XtremeSystems Forums
Go Back   XtremeSystems Forums > Official Manufacturer Information & Support > Foxconn - Quantum Force > Compatibility Lists
Reply
Old 12-31-2008, 02:52 PM   #1
BenchZowner
One-Eyed Killing Machine
BenchZowner's Avatar
Send a message via ICQ to BenchZowner Send a message via AIM to BenchZowner Send a message via MSN to BenchZowner Send a message via Skype™ to BenchZowner
BloodRage RAM Compatibility List
Let's try to build a RAM ( Memory ) compatibility list for the Foxconn BloodRage
I've personally tested the following memory kits on the BloodRage with the G13 BIOS and had no issues at all:
Compatible ( Working Fine )
CellShock DDR3-1800 8-7-6-21 2GB Dual Channel Kit ( CS3222580 ) - SPD Tool v0.63 dump file - Thaiphoon Burner 6 dump file
SuperTalent DDR3-1866 C8 2GB Dual Channel Kit ( W1866UX2G8 ) - SPD Tool v0.63 dump file - Thaiphoon Burner 6 dump file
CSX Diablo DDR3-2000 2GB Dual Channel Kit ( DIABLO3-2000-2GB-KIT ) - SPD Tool v0.63 dump file - Thaiphoon Burner 6 dump file
A-Data Vitesta Extreme Edition DDR3-1333+ 3GB Triple Channel Kit ( AD31333E001GMU ) - SPDtool v0.63 dump file - Thaiphoon Burner 6 dump file
Corsair Dominator DDR3-1800 C7 2GB Dual Channel Kit ( TWIN3X2048-1800C7DF )
Corsair Dominator DDR3-1600 6GB Triple Channel Kit ( TR3X3G1600C8D )
Corsair Dominator DDR3-2000 C7 6GB Tripple Channel Kit ( ? )
Corsair Dominator DDR3-2000 C7 3GB Tripple Channel Kit ( ? )
Corsair DDR3-1866 C9 6GB Tripple Channel Kit ( TR3X6G1866C9D )
SuperTalent DDR3-1600 C7 2GB Dual Channel Kit ( W1600UX2G7 )
G.Skill DDR3-1600 6GB Triple Channel Kit ( F3-12800CL9T-6GBNQ )
OCZ DDR3-1600 Platinum Edition 3GB Triple Channel Kit ( OCZ3P1600LV3GK )
OCZ DDR3-1800 Platinum Edition 2GB Dual Channel Kit ( OCZ3P18002GK )
Mushkin DDR3-1600 6GB Triple Channel Kit ( 998679 )
I will upload their SPD dumps on my FTP and link them here so you can try them out if you're having compatibility issues with your sticks.
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
BenchZowner is online now   Reply With Quote
Old 01-02-2009, 11:05 PM   #2
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
sweet! thanks a lot bill!
im heading for the office now and will work on BloodRage and Destroyer compatibility lists and some other stuff
I finally got a new 3G modem, this time one that WORKS :P
in case anybody from asia reads this, stay away from china telecom 3G!!! they may have the most antennas, but the speed and reliability is terrible :P
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 01-09-2009, 11:51 PM   #3
Touge180SX
Touge180SX's Avatar
I'll add to the list Bench!
Corsair Dominator 6GB (3x2GB) DDR3 1600 (PC3 12800) TR3X6G1600C8D works and is rock solid! At 1.64V VDIMM 2100Mhz fully Memtest86+ stable!
__________________
Core i7 920 D0 @ 4833.55Mhz~EVGA "Classified" E760~XFX HD5870~6GB G.Skill Perfect Storm DDR3 2000~Corsair HX1000~2x WD Velociraptor 150GB RAID 0~WD Cavier Black 1TB~Custom Danger Den Water Box Plus~Windows 7 x64 RTM~Dell 2407WFP
H20!
CPU Loop: MCP-655~Swiftech MCR-220~HEATKILLERŽ 3.0 LT
GPU Loop: MCP-655~XSPC RS240~EK FC5870 Plexi+Nickel
Touge180SX is offline   Reply With Quote
Old 01-17-2009, 04:01 AM   #4
EnisDonKing
Tested with BloodRage:
G.Skill 6GB (3x2GB) DDR3-1600 (PC3-12800) || (F3-12800CL9T-6GBNQ) || CL 9-9-9-24 @ 1.6V
With P03 BIOS I was able to select XMP profile for those modules.
EnisDonKing is offline   Reply With Quote
Old 01-17-2009, 04:45 AM   #5
BenchZowner
List updated.
Gonna upload some of the SPDs later on.
__________________
Old 01-17-2009, 09:44 AM   #6
ICEEXOL
Kingston DDR3-1066 2 x 1 GB kit CL7 (KVR1066D3N7K2/2G) works fine.
ICEEXOL is offline   Reply With Quote
Old 01-17-2009, 12:28 PM   #7
s002wjh
anyone try the ocz platinum series?
s002wjh is offline   Reply With Quote
Old 01-17-2009, 12:52 PM   #8
JudgmentJay
JudgmentJay's Avatar
Also interested in this, but if noone knows I suppose I'll be able to answer on Tuesday or Wednesday.
EDIT: Make that Thursday! PSU DoA
JudgmentJay is offline   Reply With Quote
Old 01-22-2009, 11:57 PM   #9
JudgmentJay
3x1gb OCZ Platinum working fine @ 1600mhz 7-7-7-24.
Old 01-23-2009, 03:20 AM   #10
BenchZowner
Can you post the exact model number for your kit ? ( it's something like OCZ3blahblah )
__________________
Old 01-23-2009, 07:31 AM   #11
JudgmentJay
My bad, it's OCZ3P1600LV3GK.
