Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: LGA1366 CPU blocks
    Jan 2008
    Tilburg, Netherlands
    LGA1366 CPU blocks
    Hi all,
    As far as I know there is still no D-Tek Fuzion 1 mounting bracket available for socket 1366 or is there?
    If not, I'm thinking of buying an EK Supreme CPU block.
    - What are you thoughts about this block concerning cooling capacity?
    - Does it also use impingement?
    - Is there a substantial difference between the acetal and persplex version?
    Thanks in advance for any reaction.
    CPU: Intel Core i7 920 (4.02Ghz @ 1.35v) (3836A875)
    Mobo: Asus P6T-Deluxe (bios 1701)
    RAM: Corsair TR3X6G1600C8D (1700Mhz @ 8-8-8-24-1T)
    Videocard: Club3D HD7950 RoyalKing 3Gb
    Soundcard: Asus Xonar DGX
    HDD's: 1 x 256Gb Samsung SSD 840 Pro and 3 x 640Gb Samsung F1 Spinpoint
    PSU: Zalman 850W
    Case: Coolermaster CM690
    D-Tek Fuzion with 5,5mm nozzle | Swiftech MCP655 | Thermochill 120.2 | EK Reservoir | XSPC High Flex 7/16" ID - 10/16" OD | Scythe S-Flex SFF21F Fans
    Jun 2006
    Netherlands, the
    Duniek makes custom Fuzion v1 hold down plates
    http://www.xtremesystems.org/forums/...d.php?t=210030
    Jan 2008
    Quote Originally Posted by eltinio View Post
    Thanks, I already PM'ed with him about these brackets. But was curious how the EK would do and if it includes an 1366 mounting bracket by default.
    PSU: Zalman 850W
    Jul 2007
    Cambridge, UK
    I use a XSPC Delta V3 for 1366, works very well and cheap too
    [SIGPIC][/SIGPIC]
    Sep 2006
    North East UK
    I just made my own Delrin topped block based on the DD MPC-CPU - Still needs light sanding and polished but pretty happy the way it turned out and looking forward to seeing how it performs
    Sep 2006
    North East UK
    I love that warm fuzzy feeling you get when you complete making something and it turns out good
    Never tried to flame polish Delrin before but thought i'd give it a go and it worked
    Just need a matching NB one now
    Xtreme Mentor
    Sep 2007
    Dallas
    Looks good Coolermeister!
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Mar 2007
    Huntington Beach, CA
    Quote Originally Posted by coolmiester View Post
    This is the XS spirit of innovation that I love. Great job Coolermeister!
    MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
    CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
    GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
    Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
    2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
    Jun 2008
    Looks good, do you have any pics of the internals?
    Quote Originally Posted by Movieman View Post
    I don't care, I'm running out of popcorn waiting for the results..
    Jan 2008
    @ Coolmiester
    Looks very sweet!!!! But how is the mounting on the backside? Aren't affraid that you bent the mobo without any backplate supporting it?
    @ All
    Are the cooling capabilities of the EK Supreme comparable to the Fuzion version 1?
    PSU: Zalman 850W
    Sep 2006
    North East UK
    Oh yeah, that was just a test fit and i'll be making backing plates for CPU and NB for when i do the final fit
    You can see the making of the top here
    Its essentially an MC-Chipset block.
    Jan 2008
    How about modifying a GTZ bracket and combine it with an EK backplate for mounting the Fuzion version 1?
    PSU: Zalman 850W
    Nov 2004
    Sweden
    Quote Originally Posted by Pisklink View Post
    Thatīs exactly what iīve done. Havent mounted it yet but i think it will work just great. Using the old screws and springs from the first D-tek Fuzion mountkit.
    Maybe not the sweatest modd, but itīs cheap
    [SIGPIC]http://techsweden.org[/SIGPIC]
    Gigabyte Z87X-OC, Haswell 4770K, 8GB Team Group 2666mhz, Asus HD7970
    Jan 2008
    Well, I think it's a sweet, cheap and decent mod till an official bracket will be released. But are you also planning on using the EK backplate for mounting?
    And do you think there is still enough material on the GTZ bracket after using a dremel? How much did you remove to make it fit?
    PSU: Zalman 850W
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    lol nice mod!
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Sep 2006
    North East UK
    Given most people on XS would buy the latest block for a 1 or 2 degree decrease i'm actually quite surprised that most block manufacturers are just adapting their old blocks with a new mounting plate for i7 when i would of thought a re-design was in order to optimize the new core size
    Chasing After Diety
    Jan 2007
    i agree with you.
    But if you think of actual coverage on a waterblock, and how it was always much larger then the actual die, it still works out.
    But were seeing companies make slight tweeks in design, and one company that came out of nowhere and told us there back koolance. :P
    Its gonna take a lot to pull me off this 350.
  18. #18
    Dec 2007
    http://www.tilatech.com/xsdev3cpuaci.html
    this block is within 1c range of GTZ plus this comes with i7 mount. for 59.99 vers gtz which is 69.99+9.99 mount
    here is a review comparing it to GTZ and some others http://www.overclock3d.net/reviews.p...ock_shootout/5
    I like turtles
  19. #19
    May 2005
    POLAND/Cracow
  20. #20
    Mar 2007
    SoCal
    I pmed Duniek a few dys ago, got no response back. I'm tired of waiting, got myself GTZ with 1366 mount, MCP655+XSPC top and PA120.3, hopefully, it'll be enough for these damn heat ovens
    Sig is under construction
  21. #21
    Jun 2008
    Hanover Park, IL
    It worked REAL good!
    i7 940 + HK LT, GTX 480 SLI
    ASUS P6T DLX V2, 6gig Corsair Dominator 1600
    2XDDC 3.2 18watts, PC LRT, pure distilled+silver, TC PA120.3/TFC 120.1
    2x150gigWD RaptorX, 4x1tbWD BLK SG, 1.5tb external drives
    SB Titanium PCI-X, Logitech z2300, Triton AX PC Pro
    2xMemorex DL DVD burners-USB attached
    Samsung 225BW & 204B
    MM U2 UFO powder coat+12x120MM fans, Enermax Galaxy EVO 1250W, Windows 7 U64
  22. #22
    Xtreme Mentor
    Oct 2005
    Quote Originally Posted by anzial View Post
    Hmm.... I PMed him a few days ago, got a response, sent a payment, now just waiting! Too bad it will be an international shipment, probably slower than usual.
    But finally I will get my Fuzion V2 on my 920!!
    Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
    —Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
  23. #23
    Mar 2007
    SoCal
    What's the best way to apply TIM on i7s? I saw a post around here a while ago, can't find it again
  24. #24
    Xtreme Mentor
    Oct 2005
    I would assume if you are using a normal TIM, a dab in the center of the IHS is the best.
  25. #25
    Oct 2007
    Coolmeister, I like the block. Where'd you get your delrin, how thick is it, and how much was it? Sorry for all the questions...
