EVGA is an award-winning company[1][2] that primarily produces NVIDIA based
consumer computer hardware.[3] Founded in July of 1999, it is currently
headquartered in Brea, California.
EVGA GTX 85
Stream Processors 240
Bus .................512bit
samsung GDDR3 0.8ns
ROP....................32
GLFOPS................
Vram..................1GB
pixel Fillrate........ 20.7
Bandwidth........... 159
Texture Fill.......... 47.4
PCI-Express 2.0
Core clock......... 648MHz
Memory clock....... 1242MHz (2484MHz effective)
Shader clock........1476MHz
- 2nd generation Nvidia® Unified Architecture
- Full Microsoft® DirectX 10
- Nvidia® 2-way and 3-way SLI Ready
- Nvidia® Pure video™ HD Technology
- Nvidia® PhysX Ready
- Nvidia® CUDA technology
- PCI Express® 2.0 Support
Interface
- HDTV
- DVI-I
- DVI-I
_____________________________________________
Hardware:
- Motherboard: Asus Rampage extreme intel X48
- Processor: Intel C2D E8600@ 4.02GHz
- Ram: Cellshock blue PC1500 1866MHz @ 1600MHz (7-7-7-14) 1T
- Videocard: EVGA GTX 285
- soundcard: Creative X-FI Titanium PCI-EX
- PSU: Corsair HX1000W
- Cooling: Watercooling
as you can see the 285 is a little bit different of 280, with the evga version
the back actually is uncovered, unlike the 280, this for me was a surprise.
and explains too the price tag diference beetween 280 and 285.
this card needs both a 6-pin and 6-pin power connector, unlike the 280 that demands 6-pin and 8-pin power conector
Nvidia really scores in the cooling department, 36ºc idle for such a hughe
chip like GT200 even being 55nm, because this chip doesn't seem to suffer a size drop from de 65nm version
GTX285 PCB, CHIP COOLER
CRYSIS
Windows Xp 32bits
DirectX 9
GTX 280
602MHz // 2214MHz // 1296MHz at 1900x1200
- Minim : 33.47 FPS
- Maximo: 53.9 FPS
- Avergae: 44FPS
GTX 285
648MHz // 2484MHz // 1476MHz at 1900x1200
- minim: 36.29 FPS
- Maximo: 59.21 FPS
- Average: 47.94 FPS
GRAND THIEF AUTO IV
Windows Xp 32bits
DirectX 9
GTX 280
- Average FPS: 50.95
- Duration: 37.09 sec
- CPU Usage: 91%
- System memory usage: 57%
- Video memory usage: 97%
- Video Mode: 1920 x 1200 (60 Hz)
- Texture Quality: High
- Render Quality: High
- View Distance: 29
- Detail Distance: 100
GTX 285
- Average FPS: 54.24
- Duration: 37.13 sec
- CPU Usage: 79%
- System memory usage: 56%
- Graphics Settings
- View Distance: 29
*Both cards at default clocks
CRYSIS WARHEAD
Windows Xp 32bits
DirectX 9
GTX 280
*Minim : 26.77 FPS
*Maximo: 33.06 FPS
*Average: 26.92 FPS
GTX 285
*Minim: 20.93FPS
*Maximo: 35.84 FPS
*Average: 29.35 FPS
3DMARK06
i've step both cards at same Clocks 621MHz // 2270MHz // 1357MHz, same bios config (voltages, frequencies) and runned at very same conditions, and the results are:
EVGA GTX280: 17038 marks
EVGA GTX285: 17477 marks
as you can see, and i can't explain why but cpu score more 71 marks
and the total diference: 439
i'll try this test later but overclocking GPU & CPU, to make sure
that this scores are real.
Overclocking:
