http://valid.canardpc.com/show_oc.php?id=471056
There you go.
There you go.
Could it provide any performance boost when high HTT clocks are used like with high FSB on Intel platforms?
MPOWER|i5 3570K|TRUE Spirit 140|2x4GB+2x2GB|VTX3D 280X|SanDisk Extreme 120GB|HX520W|Arc Midi|G2222HDL|G400s+QcK|Xonar DGX
F1A75-V EVO|3870K|Venomous X|2x4GB|5830+DeepCool V400|F4EG 2TB|Solid 3 120GB|Silencer MKIII 500W|NZXT Source 210 Elite|IPS226V|Xonar DG
Overclock yourself, you must!!!
The htt link multiplier is at 1x though????
Is that even possible?
and why would they lower it that much?
Was it needed to make the high htt work?
If it'll work that high normally we'll see some really good overclocking on the 920 and other non black edition cores.
I can't wait to see how the dual cores will clock they should be able to clock up to wolfdale levels from how things are turning out so far.
For me is quite interesting fo future PII920 owners!
AMD Phenom II X2 550@Phenom II X4 B50
MSI 890GXM-G65
Corsair CMX4GX3M2A1600C9 2x2GB
Sapphire HD 6950 2GB
This COULD be the CPUZ bug as well. I don't hope so, but it's definately a possibility (at least until we see benches at 300+ MHz).![]()
--->TeamPURE<---
Makes me happy , I have that same Mobo![]()
AMD Phenom II X550BE @ X4 3.8Ghz | Asus Crosshair V Formula | Gskill F3-16000CL9-8GBRM | 2 X Saphire 4850 in Crossfire | Asus Xonar D2x | Corsair HX750 | Silverstone Raven rv-01
Heres a screen fom coolice
original thread here
http://forum.breakthelimit.net/index...&st=0#entry780
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
Lowest possible HT multi seems to be indeed 1x. I have not yet seen sub 5x.
This is the responsible register.
Will try to modify this register with baredit tomorrow to see if it's possible to use lowert than 5x on the asrock and gbt boards whom only allow 5x min via bios. With 5x I'm hitting a wall at 280MHz and i'd need abit more to beat 9500 wr.![]()
wow so is there anyone else that has a phenom II or is it just coolice? he keeps pumping all this stuff out.
Any idea if this is expected to be common? I.E. can phenoms clock with HT better now? If so then I may not wait as long for an AM3 BE to come around.
since coolice is the only when i have seen do it im not sure if this is a simple thing to do. deneb is two weeks away and we should know soon.
Nice man...The only thing really high HTRef clocks prove though is the ability for locked clock CPU's (such as the 920) to reach higer CPU frequencies...
As impressive as that is, my experience with Phenoms have shown that keeping the HTRef around 200 and using Multis for higher CPU/IMC/Mem clocks have shown better results....
Hopefully things will change with new Mobos, but from my experience high HTref clocks get a little squirley and cause wierd results...
In the end though 350 on the HtRef (benchable) is pretty damn impressive!!
I'd still rather have a 940 @ 210x20x12 at reasonable V's...
Only time will tell, but I don't see Xtreme HtRef clocks being the future of PhII...
Damn... I need a 940BE RIGHT NOW!!![]()
AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
First Computer: Commodore Vic 20 (circa 1981).
Any ideas what was the cooling for this 5GHz+ benches? It should be cascade or phase change for 1.7V+...
P.S. It's great we have any opportunities to use some HTT in order to keep our memory frequencies at the edge of the chips' max.
P.P.S. Silly me it's written the tests were on L2N.
very good, so "non-black" series users will have a good oc to.
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55''Samsung LED 3D TV
Coolaler OC Team from TAIWAN
My English isn't good, please much and much forgive
Damn now i am gonna get myself a 920 for sure!
Perfect !!
Where courage, motivation and ignorance meet, a persistent idiot awakens.
Great
Hi Toppc, can you tell me what HSF you used for that 4GHz system![]()
Hmmm, DDR 1200 running 1:1 seems very doableVery nice results!
Synaptic Overflow
CPU:
-Intel Core i7 920 3841A522
--CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
Motherboard:
-Foxconn Bloodrage P06
--Blck: 200Mhz| QPI: 3600Mhz
Graphics:
-Sapphire Radeon HD 4870X2
--GPU: 750Mhz| GDDR: 900Mhz
RAM:
-3x 2GB Mushkin XP3-12800
--Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
Storage:
-3Ware 9650SE-2LP RAID controller
--2x Western Digital 74GB Raptor RAID 0
PSU:
-Enermax Revolution 85+ 1250W
OS:
-Windows Vista Business x64
ORDERED: Sapphire HD 5970 OC
LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
IN MSI 9600GSO 512MB 256bit
intel i7 920
amd x4 940
I'd like to see a High HTT shot under DIetc for 920 users looking for high clocks.
heatware chew*
I've got no strings to hold me down.
To make me fret, or make me frown.
I had strings but now I'm free.
There are no strings on me
