It might be too early to say but Intel's leap ahead with new Xeon over AMD in server area looks even more impressive then Core 2 storm some times ago.
http://www.anandtech.com/weblog/showpost.aspx?i=532
The SAP numbers are absolutely astonishing, as Intel's dual socket is able to outperform quad socket opteron machines. Based on the scaling of Barcelona, we speculate that a quad Shanghai at 2.7 GHz would obtain the performance of the Dual Xeon 5570 w/o HT.The new Xeon 5570 outperforms the "old" 5450 by 119%!!!
These numbers are so high, that we checked and checked again. The database used is the same (SQL Server 2005), so unless there is some incredible tuning parameter that HP and FS have discovered and that we have yet to hear about, that is not it.
At this point we have no idea how it is possible that a 3 GHz Nehalem outperforms the latest Opteron by a margin as high as 80% and more. But we can give it a try. In a previous server oriented article, we summed up a rough profile of SAP S&D:
• Very parallel resulting in excellent scaling
• Low to medium IPC, mostly due to “branchy” code
• Not really limited by memory bandwidth
• Likes large caches
• Sensitive to Sync (“cache coherency”) latency
One of the biggest bottlenecks for Intel has been the sync latency. It is possible that once the "sync" bottleneck was removed, the intel architecture is able to show it's real integer crunching power thanks to the out of order loads (memory disambiguation) and better branch prediction.Those are two areas where the opteron architecture is still weak.
