01-19-2009, 09:27 PM
#1
Seagate firmware update bricks 99.9% 500 GB 7200.11 Barracudas
As you all know, the 7200.11 series of HDDs have been failing within 4 months of usage. Seagate claims that they are aware of this issue, and has released a firmware update that was supposed to fix it. All 7200.11 Barracuda 1 TB, 750 GB, 500 GB, 320 GB drives are affected (including server counterparts).
However, the firmware update did not work initially. This afternoon, they released another update which changed the firmware upgrading utility, and some had successes flashing the 750 GB and 1 TB drives, however, 99.9% of people that flashed on the 500 GB (ST3500320AS) bricked their drives.
People with multiple 500 GB drives had all of them bricked as the tool automatically flashes all of the detected models.
This thread is known as the "thread of the bricked 500 gig cudas":
http://forums.seagate.com/stx/board/...cending&page=1
This is where all people that have bricked their 500 GB drives with this new firmware posts.
This is the original 7200.11 firmware issue thread (official, stickied):
http://forums.seagate.com/stx/board/...thread.id=4771
Tonight, Seagate decides to remove the firmware from the site.
http://seagate.custkb.com/seagate/cr...p?DocId=207951
" Note: This file has been temporarily taken offline as of Jan 19, 2008 8PM CST for validation."
A bit too late. I'm sure lucky I did not flash the firmware today. I played it smart and waited for other people to try it out first. Someone at the Seagate firmware testing center will most likely get fired soon. This is a big widespread problem.
__________________
.:: Gaming PC Specs ::.
Case: Antec Nine Hundred
CPU: Intel C2Q Q9650 @ 4.0 GHz (9x445), 1.31v (cooled by Xigmatek HDT-S1283) [IntelBurnTest{Linpack} stable]
GPU/Monitor: Visiontek HD 4870 X2 @ 800 MHz/4000 MHz +SyncMaster245BW 24"
Motherboard: ASUS P5Q Deluxe (BIOS 2005)
Memory: 8 GB (4x 2 GB) OCZ Reaper HPC DDR2 1066 @ 1069 MHz, 5-5-5-18, 1.90V
Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
PSU: OCZ GameXStream 700W
O/S: Microsoft® Windows Vista Ultimate X64 SP2
.:: HTPC Specs ::.
Case: Silverstone LCB13B-E ATX
CPU: Intel C2Q Q6600
GPU/Monitor: Gigabyte Radeon HD 4350 +Philips 42" 1080p 120Hz
Motherboard: Gigabyte GA-EP45-UD3R
Memory: 4 GB (2x 2 GB) OCZ Reaper HPC DDR2 1066
Hard Drive: 2x Western Digital Caviar Black 1 TB (RAID 1)
Sound: 7.1 surround through HDMI
PSU: OCZ ModXStream Pro 500W
01-19-2009, 09:28 PM
#2
I really don't know if I'll buy another Seagate drive after this one...
I've been satisfied, but it really sounds like they might have gone down hill since.
__________________
Q6600 g0 (lapped up to 1200 grit) @ 3.6 ghz (will be higher once a game comes out that needs the juice)
DFI LP LT X48
EVGA GTX 260 (216) FTW (what a name...)
4 gigs DDR2-800 Ballistix 4-4-4-12
Creative X-Fi XtremeGamer
500 gb Seagate + 150 gb Raptor X
Silverstone 850 watt (modular)
Vista Business 64 bit
EK Res 150 -> DDC3.2 + XSPC Rev. 3 top -> MCR320 rad (S-Flex F fans) -> Apogee GT (bowed) -> MCW30 -> MCR120 rad (Zalman F3 fan) -> MCW60 -> EK Res 150
01-19-2009, 09:31 PM
#3
Xtreme Mentor
Oh dear, more fail at Seagate. What's happened to them really and do they have like only 1 tester or something, how could they miss the firmware incompability with 500GB drive is beyond me.
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
#4
I really hope my two Seagates don't brick on me  I'm running them in Matrix RAID. I've personally had a drive brick on me, so one of the drives I'm using is from RMA.
And the bricking I experienced is, according to Seagate, a firmware issue. Well now they release a firmware that is supposed to fix that issue, but apparently it ends up breaking the 500 GB drives quicker (instantly)  .
__________________
.:: HTPC Specs ::.
01-19-2009, 09:32 PM
#5
People panic cause their drives fail.
Seagate wants to rectify this
Seagate rushes
Drives die
People scream
Hmm whose really to blame?
#6
The firmware for my drive is apparently validating. I'm not too anxious to flash it, but I'd rather not wait to have it brick on its own either. Damned if I do, damned if I don't...
