First time mismatched 6x1GB triple channel. Still manages to accomodate my push 120x38mm thick Scythe UltraKaze 2000rpm fan with memory module installed in dimm slot 1
System specs
  • Intel Core i7 920 3836A756
  • Thermalright Ultra 120 Extreme + LGA1366 Bolt Thru kit + 2x 120x38mm Scythe UltraKaze 2000rpm 87cfm fans in push/pull
  • DFI LP UT X58-T3EH8 R.A51 - 01/23 beta bios
  • 128MB Gainward FX5200 PCI
  • Ram cooling: 3x 60x25mm Sunon 23.5cfm Maglev fans
  • 80GB Hitachi 7K80 SATAII
  • Pioneer DVD-RW
  • 1KW Corsair HX1000 psu
  • WinXP Pro SP3 full nLite updated hotfixes / Windows 7 beta dual boot
Memory configuration:
  • Dimm slot #1: 1GB G.Skill PC3-12800HZ (Samsung HCF0)
  • Dimm slot #2: 1GB Corsair DDR3-2133C9DF Dominator (Samsung HCF0)
  • Dimm slot #3: 1GB Cellshock PC3-14400 (Micron D9GTR)
  • Dimm slot #4: 1GB Corsair DDR3-2133C9DF Dominator (Samsung HCF0)
  • Dimm slot #5: 1GB Cellshock PC3-14400 (Micron D9GTR)
  • Dimm slot #6: 1GB G.Skill PC3-12800HZ (Samsung HCF0)
Seems with 6x1GB AUTO CMD rate = 2T, so for 1T you need to change CMD rate from AUTO to 1T (1N).
Bumped vdimm straight to 1.830v in bios and clocked 6x1GB straight up to DDR3-1606Mhz 8-8-8-24 1T to see how it runs. Everest latency speeds seem to get slower as you add more modules. So in terms of fastest everest latency the order goes = 2x1GB > 3x1GB > 6x1GB. Still 32M time with 6x1GB DDR3-1606Mhz 8-8-8-24 1T is pretty decent.
6x1GB @DDR3-1606Mhz 8-8-8-24 1T at 1.830v bios (DMM measured 1.835v real)
