a little dremel needed 5minutes approximately..
making sure its clean
i940 at 4ghz
ambient 22.0-22.1c(3 digital thermometers)
3mounts each...no variance
mx-2 22g syringe
prime95 + realtemp + 15minutes
480gtx push pull + dual 355 pumps with xspc tops
last place: dtek fuzion v2, even with high flow...it couldn't keep up with koolance or ek, computer restarted go figure
3rd place: gtz, not exactly good, but it had slightly better temps than the fuzionv2, had leak problems with it, computer restarted..
2nd place: ek supreme...as the name implies..it is supreme only to old blocks..
1st place: k350, no surprise..tested and remounted for this review...best damn block in water cooling at the moment..
**fitseries next weekend
I am running the CPU in its own loop or with the NB cooler. so this block should be great!
