 32bit so that shouldn't be an issue itself.
Are you using RT API to write the registers?
BOOL WriteI2CEx(BYTE *BUS, BYTE, *DID, BYTE *REGISTER, LPCSTR *g_complex[gpu_id].m_dev) I believe
There is also ReadI2CEx(...)
the Ex functions are to access any GPU device, the non-Ex are only for primary GPU.
__________________
DFI LT-X48-T2R UT CDC24 Bios | Q9550 E0 | G.Skill DDR2-1066 PK 2x2GB |
Geforce GTX 280 729/1566/2698 | Corsair HX1000 | Stacker 832 | Dell 3008WFP
mikeyakame is offline   Reply With Quote
Old 02-06-2009, 02:12 PM   #13
DMH
DMH's Avatar
Nope still not working man
__________________
Old 02-06-2009, 02:16 PM   #14
fgw
fgw's Avatar
what card are you using?
__________________
Old 02-06-2009, 02:25 PM   #15
Solus Corvus
Solus Corvus's Avatar
Works nicely on my 4870x2. Thanks for releasing this.
Solus Corvus is offline   Reply With Quote
Old 02-06-2009, 02:29 PM   #16
fgw
fgw's Avatar
guess the problem is he is using 4850 cards. unfortunately i originally thought the 4850 is using the VT1165 but i was wrong! updated my post and removed the 4850 from the list.
yes i know and use this functions.
have you tried it on your gtx280 under 64bit?
__________________
Old 02-06-2009, 02:31 PM   #17
mikeyakame
mikeyakame's Avatar
Neh. It's only 9.30am here I'll grab it now and take a look.
Ok first thing to fix.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Unwinder\R ivaTuner\Monitoring\Plugins]
"VT1165.dll"=dword:00000001
Reg key needs to be like that for 64bit OS.
So just make an extra registry key called vt1165_x64.reg and tell people with 64bit OS to run that.
32bit registry keys are stored in there.
And it loads once I do that but throws an exception about unreferenced memory address and takes out Rivatuner.
When I restart RT it seems to load ok, but it has no values in your message box and they are wrong!
GPU=0, VID=CBh, Voltage=0.000v...
It also randomly selects VID register offsets heh. It needs to be linked against newer platform sdk and i'd say pointers aren't being handled correctly for some functions. Shoot me the source and I'll see if I can find the problem and fix it.
__________________
Old 02-06-2009, 02:32 PM   #18
Solus Corvus
Works fine in Vista x64 here.
Old 02-06-2009, 02:35 PM   #19
fgw
fgw's Avatar
thanks a lot, for confirmation, solus!
__________________
Old 02-06-2009, 02:45 PM   #20
mikeyakame
mikeyakame's Avatar
Mind you I'm booted on Windows 7 x64 at the moment, and don't really want to boot back to Vista SP2 unnecessarily.
__________________
Old 02-06-2009, 03:25 PM   #21
Jaivan
Xtreme Cruncher
Jaivan's Avatar
Works great for me vista x64 CF 4870's
Thanks a lot for the post...hehe time to go clock them up now
Edit: Can you also give more instructions on how to load the settings on start-up.
__________________
Asus M3A79-T | Phenom II 940 @ 3.618Ghz (268x13.5) 1.536v NB @ 2.680Ghz 1.475v | 8Gb G.Skill F2-8500CL5-2GBPI @ 5-5-5-15 1072MHz | 2x HIS HD4870 512MB @ 825/900 | 3ware 9690SA-8I RAID 6 with 8xSeagate 7200.12 500GB | Auzentech Prelude | Silverstone Decathlon 850W | Silverstone TJ-07 | Samsung 275T | Vista X64
Jaivan is online now   Reply With Quote
Old 02-06-2009, 03:46 PM   #22
Telperion
Telperion's Avatar
XP Pro, SP3.
Does not work on my Asus 4870 1 GB Dark Knight card. Gives me the red error message up above.
Telperion is offline   Reply With Quote
Old 02-06-2009, 03:52 PM   #23
DMH
DMH's Avatar
GTX260 216SP Gainward,Vista Ultimate 64-bit
__________________
Old 02-06-2009, 03:58 PM   #24
Luka_Aveiro
Luka_Aveiro's Avatar
I think that specidfic gainward card does not have the reference nvidia design, so it might not have the Volterra 1165 voltage regulator, that's why it isn't working, filho...
__________________
Some guy about Fermi early benchmarks at 13/12/2009 (european date format)
Originally Posted by v_rr View Post
Santa Claus is coming earlier this year
Dream Land
Luka_Aveiro is offline   Reply With Quote
Old 02-06-2009, 04:12 PM   #25
LowRun
LowRun's Avatar
Even tho' i don't have the hardware to take advantage of your plugin, i have to thank you big time for that very nice contrubution to the OC community. You sir represent the true XS spirit
Again, thank you very much.
__________________
Originally Posted by Shintai View Post
I still dont believe in a L3. It simply makes no sense when looking on the size and past history. Itanium only got a L3 due to the massive sizes of up to 24MB and soon 30MB. And I dont think anyone here on the board got access to a nehalem system, nor will have it for the next 3-6 months.
L3 is a step backwards for mainstream, not upwards.
LowRun is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
