Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 102
Thread: RV870 single-core, R870 dual-core, R800 quad-core?
    Xtreme Mentor
    Jun 2008
    France - Bx
    From the well-informed site from North : Nordic Hardware
    The story of a dual-die GPU from AMD/ATI has been circulating since way before the launch of R700, Radeon HD 4870X2. While it did allow many to dream, it turned out to be just a rumor, or maybe it was just to soon? Either way a source has hinted that the new card R870 will be two GPU dies glued together sharing a memory bus. This is pretty much the exact same that was said before the R700 launch, and while we can't confirm this, similar information has been posted over at Chiphell.
    Both are basically saying that AMD has glued two RV870 GPUs together to build world's first dual-die GPU, which is kind of amusing considering AMD's bashing of Intel's dual-die solutions. Anyhow, this means that AMD would then be able to build what many would come to call quad-fire on a stick. Four GPU dies on the same card, R800. It also means that for the first time we will have a middle between the RVx70 and Rx00.
    Specification wise this would land us on something like 1000-1200 shaders and 50-60 TMUs with RV870, 2000-2400 shaders and 100-120 TMUs with R870, and 4000-4800 shaders and 200-240 TMUs with R800. In theory (IN THEORY!), AMD could launch them as Radeon HD 5870, Radeon HD 5870 X2 and Radeon HD 5870 X4.
    There isn't a salt mine big enough take with this, but we just wanted to notify you that the rumor has resurfaced. Beware.
    Source
    Good newz,
    W&S
    Xtremely Hot Sauce
    Sep 2007
    New York
    If it's true, I'd like to see how CrossFireX scales, and if it'll support 8 GPUs (such as dual-HD5870X2, quad-HD4870X2). Other than that, I'm curious to the packaging, and I assume there'll still be a secondary chip to handle GPU-to-GPU communication. My only other question is how will memory be split? Will both have access to the full amount? Or will access be limited, such as current 2x1GB cards?
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Xtreme Cruncher
    Aug 2006
    Denmark
    Uhmm...no, no and no for the nTh time.
    Its pretty bad to make random forum posts into news. Do I even have to mention the 900 shaders in RV770 "news" that was from XS speculation/random fun. (That person actually believes the 900SP RV790 we madeup here at XS).
    It would also mean you would need 4GB memory on a "quadcore" to have 1GB.
    In fact everyone thinks that R800 is the adoption of two dual-core RV870 the glue, I suddenly thought of AMD can make RV870 have the 1000-1200 stream processor 40NM ultra-small core, defined as the RV870, and the two high-level RV870 glue, causing R870, in fact, if two of the 1000 SP glue together RV870 will not vary much from the area, and can be shared memory, when a single card to sell ... ..., while the R800 is the R870 the two versions of X2 is, in fact, has four RV870 the RV870X4 ... ... every two RV870 composed of a memory can be shared R870, R870 with two similar R700 via the Internet to form the first internal CF ... ...
    Hahaha, what a bunch of FUD. Its utter homemade crap. And the poster basicly try to shoehorn it in as people ask questions. 100% homemade!
    Suddenly have the feeling ... ... RV870 is two 40NM glue version of the RV790 ... ...
    RV770 800SP 55NM ——> RV790 1000SP 55NM ——> RV870 (40NM RV790X2) 1000X2=2000SP RV770 800SP 55NM -> RV790 1000SP 55NM -> RV870 (40NM RV790X2) 1000X2 = 2000SP
    March-April release RV790 If 900SP, the performance of most high RV770 15% -20%, right?
    Not sure why nordichardware pulls of such a dumb stunt. Even tho Andreas write alot of salt and theory. This just belongs nowhere.
    Crunching for Comrades and the Common good of the People.
    Aug 2005
    Germany
    so a single gpu card is like the low end... if they don't fix microstuttering & co i really hope this won't happen anytime soon.
    1. Asus P5Q-E / Intel Core 2 Quad Q9550 @~3612 MHz (8,5x425) / 2x2GB OCZ Platinum XTC (PC2-8000U, CL5) / EVGA GeForce GTX 570 / Crucial M4 128GB, WD Caviar Blue 640GB, WD Caviar SE16 320GB, WD Caviar SE 160GB / be quiet! Dark Power Pro P7 550W / Thermaltake Tsunami VA3000BWA / LG L227WT / Teufel Concept E Magnum 5.1 // SysProfile
    2. Asus A8N-SLI / AMD Athlon 64 4000+ @~2640 MHz (12x220) / 1024 MB Corsair CMX TwinX 3200C2, 2.5-3-3-6 1T / Club3D GeForce 7800GT @463/1120 MHz / Crucial M4 64GB, Hitachi Deskstar 40GB / be quiet! Blackline P5 470W
    Xtreme Mentor
    Apr 2005
    I like this part of the article:
    "There isn't a salt mine big enough take with this, but we just wanted to notify you that the rumor has resurfaced. Beware. "
    Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    Well dual-die single sub would be easier to fab than trying to make a native dual-die (how would that work for GPUs, given theres hundreds of "cores" as it is?!, but thermal dissipation density could be horrible.
    you sigged that?
    why?
