Page 1 of 4 1234 LastLast
Results 1 to 25 of 88
Thread: Swiftech Caldera 4870X2 Released
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    We are glad to announce the release of the Caldera 4870X2 hybrid cooling system for AMD's HD4870X2 reference design graphics cards.
    http://www.swiftech.com/products/Cal...ing-system.asp
    Shipping to resellers will begin this coming Monday.
    MSRP is $159.95, water-block and heatsink included.
ID:	90728   Click image for larger version.
ID:	90729   Click image for larger version.
    CEO Swiftech
    Mar 2006
    Los Angeles CA
    Just to be certain water never comes in contact with the aluminum correct?
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by aspire.comptech View Post
    correct.
    CEO Swiftech
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    why is it the same price as the EK nickle block, shouldent it be about the price of the xspc block since its a hybrid so it should be cheaper in theory
    and if u trim the stock unisink would the culdera block work on it
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Aug 2007
    Longview,WA
    looks good very cool idea.
    -TJ07
    -Core i7 920
    -Rampage II Extreme
    -EVGA 8800 Ultra
    -Corsair Hx1000w
    -Corsair 6GB DDR3-1600 Dominator
    -Intel 80GB SSD gen.2
    -WD 6400AAKS Raid 0
    Xtreme Mentor
    Sep 2007
    Dallas
    Quote Originally Posted by zanzabar View Post
    Agree on the first part. Way over priced. The heatsink doesn't get cooled by the water blocks, you are not adding any sinks to the back of the board for the memory on the other side. The EK nickel is the same price, the Koolance and DD are $20 less and the XSPC is $60-$70 less depending on where you get it from.
    And to boot the name is still upside down and yes you can see it, especially in a horizontally mounted MB.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Jul 2006
    Just 2 questions:does it fit in a single pci slot, and is performance on par with a pair of mcw60's?
    “You Americans are so gullible. No, you won’t accept communism outright, but we’ll keep feeding you small doses of socialism until you’ll finally wake up and find you already have communism. We won’t have to fight you. We’ll so weaken your economy until you’ll fall like overripe fruit into our hands." Nikita Khrushchev
    Mar 2008
    Dallas, TX
    I really like that the vram isn't cooled by the water, but I also agree way over priced. I love swiftech products, all very high quality, but this isn't worth it. The stealth blocks were much more attractive imo.
    "fightoffyourdemons"
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Quote Originally Posted by Chruschef View Post
    and aluminumy
    Mar 2008
    Dallas, TX
    Quote Originally Posted by SNiiPE_DoGG View Post
    and aluminumy
    I never commented on how good they were.
    I certainly never owned one.
    Nov 2002
    Michigan
    What makes this design better than other similar products to warrant the higher price? The most expensive material; copper; has been significantly reduced and should allow for a less expensive product. The only benefit I see is not dumping the mem/vreg heat into the loop but in turn forces you to use a fan to move the heat into the case. I like the idea of the heatsink if it is used in conjunction with standard/re-usable blocks, but all of this is tied to one single card. This option makes no sense in cost or function. The only possible upside I see is bling factor, which I think is important for a good deal of people but not put ahead of overall performance and cost.
    Please explain to me where I am wrong? I did not set out to attack this product, I just can't seem to find a place for it, this late and this pricey.
    Gigabyte GA-P35-DS3P
    Intel Q6600@3.5
    G.Skill 4GBPQx2 8GB
    ATI HD4870
    WD Raptor-X 150
    WD 36GB Rapor x2
    WD 320AAKS
    NEC 3500a DVDRW
    Corsair HX620
    X-Fi Prelude
    Xtreme Mentor
    Sep 2007
    Dallas
    Also on the heatsink the grooves go up and down, not side to side, so air from a fan will not travel down the grooves. Correct me if I am wrong.
    Desk Build
    W/C System
    Xtreme Mentor
    Sep 2006
    Don't mean to add to the bad vibes, but damn, that thing is you-gee-el-why. I knew I was getting a lump of coal for Christmas, but I didn't know it was coming this early.
