Hi all, who help me with this program? I downloaded it yeasterday, but i dont know, how use it and where this folder copy?readme is in japanese.
Worked it only on AMD chipsets or too on Nvidia chipset?Thanks all
ROG Power PCs - Intel and AMD
Its simple: unpack into any folder anywhere.
start the program, use the second tab (p-states) to adjust voltages and clocks
hit accept, then ok.
start cpu-z and look whether it works. if it doesnt, check if energysaving-settings in windows are right for cnq...
if everything is ok, make a shortcut.
edit the shortcut to start the program with the switches "-loadpstate -nowindow"
put the shortcut into autostart
voila there you go
i waited LONG for such a program for K10. I could have used my 9750 with a higher overclock.. but whatever, better late then never.
whether it works on nV chipset: dunno.. try it out![]()
1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
wow thats a really nice program. so it has the effects of cool and quiet without even turning cool and quiet on? also i see for phenom I it only allows for 2 different power states. i know phenom I only has 2 power states but can you add more?
no cnq must be on.. but you can alter the p-states and even nb-multi/volts in windows and load them on bootup.
now i can undervolt/oc WITH CNQ ON!! like in those good old crystalcpuid days... AND BRING IDLE POWER DOWN! Only 142w left for my machineand its even better then crystalcpuid/rmclock, because it just alters the p-states entrys in the msr and then quits. no additional running prog in the background...
but i think you cannot add additional p-states...
i have cool and quiet off but i can still set power states and use them.
oh even better![]()
Thanks, today il try it
great find!! but not much info available on this program.
i saw in google that this is possible also:
K10STAT.exe -loadprofile:1 -nowindow
and these commands can be used:
-enabletlbcache
-disabletlbcache
not sure about these i saw:
-unlimit
-enable309
-disable309
dont know if 309 belongs to the command.
amd 940 @ 3.5ghz stock voltage or 3.7ghz 1,425v home made cpu block 3616 mhz and 2210mhz nb stable
gigabyte ga-ma790fx-dq6
sapphire hd4870 1gb @ 160-200 in idle , 750-950 load, with 2 rivatuner power profiles shortcuts.
2x 2GB OCZ Blade 8500 ddr2 1066 @ 1.85 volt
seagate barracuda 7200-11 1x500gb & 1x640gb (rip 1 500gb barracuda)
seagate barracuda 7200-12 1TB , very nice hd, 5 degree colder then the 640gb
windows xp 32
lian li pc-a70b
cooler master real power 850watt
interesting...
or here http://www.geocities.com/k10stat/
running my phenom now 400mhz idle.
but some documentation would be greatly appriciated because yesterday suddenly i was running 162mhz fsb. and i dont know how i did it.
edit: its everest giving wrong values when using k10stat.
and downclocking doesnt give much extra savings, perhaps imc or cache is still taking alot of power.
the 5000be took waaay less at 1.1ghz then the 940 at 4x100mhz.
windows xp 32
lian li pc-a70b
Hm its ok, but OC up is only with open CPU multiplier...
x3 8650 next OC up is unreal on this board
yes i did. below 0.75 volt it just crashes. my amd 5000 was at 0.8.
i have seen screens where they set 0.65 for phenoms with k10stat, so probably my board doesnt allow it or crashes at this setting.
windows xp 32
lian li pc-a70b
new version of k10stat is out.
seems to have more functions towards cnq or has its own clock control.
windows xp 32
lian li pc-a70b
lots of changes but i can't get their own cnq thing to work. when my cpu is at 0% usage it doesn't change and it doesn't go up on load. i have had it randomly switch itself around a few times tho. would i need to have cnq on for this to work properly?
Particle's First Rule of Online Technical Discussion:
As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
Rule 1A:
Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
Rule 2:
When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
Rule 2A:
When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
yes i just got it to work.
you must turn of cnq in windows. with powerprofile is enough.
create a shortcut to k10stat with this in the commandline -clkctrl:1
now its on
but k10stat must remain running to make use of its autoclocking.
windows xp 32
lian li pc-a70b
hmmm trying to load the second profile from K10stat I renamed "ocslight" on startup.
however I cannot get the switches to work..
I tried variations like:
-loadprofile:2 -nowindow
-loadprofile:ocslight -nowindow
-loadpstate:2 -nowindow
-loadpstate:ocslight -nowindow
checking in CPU-z but no result..
powersetings in vista as balanced... anyone any idea to get it to load a specific profile?
940BE - GB MA790GP-DS4H - 4x1gb OCZSR1066gk's
Current:
24/7 Torrent & Internet Box: 0.975V -0.800V. Brisbane @2Ghz w. CrystalnQ // Biostar TA690G // 2x 1Gb Geil 800@4-4-4 // IDE DVDRW // 250Gb WD S16 Sata // Coolermaster iGreen 500W & 2x 120mm Antec case fans.
Main PC: 3Ghz BE 5000+ @1.45Vcore 273x11 // Asus M32R2-MVP // eVGA 8800GTS SC 320mb // 4x 1GB DDR1066 OCZ D9GKX // several HDDs & optical // Soprano DX & Zalman cnps9500nt // FSP FX700-GLN // Acer AL2216Wbd 22"
My 6600GT AGP Ghetto PrescottCooler Mod
old Main rig:
Desktop Barton 2600+ @202x11 with Lapped CM Jet7 - GA-7NNXP - 2x512MB 2.5-3-3-11 Value Kingstons - PNY 6600GT AGP @ 605/1135 - 3x120GB & 1x200GB HDDs (WDC/Maxtor/Seagate) - 2xopticals burners (DVD R/RW 8-4-32 +/- Liteons) - iBest "crap" 600Watt Dual fan - Logitech MX Cordless Duo - Logitec Quickcam Orbit
Very old Server:
Intel P4 willamette 1.4Ghz - 2x128MB & 2x64MB PC800 RDRAM - Intel D850GB Mobo - 10GB & 80GB seagate HDD's - jetway 9600SE - Win2003 Server
did you enter it like on the picture and if you start the k10stat.exe, does it show all the profiles you applied?
i just tried with k10stat91 and renaming and starting a profile doesnt work.
i renamed profile 2 to test and -loadprofile:2 -nowindow did seem to start profile 2.
windows xp 32
lian li pc-a70b
tnx, I took the easy way out and swapped the profile I wanted to 1. then it did load.
hopefully the creator of k10stat wll provide more documentation and versions![]()
Current:
old Main rig:
Very old Server:
Anyone else having problems with k10stat not applying at boot? Tried it via a shortcut and via the registry, but the altered p-states do not get applied. When running the exact same shorcut/cmdline after boot, the p-states do register.. This is on WinXP SP3 btw. Does the amd driver need to be initialised or something?