__________________
Antec 1200
Foxconn Bloodrage
i7 920 @ 4.0ghz
3x2gb OCZ Platinum @ 1600mhz 8-7-7-20
2x GTX285 SLI
X-Fi Ti | Klipsch Pro Media 2.1
Dell 24" 2407WFP
Windows7 x64 RTM
Old 01-23-2009, 07:32 AM   #12
BenchZowner
Updated.
I'll upload some SPDs in a bit
__________________
Old 01-26-2009, 06:24 PM   #13
INFRNL
I am Addicted!
when are we going to get an update. I should be testing some Supertalent 6gb 1600 cl9 and Mushkin 6gb 1600 cl7; hopefully this weekend after ram gets in. not sure if anyone has already confirmed either of these yet
INFRNL is offline   Reply With Quote
Old 01-31-2009, 08:07 PM   #14
Telo
You can add OCZ DDR3-1800 Platinum 2GB Dual Channel kit [OCZ3P18002GK].
Currently running it at DDR3-1600 8-8-8-24 on 1.60v [testing while Dominator GT comest out]
__________________
Ol' Faithful
- Foxconn BlackOps - BIOS G27/G30 [watercooled via the stock NB block; air cooling for the VR HS]
- Intel E8500 Q809A655 [VID 1.1750v] @ 4,275MHz [475x9 @ 1.32v; Watercooled by D-Tek Fuzion v1]
Testing out an E8600 at the moment
- G.Skill F3-1600CL9D-4GBGT1 4GB Kit @ 1900Mhz 8-8-8-21-2T on 1.87v
- WD RaprtorX 150GB Windows 7 32bit
- WD Velociraptor 300GB Windows 7 64bit
- Seagate Barracuda 1.5TB SATA 5900 RPM 32MB
- LG 8164B DVD-ROM [Rawdump capable]
- Sapphire HD4870 1GB
- BFG Ageia Physx
- ULTRA X3 ULT40064 1000w PSU
- CoolerMaster Cosmos RC-1000
- Samsung 2343BWX
System in the works:
- Foxconn BloodRage
- Intel Core i7 920
- 6GB Mushkin RedLine DDR3-2000
- WD RaptorX 150GB
- Seagate 1.5TB
- CoolerMaster 1000w
- CoolerMaster Stacker 830 Black
- Gateway XHD3000 30"
Telo is online now   Reply With Quote
Old 02-02-2009, 02:57 AM   #15
dreagnon
I had some problems with the 6GB Kit of :
OCZ Intel Extreme OCZ3X1600LV6GK
it always stops at Post code 26.
Afterwards I installed the Dominator Kit and it works fine with the same settings
dreagnon is offline   Reply With Quote
Old 02-06-2009, 02:43 AM   #16
saaya
Xtreme X.I.P.
saaya's Avatar
couldnt find either of those kits here... ill check again...
Hmmm even with one stick installed?
thats an older kit so maybe it needs high vdimm...
What BIOS are you on?
Can you try G16 and enable virtual XMP and set the speed to DDR3 1333 and then switch the memory to the OCZ kit?
__________________
Old 02-06-2009, 02:57 AM   #17
BenchZowner
If you guys could upload SPD dumps of your RAM with SPDtool v0.63 and Thaiphoon Burner v6,0,3,0 Build 0116 Final it would be great.
Clicking on the application name starts the download from my server.
I'll post instructions on how to read the SPD and save them as a file later on.
__________________
Old 02-06-2009, 03:08 AM   #18
BenchZowner
To upload your SPD dumps use the following info:
1) Use your RAM's product code as a filename for the dumps
2) Upload them to my FTP using the following info:
ftp server address: ftp.benchzone.com
port: 21
account type: normal
username: spd@benchzone.com
password: spd
You can use a FTP client like FileZilla to upload the files to the FTP.
__________________
Old 02-07-2009, 08:11 AM   #19
BenchZowner
I uploaded some SPDs and updated the first post
__________________
Old 02-08-2009, 05:52 AM   #20
VVJ
VVJ's Avatar
BenchZowner, cool thread! Thanks for your efforts! I can provide a free license for the latest Thaiphoon!
__________________
-All Units, this is Eagle 6. Return to base, over?
-Roger that. Heading to home.
VVJ is offline   Reply With Quote
Old 02-08-2009, 08:39 AM   #21
BenchZowner
That would be greatly appreciated ( and useful )
__________________
Old 02-08-2009, 08:52 AM   #22
systemviper
Phazers on Stun
systemviper's Avatar
Send a message via Yahoo to systemviper
I'll be firing up my Bloodrage this week, i'll test Cellshock 1866' 3x1G but it's old style DDR3 plus i am getting Mushkin 3x2G 1600 cas 7set.
__________________
HEAT
systemviper is offline   Reply With Quote
Old 02-09-2009, 05:40 AM   #23
saaya
Xtreme X.I.P.
saaya's Avatar
cool, thanks a lot man!
looking forward to your results!
__________________
Old 02-09-2009, 09:42 AM   #24
VVJ
VVJ's Avatar
Everybody, who needs a free license just PM me your registration key from Thaiphoon Burner so that I could generate the activation key. Thanks for choosing Thaiphoon Burner!
__________________
Old 02-09-2009, 06:22 PM   #25
RayderR6
I have had no problems with the OCZ 6GB kit (OCZ3P1600LV6GK), manual setting needed. Stock timings with 1T all day from 1066-1600. No problems with 7-7-7-20-1T in the same range. I have yet to pull off any 6 CAS even at 1066, maybe someone better than I could find the magic timings. I have not had the time to play above 1600 yet, but I will.
P03 and G13 confirmed. The 3Gig is already up, but nothing like being sure.
RayderR6 is offline   Reply With Quote
Reply
Tags
bloodrage, bloodrage compatibility, list, memory, ram
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
