Results 1 to 25 of 35
Thread: Fits Radbox monster build (work log)
Threaded View
    Xtreme PITA to MM
    Nov 2007
    ATX
    i wanted to make something that would cool my entire computer and handle the load of a i7 at max.
    i'll be using 2 HWlabs 560GTX's that gary from sidewinders ordered for me from HWlabs.
    i'll be using 8 delta FFB1424SHG's for fans. these are 140mm x 50mm and have 237cfm at 24v.
    to power the fans i'll be using 2 meanwell S-100-12's and a meanwell S-150-24 for my pump, a pdd-20.
    i'll be using 2 EK250 res's as well.
    frame...
    rads...
    fans installed...
    res's mounted...
    psu's mounted and testing fitment of the rads...
    psu wiring....
    a quick test outside the case...
    first run....
    wiring up the fans...
    heres a video to show how loud it is...
    http://www.youtube.com/watch?v=M_m-TxaPMXA
    things you cant see in the pics....
    1. fan psu's allow for 9v - 17v so i can regulate the fan speed from the psu.
    2. like the fan psu's, the pump's psu can be regulated from 19v - 31v to adjust the pumps speed/flow.
    3. unit weighs 47 pounds filled when full of water.
    4. dual res makes bleeding the loop A LOT faster because it allow for 2x capacity when filling the loop. looks cool too, at least thats my opinion.
    5. fans are modular and use a 6pin pcie connector. i have several more of these so if for some reason one dies its a matter of 4 screws and a simple unplug to replace it.
    6. it measures... 27" tall x 16" wide x 12" thick.
