01-21-2009, 01:07 PM
#1
LOVE=MC²
GTX285 various mods
*** please mod at your own risk ***
before any further my cooling to vmodding recommendations
- stock cooling: step 1 + ocp mod
- better air/water/phase cooling: steps 1-3 + ocp mod
- multi phase/ln2/helium cooling: crotales vgpu/ocp + napalms steps 1-3
the following pics and mods @ evga ssc 285
10v 1500uf rubycon blackgate nx cap @ vacant C561-4
crotale vgpu/ocp mods: http://www.xtremesystems.org/forums/...d.php?t=220607
before attempting any vmod please measure your current voltage/s
measure points
- red:vgpu
- green:vmem
- courtesy:CryptiK
step #1
- for better understanding please check dengyongs post # 80 cryptiks post # 112 and # 118
- simple way to increase vgpu from 1.15v reference
- mod increments vgpu ~1.2-1.3
step #2
- for those of you that dont want to do step 1
- bridge 2 vacant from factory
- 1/2/3/11 bridged from factory
- for those of you that still want to do step 1
- for those of you not gaining much @ step 1
- for those of you that have already done step 1 and want to take it a bit further
- 1/2/3/4/11/12 bridged
step #3
- one more vgpu mod
- mod increments vgpu ~1.35-1.4+
thanks goes to
- Cryptik for all the help/confirmations
- crotale for his vgpu/ocp mods
- dengyong, andressergio and everyone else contributing @ thread
Reason: updates
01-21-2009, 01:51 PM
#2
Champion
Interesting ... Thanks for sharing !!!
01-21-2009, 02:16 PM
#3
I wonder if having an eight pin power cable in place of the 2nd six pin would help any ?
01-21-2009, 02:56 PM
#4
Thank you for sharing.
__________________
i7 920 BATCH 3838B079 4.2GHZ on 1.312v HT on, CFO off
FOXCONN BLOODRAGE
6G CORSAIR Dominator TR3X6G1600C8D
1x GTX 285 w/ heavily ported AquagraFX fc block
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
2x DDC3.2 EK tops 2x PA120.3
WESTINGHOUSE LVM-37w3
Donate to XtremeSystems
01-21-2009, 04:33 PM
#5
Outstanding, thank you for this.
Where did you get your SSC from? Newegg...Mwave...Tiger??
01-21-2009, 04:46 PM
#6
Would that make a difference ?
__________________
FOXCONN BLOODRAGE
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
01-21-2009, 04:53 PM
#7
LOVE=MC²
i got my ssc from newegg..
which gtx285 brands @ 4908 pcb ?
01-21-2009, 05:58 PM
#8
It might...never know.
01-21-2009, 05:59 PM
#9
Not sure, that might be mfg. specific. XFX and BFG have different PCB numbers? Can anyone check? It also might just be a batch number to a set of PCBs...anything is possible.
01-22-2009, 05:02 AM
#10
LOVE=MC²
evga ssc @ 1.20v
my ssc @ 1.23v
vmod @ 1.26v
no oc gain
vgpu mod does not work on the ssc until ovp is removed/increased
so if anyone could/would share that would be greatly appreciated
01-22-2009, 07:02 AM
#11
Title is Under NDA
evga ssc @ 1.20v
my ssc @ 1.23v
vmod @ 1.26v
no oc gain
I think everyone is looking for OVP for these 285/295 cards... Tough to find though. From what I gather the best way to increase Mhz is better cooling. with a 295 @ 1.26-1.3v (OVP/OCP kicks in around 1.3) on stock cooler you can get about 750-775 core. With watercooling people have been getting 800-830. I imagine once we can get our hands on some Tek5.0 slims and LN2 these babies we will see big gains in the core clocks
__________________
PURE benching, teamwork, determination, skill, dedication.
01-22-2009, 02:25 PM
#13
LOVE=MC²
deleted
01-22-2009, 03:37 PM
#14
XS-Fanb0i N-side
Don't ya cool these memory and pwn parts originally touched by the stock HS?
What did the last mod gain you in clocks?
__________________
Xtremesystems.org
i7-950 * Duniek + DT rty singlestage comin' (long wait since september ) * EVGA X58 Classified * 6Gig Corsair DomGT 2000C7 * XFX GTX 285 XXX * Intel 80Gig G2 + OCZ Vertex 30GB * Corsair HX1000 * Dimastech Easy V2.5 * Swiftech MCW60, MCP355 Dual Setup@Watercool Top, PA120.3 w/Triebwerk, EK Res250, DD 16/10 w/Feser fittings...