__________________
DFI LANParty DK 790FX-B
Phenom II X4 940 BE (0849APMW) @ 3.6GHz (18x200) w/1.48v
-cooling: Scythe Mugen 2 + AC MX-2
BFG GeForce 8800GTX OC2
8GB PC2-6400 G.Skill @ 800MHz (1:2) 5-5-5-15 w/1.8v
Seagate 1TB 7200.11 Barracuda
Corsair HX620W
Support PC gaming. Don't pirate games.
01-19-2009, 09:33 PM
#7
Seagate rushes
Drives die
People scream
Seagate for initial testing problems. The drives already had a firmware problem at first. Refer to my previous post.
Well I wouldn't (yet) because they just pulled the firmware from the site... obviously there's a problem with it.
__________________
.:: HTPC Specs ::.
01-19-2009, 09:39 PM
#8
glad it seems the ES2 500G arent hit by this, i got 8 of them in a raid 5 on a server! (basically the enterprise edition of these drives)
i have had issues with a few segate 500G last year but the 7200.10 models, i also had 3 320G 7200.10's go bad in the span of a month, i am with some others, i dont trust segate anymore, back to WD or hitachi for me!
I think the problem with the firmware is some people flash their drive and it then become unseen in the bios or in window, or you can see the files on your drive, but you cant access them.
__________________
|Rig|Asus P5Q-E|Q9650 @4.07Ghz- Swiftech MCR320 triple rad | Yate Loon 120mm x 25mm x 3 | D-TEK FuZion v2 | Swiftech MCP655-B™ 12v | 8G 1066 Corsair Dominator) | 3x 640WD,|Asus 4890 (stock right now) | Corsair 1000 | Dell 23" 1920 x 1200 |
Originally Posted by jimmyz
This chip is gonna stop piracy like condoms prevented unwanted pregnancies and STD's.
01-19-2009, 09:41 PM
#9
Unfortunately, yes they are.
Affected ES.2 drives:
http://seagate.custkb.com/seagate/cr...p?DocId=207963
Original KB article: (Lists 7200.11's ES.2's, and some Maxtor drives as affected)
http://seagate.custkb.com/seagate/cr...p?DocId=207931
__________________
.:: HTPC Specs ::.
01-19-2009, 09:46 PM
#10
Xtreme Mentor
Seagate rushes
Drives die
People scream
Seagate for rushing. People always panic. Seagate should know better and fully test their updates.
__________________
"In today's regulatory environment, it's virtually impossible to violate rules." -- Bernard Madoff, Oct. 20, 2007
xtremespeakfreely
01-19-2009, 09:50 PM
#11
Xtremely High Voltage
Sounds strange to be "flashing" a hard drive
01-19-2009, 10:00 PM
#12
Xtreme Mentor
ES.2 is affected. Seagate has a thing online where you can enter your drive serial numbers and it will tell you if your drive needs the update. My two 250GB ES.2 drives did not need it, thank god.
__________________
Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
—Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
01-19-2009, 10:04 PM
#13
I bought a 7200.11 320 GB barracuda 16mb cache hdd
Is mine one of the susceptible to the fail in the first place?
If so is the firmware ok to update for this since only the 500 gig gets bricked?
What are the specifics of this EPIDEMIC?
01-19-2009, 10:09 PM
#14
Xtreme Cruncher
Are the 1.5Tb dieing also?
__________________
01-19-2009, 10:13 PM
#15
Guys what the heck is going on with Seagate lately? This is the second huge failure report on this forum. These are pretty bad reports we're getting.
Segate and WD are about the best there is. Something must be up. Whatever it is they need to get control of it. This is gonna start to raise panic. People get real worried whehn it comes to their data. I mean you could potentially have a mirrored array of these things and both drives could get took out if you updated them. Even tyour backup would get killed in that circumstance. This could be really bad news.
It said they removed the file for validation?!? WTH?!? Did they not validate it before they unleased this onto the world? That is a serious "oooops" if they didn't.
01-19-2009, 10:16 PM
#16
Seagate rushes
Drives die
People scream
Seagate of course.
I can't see Seagate getting any money out of me again for a very long time. The trust is just gone.
__________________
Intel Q6600 | GA-965P-DS3 | XFX 8800GTX | 2x2Gb G.Skill + 2x1Gb Crucial Ballistix | Vista Ultimate x64 | Silverstone Zeus 750w | Swiftech/D-Tek Cooling | Lian-Li v2000b
OCNZ IRC Channel : #ocnz on irc.Rizon.net
01-19-2009, 10:21 PM
#17
Reminds me of the game Lemmings for some reason. Price them cheap and watch those guinea pigs fall over into a pile of bricks.
01-19-2009, 10:43 PM
#18
Grrrrrrrrrr
WTF! What is Seagate doing?
Situation could be interesting if that firmaware update would have been distributed trough windows update.
01-19-2009, 10:49 PM
#19
I was initially relieved when I entered my serial and found I was supposedly "NOT affected" - capitalization is Seagate's.