    ______
    Dec 2008
    be awesome if it was true but i don't believe it at all
    and if it does turn out to be true i'll be like AW SH*T WHYD I GET THIS GTX 200 CARD
    I am Xtreme
    Oct 2004
    U.S.A.
    bah ATI can't get their drivers right.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    Feb 2008
    London Ontario Canada
    it took how many years for nvidia to get sli multi monitors to work no one is perfect stop while your ahead
    Case: Corsair 400R
    PSU: Corsair HX1000W
    mobo: Maximus IV Gene
    CPU: 2500K @ 4.2ghz 1.19 volts
    RAM: Gskill Ripjaws 1866mhz 2 x 4 gigs
    OS Drive: Kingston Hyper X ssd 120 gig
    Graphics: XFX HD5850
    Cooling: Corsair H100
    OS: Windows 7 Pro 64 bit
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Quote Originally Posted by safan80 View Post
    CF drivers? Never.
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
    Xtreme Guru
    Dec 2002
    deja vu: RV770 single-core, R770 dual-core, R700 quad-core
    R7xx was meant the same..
    will it happen?.. eventually.. R8xx aint no guarantee
    its about time cf/cfx moves @ die
    I am Xtreme
    Oct 2004
    U.S.A.
    Quote Originally Posted by STaRGaZeR View Post
    CF drivers? Never.
    and opengl drivers
    c[_]
    Nov 2002
    Alberta, Canada
    All along the watchtower the watchmen watch the eternal return.
    Nov 2005
    Quote Originally Posted by Shintai View Post
    Shared bus by dual-cores. Need 2GB memory on a "quadcore" to have 1GB.
    And AMD is only a CPU manufactor due to stolen technology and making clones.
    Xtreme Guru
    Dec 2002
    @ stevil
    nice.. but still micro stuttering
    if cf/cfx moved @ die.. maybe just maybe ms be gone
    Apr 2008
    Lansing, MI / London / Stinkaypore
    Considering that IF RV790 exists as a 40nm part it will be a hell of a scaling up with 1200+ SPs already...
    Why would RV870 take so much hassle in scaling instead? Make a 790-ish sized part (250-300mm^2), X2 it, no big worries.
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Banned
    Oct 2006
    very interesting pic.......
  18. #18
    Jun 2008
    Quote Originally Posted by STEvil View Post
    a very skilled photoshopper....right?
  19. #19
    Mar 2008
    川崎市
    @stevil, cooling that would be a nightmare.
    I don't believe amd will make a dual core gpu anytime soon, why would they? I think it's more likely that they will just scale everything of the current gpu's up a bit.
  20. #20
    Dec 2007
    Multiple dies on graphics cards are starting to sound like the rumours surrounding an integrated large ammount of EDRAM in ATI's GPUs a few years ago. Ever since the 9700 Pro came out there were rumours about ATI's next GPU with 10MB EDRAM. That proved too complicated for the "mess" that is the PC platform but eventually it came out in a console and was quite successfull.
    My guess is that two GPUs sharing the same memory pool could be too dificult to get into a PC, but could very well be in the next XBox or Playstation (I won't say Nintendo because they're obviously not aiming for the "best tech" battle).
  21. #21
    I am Xtreme
    Oct 2004
    U.S.A.
    Quote Originally Posted by NapalmV5 View Post
    @ stevil
    for the Nth time the 4870x2 has no micro stuttering.
  22. #22
    Apr 2008
    4 chips (3 frames in queue) would give you LESS possible stuttering than 2, actually.
    See Rage3D's investigations on it.
  23. #23
    Xtreme Guru
    Dec 2002
    ^ you mean 4 cores..
  24. #24
    Xtreme Guru
    Dec 2002
    then wth am i doing @ single gpu cards..
  25. #25
    Xtreme Cruncher
    Aug 2006
    Denmark
    Photoshop ftw! And the extra blur is a nice touch
    Here is another bunch of photoshops.
    Quote Originally Posted by v_rr View Post
    Ye and those 100-200GB/sec external busses is lovely too and 512bit MCs.
