Results 1 to 19 of 19
Thread: Look ma' I bent my HR-03GT cooler!! (W/ PICS!)
    Jul 2007
    In my home.
    Thumbs up Look ma' I bent my HR-03GT cooler!! (W/ PICS!)
    Hello All,
    My problem was that I just got a new GTX285 SSC and I wanted to use my older GTS8800 512 as a PhysX card. The issue was that I had put the HR-03GT cooler along with the HR-11.
    In my MM-UFO case and my new Gigabyte mother board, the card would not fit in the bottom PCIe slot, so my options were to put the old stock cooler back on or try and make room by bending the HR-03GT heat pipes.
    Well here are the results. I just bent them slowly and checked the condition of the pipes every couple of centimeters. I will not be held responsible if you screw up your cooler!
    Here are the pics.
    I did mount an air block to divert the hot air from blowing on my GTX285.
    Let me know what you think.
    Core 2 Quad Q9650 @ 4.00Ghz 1.3375(v) F9 BIOS
    2 X 2 GB DDR2 1100 @ 1000 G.Skill PC2-8800
    2 X 500gb GB SATA 2 HD RAID 0
    Gigabyte GA-EP45-UD3P
    EVGA GTX285 SSC
    EVGA 8800GTS G92 PhysX
    My 3DMark Vantage Score 16,444
    Pics of my computer
    c[_]
    Nov 2002
    Alberta, Canada
    Works awesome, doesnt it?
    All along the watchtower the watchmen watch the eternal return.
    Jun 2007
    Winston-Salem, North Carolina
    Nice.. Did you just bend it with your hands slowly or something? Im not familiar with how strong the heatpipes are on them
    Q9650 L826A965 | 4.0Ghz 1.27v
    Gigabyte EP45-UD3P F7 Bios
    eVGA GTX 280
    CPU= D-Tek FuZion V2 / Laing D5 Basic / XSPC RX-240
    Corsair 2x2GB PC2-8500
    Corsair 1000HX
    AuzenTech X-Fi Prelude | Logitech Z-5500
    WD 250GB SE / WD 1TB Green
    Antec Nine Hundred
    Mar 2008
    Minnesota
    Nice! Any effect on temps going from standard to bent? I wouldn't think so unless the fan cooled the back side of the card enough to drop core temp.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Jun 2008
    Nice work
    Jan 2008
    Traveling through time
    Quote Originally Posted by tool_462 View Post
    hey you used to post on tom's hardware didn't you
    CPU: i5 3570k @ 4.2 Ghz
    Memory: 2x4gb Kingston HyperX @ 1600Mhz
    Graphics: Sapphire 6950 Toxic on BenQ XL2420TE
    Board: ASUS Sabertooth Z77
    Power: Corsair AX850W (70A)
    HEATware
    Currently playing: Planetside 2, Dead Space 3, Call of Juarez: Gunslinger
    May 2006
    UK
    looks great, how are you cooling the card VRM though?
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Xtreme Mentor
    Feb 2004
    The Netherlands
    wuss
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
    I am Xtreme
    Jan 2006
    Australia! :)
    I remember Andre doing this I think, back when the HR03 first came out.. think he did it with 2 of 'em & mounted it to 2 88GTXs to bench
    nicely done
    Jul 2007
    In my home.
    Quote Originally Posted by itslogz View Post
    Yeah, I just used my hands and bent slowly. The heatpipes are just copper tubes so they are realativly easy to bend. Just take your time.
    -Jason
    EVGA GTX285 SSC
    Pics of my computer
    Jul 2007
    In my home.
    None that I have noticed.
    EVGA GTX285 SSC
    Pics of my computer
    I am Xtreme
    Jan 2006
    Australia! :)
    just out of curiousity - why not a 120mm fan?
    Jul 2007
    In my home.
    I didn't have a 120 PWM handy. I am still figuring out how to O/C my physx card so right now it is at stock settings and it doesn't get too hot. also, I didn't want a lot of "warm" air blowing on my GTX285.
    -Jason
    EVGA GTX285 SSC
    Pics of my computer
    I am Xtreme
    Jan 2006
    Australia! :)
    Quote Originally Posted by Jsunn View Post
    -Jason
    ahh, ok cool
    Nov 2005
    Very skillful bending of those pipes, it looks good alongside the 285
    I did want to ask about using your 8800 for a PhysX card though. Does this provide an advantage over just enabling PhysX with the 285 only? I just enable it on my 280 when I want to play with Nvidia's demos and such, but not for any major gaming use. Is the additional card a major boost for PhysX?
    i5 750@3800
    Noctua NH-U12P/120x38mm Panaflow M1
    GSkill 4G DDR3-2000 Ripjaws
    EVGA P55 FTW 200
    EVGA GTX 480/Zalman VF3000F &
    Zotac GTX 480 AMP Edition/Zalman OEM VF3000F SLI@800/2000
    Seasonic M12D 750
    WD Caviar 500
    Coolermaster HAF 932 Black Edition
    W7 64 Pro
    Jul 2007
    In my home.
    Quote Originally Posted by Retro View Post
    The way that it works, anyone please correct me if I am wrong, but the second card will do the calculating of the physics processes while the main card does the rendering.
    In 3dMark Vantage you will get better scores withe Physx enabled on the main card, because it is often the faster card and during the test there isn't much graphically going on. In an actual physics coded game, you will see the improvement.
    -Jason
    EVGA GTX285 SSC
    Pics of my computer
    Nov 2005
    -Jason
    Thanks for the explanation. This could be quite a benefit when we see some of the new PhysX titles that are coming out.
    Speaking of benefits, how is the new 285? I saw your temp. and fan speed reports in your other thread, and the performance must be a big jump from the 8800. I think that having 1024mb of ram also makes a big difference over the 512mb in the 8800.
    i5 750@3800
    EVGA P55 FTW 200
    Seasonic M12D 750
    WD Caviar 500
    W7 64 Pro
  18. #18
    Jul 2007
    In my home.
    The performance jump is HUGE!! Far Cry is awesome with the settings at high and 4X AA. I am going to go to very high and see how it looks. I was sitting at ~60FPS!
    Also, back to the Physx question, the game has to be "coded" to use the second card as Physx or nVidia's CUDA.
    If its not the PhysX card will just sit there, no loss, it is really a win win.
    EVGA GTX285 SSC
    Pics of my computer
  19. #19
    Nov 2005
    That 285 was a good investment, I figured there would be a big jump in performance from an 8800
    I sure noticed the improvement going to a 280. And that was from a 9800GX2. I hope Nvidia gets it right this time with the 295, but I am going to stick with single-gpu cards regardless. I will enjoy it even more once I finally get that HR-03GTX project finished
    It will be interesting to see what the game developers come out with for PhysX then.
    I don't know if this list has any of the specially coded upcoming games on it yet, but there are a lot of titles, both past and present.
    http://www.nzone.com/object/nzone_physxgames_home.html
    i5 750@3800
    EVGA P55 FTW 200
    Seasonic M12D 750
    WD Caviar 500
    W7 64 Pro
