Hey Guys,
Heres a list of CPU Heatsink/Waterblock/Extreme Cooling solutions that are known to fit on BloodRage.
Since one of its unique features are the 775 mounting holes, there are two lists, one for 775 and one for 1366 Solutions
Note: 775 PushPin Heatsinks like the Intel Stock Heatsinks are NOT officially supported... you might be able to fit them but since the 1366 cpu socket is higher/thicker than the 775 cpu socket, the PushPins will either not mount safely and pop out again, or you will bend and possibly damage the pcb. On some Heatsinks the PushPins are longer and more flexible
High end Heatsinks and other Cooling solutions cost quite some money, and they are usually mounted with backplates, so the hight of the cpu socket doesnt matter for them. Thats why we added the 775 mounting holes so you guys wont have to spend extra money on a new and expensive 1366 Heatsink or a 1366 retention kit upgrade, you dont have the hassle to search for one and dont have to wait for it to arrive. Not to mention that there are great 775 Cooling Solutions out there that unfortunately dont have 1366 bracket upgrades available.
Known to work 775 solutions:
Arctic Cooling Freezer Xtreme
Asus Silent Knight II
Coolermaster Gemini II
Coolermaster Hyper TX2 (pushpins but fits fine)
Coolermaster V8
Coolermaster Z600
Coolink Silentator
Noctua NH-U12P
Noctua NHC 12P
Duniek cu/alu cpu tube
EK Supreme Waterblock
Fuzion V1 Waterblock
KingPin F1 POT
KingPin F1EE POT
Kingblock POT by AlexTa
Koolance CPU-340 Waterblock
Koolance CPU-345AC Waterblock
Koolance CPU-345AT Waterblock
Koolance CPU-350AC Waterblock
Mach2 GT 775 mounting Kit
MPZ Copper/Alu Pot
OCZ Cryo-Z 775 mounting Kit
OCZ HydroFlow Waterblock
Scythe Ninja Copper
Scythe Orochi
Swiftech Apogeee Drive Waterblock
Swiftech Apogeee GT Waterblock
Swiftech Apogeee GTX Waterblock
Swiftech Apogeee GTZ Waterblock
Swiftech MCX 775-V
Thermalright TRU Ultra-120A 1
Thermalright TRUE Ultra-120 eXtreme 1
Thermalright TRUE Ultra-120 eXtreme Full-Copper 1
Thermaltake V1 AX
Tuniq Tower 120
Xigmatek Achilles
Ybris ACS Waterblock
Ybris One-Evo Waterblock
Zalman CNPS-9300
Zalman CNPS-9500
Zalman CNPS-9700
Zalman CNPS-9900
Zalman WB3 Gold Waterblock
Zalman WB4 Gold Waterblock
Zalman WB4 PLUS Waterblock
Zalman WB5 Waterblock
Known to work 1366 solutions:
CoolerMaster V8 *
DangerDen MC-TDX Waterblock
DangerDen MPC-CPU Waterblock
Dynatron G555
Intel 1366 Stock Heatsinks
Koolance CPU-340 Waterblock *
Noctua NH-U12P SE1366
Swiftech Apogeee Drive Waterblock *
Swiftech Apogeee GT Waterblock *
Swiftech Apogeee GTX Waterblock *
Swiftech Apogeee GTZ Waterblock *
Thermalright TRU Ultra-120A * 1
Thermalright TRUE Ultra-120 eXtreme * 1
Thermaltake V1 AX
Thermaltake CL-P0501
Thermaltake CL-P0532
Thermaltake CL-P0533
Vigor Monsoon III
Zalman CNPS-9300 *
Zalman CNPS-9500 *
Zalman CNPS-9700 *
Zalman CNPS-9900 *
* This is not a native 1366 solution. There are newer versions with 1366 mounting hole support and older versions without. For BloodRage either version will fit and work fine, for other Boards you need the 1366 backplate so if you use several boards or can chose between either 775 or 1366 mounting solutions you should get the version with the 1366 backplate/mounting plate.
1 The Wire fanclip works best as it allows the fan to be elevated slightly and moved around a bit and as result even memory modules with large heatspreaders can be installed. Dont let the fan push the memory in slot1 back! Mount the fan elevated so it sits above the memory heatsink and doesnt push it from the side. The Fanbracket hits high memory heatsinks in the first memory slot and blocks them, if the memory has low or no heatsinks it will fit but once the fan is installed it will prevent the first memory stick from getting removed/exchanged.
not supported/recommended:
Intel 775 Stock Heatsink - 775 PushPin
OCZ Gladiator - 775 PushPin
OCZ Gladiator MAX - 775 PushPin
OCZ Vanquisher - 775 PushPin
OCZ Vendetta - 775 PushPin
OCZ Vendetta 2 - 775 PushPin
Scythe Andy Samurai Master - 775 PushPin
Scythe Katana - 775 PushPin
Scythe Mugen - 775 PushPin
Scythe Ninja Mini - 775 PushPin
Scythe Ninja PLUS - 775 PushPin
Scythe Ninja 2 - 775 PushPin
Scythe Orochi - 775 PushPin
SunbeamTech Core Contact Freeze - 775 PushPin
Thermalright IFX-14 - 775 PushPin
Thermaltake Big Typhoon 120 VX - 775 PushPin
Xigmatek Red Scorpion - 775 PushPin
If you have a heatsink that doesnt seem to fit please let us know and post some pictures if possible.
If you use a heatsink that is not on the list yet and it fits well, please let us know so we can add it to the list here!
Ill add more and more heatsinks here over time, please help me to make this list as complete as possible, thanks!![]()
), Juan J. Guerrero
. I'll send you a PM with what I find if you'd like.
how come?