Athlon XP in summer 2004@12.5x261-265MHz 11-2-2-2-2.0 w/DFI Lanparty B No.1 AXP 3.25-3.3GHz+ phase cooled, 3.2GHz folding stable
No.1 HexusPifast Athlon XP: 43.92sec @12.5x263MHz 11-2-2-2-2.0 w/DFI Lanparty B
No.1 Superpi 1M Athlon XP: 30s @12.5x265MHz 11-2-2-2-2.0 w/DFI Lanparty B
01-22-2009, 04:01 PM
#15
wow, i'd be scared to kill my board with that much capacitance.
jesus.
01-22-2009, 05:23 PM
#16
this is fantastic. I can't wait to try this out on my 2 SSCs
01-22-2009, 06:28 PM
#17
wow... nice...
__________________
::: E8500@4GHz :: GTX280 :: 2x VERTEX 30GB RAID0 :: DFI JR P45-T2RSR :: 4GB Dominator 8500 :: Dell 24" :::
::: Water cooling: OCZ HF-MK1 CPU block :: Aquagrafx G200 :: Feser 240:: DDC 18W + XSPC res/top :::
::: K45 :: Celeron 430 1.8GHz :: 2GB RAM :: Samsung 750GB :::
projects: ::: “PHINIX CUBE” ::: "PHINIX nanoTOWER" :::
01-23-2009, 06:35 AM
#18
Xtreme Vmod mod
I think you would be much better using low value (~100nf) distributed capacitance in high load areas to catch spikes and high frequency noise than addling large ammounts of bulk capacitance to the outputs of the regulators, especially with the long lead lengths which it looks like you're using. Using long lead lengths will increase ESL and ESR of the capacitors and will likely negitively effect the response of the voltage regulators.
01-23-2009, 09:06 AM
#19
LOVE=MC²
yeh i agree persivore.. this was just the first recap.. more recapping to come
the capping on the back of the card ^ at first i used 4 x 6.3V 470uf blackgates
but the 4 x 10V 1500uf blackgates/results @ 1st ^ post is what made me post the mod up
im looking into tantalum/film caps aswell
there are more components in the way of this recap which are deemed to be replaced
for an sli/trisli setup id recommend 4 x high quality 10V 330uf tantalum caps @ C561-4.. if you got the space for electrolytic caps go ahead
at the moment i dont recommend the recapping of the 8x100uf.. i need to recap some more.. when i do find the better the caps/capacitance ill let you guys know.. still experimental
the memory runs fine @ 1500 naked cooled just by the airflow
having said all that im playing ETQW @ 800/1750/1500
20mhz core +
50mhz shader +
the hr03 cooler itself @ idle is only about 1 C better than the stock cooler.. @ load probably 2-3 C
01-24-2009, 04:05 AM
#20
Xtreme Guru
^nVIDIA skimping on memory vDD and vDDQ chokes. No surprise.
tsk-tsk...
But good to see they put some sense in the layout of GTX285's vGPU VRM area after the mess on GTX260/280s.
__________________
You were not supposed to see this.
01-24-2009, 09:54 AM
#21
Nice work Napalm, thanks for sharing. Those 4 x 6V-10V 1500uF blackgate caps have a huge can size for 1500uf. I suppose that's one of the benefits of using high quality audio caps. The lead length is a worry though, if you can reduce that perhaps the results will be even better. I have some Sanyo WG's and Rubycon MBZ's that may be suitable for this mod.
It's also somewhat surprising that the HR-03 is only marginally better than the stock cooler.
01-24-2009, 03:03 PM
#22
LOVE=MC²
sure as persivore stated shorter leads would benefit even more.. but space on the card is a beatch.. not only that but the ram on the mobo is in the way aswell
yeh its the nx 10v 1500uf bgs.. sounds as good as it performs on the 285
01-24-2009, 04:53 PM
#23
how much gain ? ill find out later today
waiting like a little kid @ xmas. :P
__________________
01-24-2009, 05:37 PM
#24
LOVE=MC²
lol ok ill get to it in a moment..
i was trying to get true120 copper on.. it fits!
though ill go back to hr03 after this test run
01-24-2009, 05:58 PM
#25
XS-Fanb0i N-side
Dayum... I can hear that card moan because of the weight on its shoulders (and maybe because of pimped guts that got no chance to "heal" yet  ).
__________________
Xtremesystems.org
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