A quick google later, and I find that my firmware, SX15, is actually affected anyway - even those it's not on the "official list". Again, not surprised considering how lazily/haphazardly Seagate has been handling this. Found a Seagate forum thread where one user was only seeing one out of his two 1TB drives, with my firmware.
Needless to say, panic is a good emotion to have right now. OTOH, I'm not really, since my 1TB Seagate is just for backup purposes. I can't imagine those who have 100% 7200.11 HD setups tho. Or the random old man who checked out at Microcenter with 5 of those drives last weekend - now I'm pitying the old fool
__________________
>> i5 750 @ 3.6Ghz | CM212Plus + P12 | P55-UD3R [BIOS F2] | 4GB G.Skill CL8 | eVGA GTX 260
.: 500, 640, 2 x 1TB WD; 1TB ST | Corsair TX750 | Lian Li PC-A70A | X-Fi | Logitech Z-2300
01-19-2009, 10:50 PM
#20
stoped using seagate since 2006.
saw samsung at friends rig, been a samsung guy ever since.
i feel sad for those who lost their data. seagate should die for this!
also look at how many oem builders could be using their drives as well.
__________________
E8400 @ 3.6 | DD Block | GTX 240
Gigabyte GA-X48-DQ6
2x 2GB Kingston DDR2 1066MHz
Samsung Spinpoint F1 1TB
HIS Radeon HD 4870 1GB
Thermaltake TP 850W
01-19-2009, 10:56 PM
#21
I am Xtreme
Damnit Seagate, WTF, I have two 500gb 7200.11's I bought in dec. I've always preferred seagate drives but after this fiasco I'd be lying if I said I'm still just as confident with them.
Luckily I haven't started migrating any data to them yet, now I'm a little paranoid about bringing them online for daily use if they are experiencing a high failure rate. I have them currently setup in a RAID1 config but how things sound I might as well be running them in RAID0.
__________________
Work Rig: Asus x58 P6T Deluxe, i7 920 20x200 1.425v HT on, BIX2/GTZ/D5
3x2048 GSkill pi Black DDR3 1600, ECS 9600GT
PCPower & Cooling Silencer 750, CM Stacker 810
Game Rig: Asus x58 P6T, i7 920 20x180 1.275v HT on, TRU120
3x2048 GSkill DDR3 1333 7-7-7-18, MSI GTX260 OCv2
PCPower & Cooling Silencer 750, CM Stacker 830
AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
2x1gb Ballistix DDR2 800, PowerColor 4850
Corsair VX450
01-19-2009, 11:06 PM
#22
Does anyone know if there has been a recall on these drives? Since there was already bad firmware and they botched the launch of a revision with bum firmware patch, shouldn't they be getting control of this by now?
01-19-2009, 11:09 PM
#23
I7 Fanboy
Ouch that hurts, first the drives fail, then the fix to prevent that bricks even more harddrives.
Goodbye Seagate, Margins on HDD's are allready rockbottom, I doubt they can afford a screw up like that, especially since people are sensitive about what hdd they trust with their data.
__________________
920 D0, EX58-UD5, 6GB Corsair 1600 7-7-7, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's. Seasonic M12 700W, Cosmos S
Loop1: Swiftech GTZ, Koolance 4870x2 FC, Laing DDC 3.2 with XSPC Res Top, Blackice GTX 360
Loop2: Mips Gigabyte x58 blocks, DDC 3.2 with EK top, pa120.1, xspc acrylic 5,25" res
Come crunch with us for the Cause at WCG, we don't bite
I deny any responsibility for hearing loss or Overspending at PC Shops.
01-19-2009, 11:17 PM
#24
Just to bring some optimism to the discussion - i have Barracuda 7200.8 250 GB(for 3 or more years) and 7200.10 500 GB (since series 10 release). No signs of failure
__________________
CPU: P4 3 Ghz Prescott D0 s478; Mobo: Asus P4P800 SE; Mem: 2x1024 MB A-Data; Video: 7300 GT; HDD: 250 Gb Seagate Barracuda 7200.8 SATA;500 Gb Seagate Barracuda 7200.11 SATA;1000 Gb Samsung SpinPoint F1 SATA
LCD: 24" Belinea 1920x1200 MVA
Lappy: Compal JFL92 T9300, 4GB DDR2, Seagate 200 GB 7200, 8600 GT 512 MB (better for gaming that main PC  , waiting for OLED laptops)
Wife's netbook: Samsung NC10 - Atom 1.6 Ghz, 1 GB DDR2, 160 GB HDD (it lasts 6h+ on battery yay, upgrade not needed anytime soon  )
Waiting for the next big thing to upgrade main/storage PC (maybe Sandy Bridge for upgrade)?
01-19-2009, 11:19 PM
#25
i notice some guys have the affected drives and still running? i would start backing up on ex-drives,dvds or whatever.
__________________
Gigabyte GA-X48-DQ6
Thermaltake TP 850W
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
