Results 1 to 2 of 2
Thread: Q9300 Core Temperatures Versus CPU Temperature Readings (SpeedFan & EasyTune6)
    Jul 2007
    Question Q9300 Core Temperatures Versus CPU Temperature Readings (SpeedFan & EasyTune6)
    Hi all,
    I am a bit confused and was wondering what the difference in temperature readings I am seeing means. I am running the latest version of speedfan and EasyTune6 and I see this in one of the columns for SpeedFan.
    Temp1: 34C
    Temp2: 27C
    Temp3: -2C
    Temp: 18C
    HD0: 27C
    Core 0:53C
    Core 1:53C
    Core 2:51C
    Core 3:50C
    Ok so Core 0 - 3 are my 4 core's temperatures? but when I look at gigabyte EasyTune6 software its showing my CPU temp as 27C. Which aligns with Speedfans Temp2 reading.
    What reading is correct? Shouldn't the CPU temp be of all the cores?
    Specs:
    Gigabyte Ep45-UD3P Motherboard
    Intel Core 2 Quad Processor Q9300
    8gb PC2-8500 (DDR2-1066) OCZ Reaper Memory
    500gb Seagate SATA Hard Drive
    20x LG SATA Dvd Burner
    Soundblaster Audigy 2 ZS Sound Card
    MSI ATI Radeon HD3850 512MB
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    Try realtemp. The temps realtemp shows are most likely correct and will let you know at what to look with speedfan.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
