Results 1 to 18 of 18
Thread: BloodRage: Where is the FrontPanel Audio Header?
Threaded View
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Several people already contacted me and said they cant find the IFPA or Intel Front Panel Audio header on their BloodRage board, to connect the front panel of their case to the board so they can plug in speakers or headsets on the front of the case and dont have to work their way to the back of the board.
    Well, the reason you are having difficulty finding it on the board is because it doesnt exist...
    Its on the Sonar X-Fi Soundcard
    Note: There are two types of Front Panel Audio Connectors, the older AC97 connector and the newer Intel HD Audio connector.
    They use different pinouts and are not compatible! All recent cases should have an IFPA or Intel HD Audio Front Panel header.
    AC-97 Front Panel Audio
    1. MIC
    2. AUD_GND
    3. MIC_BIAS
    4. AUD_GND
    5. FP_OUT_R
    6. FP_RETURN_R
    7. AUD_5V
    8. KEY
    9. FP_OUT_L
    10. FP_RETURN_L
    Intel HD Front Panel Audio
    1. PORT 1L
    2. GND
    3. PORT 1R
    4. PRESENCE#
    5. PORT 2R
    6. SENSE1_RETURN
    7. SENSE_SEND
    8. KEY
    9. PORT 2L
    10. SENSE2_RETURN
