Results 1 to 23 of 23
Thread: Phenom 2 Overclock results ambiant air/cold air 4.2ghz+
Threaded View
    Dec 2002
    Well after a week of testing heres a rundown of the voltages for the clocks....all clocks are bench/game stable and prolly need a bumb up of .03-.07 to be prime stable ....Ill be testing for prime stable clocks later on but heres how it worked with this setup
    OS Vista 32 and system specs are in my sig.
    Here are idle and load temps from 3 voltage settings 1.35-1.55v
    1.35v idle 30c load 43c
    1.45v idle 32c load 50c
    1.55v idle 35c load 58c
    stock clock 3ghz to 3.5ghz 1.35v
    3.6ghz 1.4v (need to test for lower maybe 1.375v-1.38)
    3.7ghz 1.45v idle temp is 36c
    3.8ghz 1.5125v
    3.9ghz 1.55v
    4ghz 1.575v just for screenie and validation. At this point Im almost at my aircooled max level. Im on air and ambiant is 24c.....Ill post load temps as I get them.
    4.1ghz 1.6125v cold air cooled ambiant 11c
    4.26ghz 1.66v...cold air
    so right now my full overclock for the entire system benchable on ambiant air sits like this.
    cpu 3.9ghz
    bus speed 200mhz
    nb 2.8ghz (5600 MT/s)
    ht 2.6ghz
    memory 1066mhz
    4850x2 running at 700/1150
    http://service.futuremark.com/compare?3dm06=9726223
    heres my 24/7 setting
    2 hours prime 1.55v load results
    super pi 1m 4.26ghz
    3dm06
    Phenom 2 940 @ 4.1ghz Sapphire 4850x2 (single card)
    3DMark Score 22399 3DMarks
    SM 2.0 Score 8770
    SM 3.0 Score 11111
    CPU Score 5746
    http://service.futuremark.com/compare?3dm06=9779982
    3dmVantage
    3DMark Score P13954 3DMarks
    CPU Score 14051
    Graphics Score 13921
    http://service.futuremark.com/compare?3dmv=730961
    cpuz validation 4.26ghz
    http://valid.canardpc.com/show_oc.php?id=492331
    Very happy with my results
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
