My Phenom II 940 - First Encounter
Well this weekend I've been playing with my new toy, and I,ve lots of doubts and questions. I'm with stock cooler (saving money to get my xigmatek s-1284) so I've not pushed the chip so much.
At stock volts(1,350V) my chip reaches 3,3Ghz NB 2.0 Ht 1.8.
It only needs +0,25V (1,375V) to be stable at 3,4Ghz Nb 2.2 Ht 1.8
And now start the probelms, to get 3,5 stable I need 1,45V...and temperatures are 50Cº in full load..so after 30 minutes in prime 95 it crashes.
Wonder if with the new cooler and less heat I will be able to get more clocks with less voltage, I can't push the chip more with the stock cooler, sure I'd take 3,6 at 1,5V but I prefer to wait.
I am overclocking by bios since AOD says that my cpu is unknown...Im in vista 64, my board is Gigabyte 790gp and the bios Fo3
Other little problem is than super pi crashes everytime I start it, even at stock clocks (using mod 1,5)
I can't set the Northbridge above than 2,3, don't know what i'm doing wrong.
Well some pictures:
Vantage 3.0Ghz Radeon 4870 512Mb 830/950
Vantage 3,4Ghz Radeon 4870 512Mb 830/950
3d06 3.0Ghz Radeon 4870 512Mb 830/950
3d06 3,4Ghz Radeon 4870 512 Mb 830/950
Farcry 2 Run at 3,0Ghz Radeon 4870 512Mb 830/950 1280x1024 Ultrahigh settings
- You may not post replies
- You may not edit your posts
Forum Rules