    For my part I know nothing with any certainty, but the sight of the stars makes me dream.
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Utnorris View Post
    Utnorris, explain to me how you can see the name when the motherboard is installed normally:
    Now, if the motherboard is installed upside down, as is possible in several high-end cases, this is what you see:
    So if you mean to criticize how the name is oriented because in Desktop PC's it would be upside down, then I ask: how many enthusiasts use tricked dekstop PC's (with windows for example) as opposed to towers?
    Just give me one valid example please, because I would really like to understand where you are coming from.
    CEO Swiftech
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by _G_ View Post
    I think this is the same question you asked once before. The card stock retention bracket uses two slots. It doesn't matter how much space the cooler takes since the card itself will use two slots.
    But in the event you decided to cut the card' stock retention bracket with a dremel in order to free up the second slot, then I suppose that question becomes relevant. I'll have to double-check if there is enough space to do that, but I suspect there might be.
    Performance: yes the C/W is exactly the same as the MCW60 since we use the MCW60 copper base. The pressure drop will be higher that of the MCW60 simply because you have the extra 90 degree elbow dictated by the inlet/outlet orientation. That is true for all full-cover blocks.
    CEO Swiftech
    Jul 2007
    Montreal, Canada
    Quote Originally Posted by gabe View Post
    Im guessing he meant on horizontal motherboards like in the MM cases.
    There for it would look like this:
    MM Ascension Duality - Sky White
    i7 920
    Gigabyte EX58-UD5
    Gigabyte 4870X2 , DD 4870X2 Waterblock
    3 x 2GB Patriot Extreme Viper
    Silverstone Decathlon 1200W
    Raptor X 150, WD Black 1TB
    4 x Samsung F1 1TB
    3 x 320 Seagate 7200.10
    X-Fi XtremeMusic
    Stinger all copper V8 1366 (Soon to come)
    Thermochill PA.120.3
    Swiftech 655 Vario pump
    Maze 4 NB block
    EK Multi option res 250
    Feb 2007
    MA, USA
    Quote Originally Posted by Apollo4g View Post
    ding ding ding, we have a wiener
    yeah I think the log is indeed upside down for horizontal mobos, however it is correct for inverted ATX which is a MUCH more common configuration despite what you mm owners may think.
  18. #18
    Banned
    May 2008
    vermont, yes i like women
    will this work on a 4850X2???
  19. #19
    Jul 2007
    Montreal, Canada
    Haha very true, was just clarifying what he meant.
    i7 920
    Gigabyte EX58-UD5
    4 x Samsung F1 1TB
    X-Fi XtremeMusic
    Maze 4 NB block
  20. #20
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Ok. So how many MM owners are interested see a cover option with the name cut in the other direction?
    CEO Swiftech
  21. #21
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Adam217 View Post
    The product is late indeed. Nothing I can do about that unfortunately.
    GPU cooling performance is superior by design to any other full cover on the market, but not better than individual blocks such as the MCW60 or the Fuzion; in fact flow restriction is worse than these solutions, for the reason I explained earlier (the extra 90 degree elbow dictated by inlet/outlet orientation), but this is something full cover owners have accepted as a compromise.
    Price is a reflection of the small quantity we made for what I see as a "limited edition". On the other hand, people who like the design and the added performance, and who spend over $500 on a card shouldn't worry that much whether the product is at the high-end of the price spectrum by a few bucks.
    CEO Swiftech
  22. #22
    Jun 2008
    I have a DD Torture rack and I see his point but what the hell else do you expect when something like 5% of enthusiasts even, will never really look at that logo?
    Dec 2012 setup:
    • i7 920 @ ~4.4Ghz 1.354v |Mushkin Enhanced Ridgeback 3*4GB @~1680mhz CAS8T1 | DFI UT LP X58-T3EH8 w/Flame Frezer | Radeon 6990 4GB
    • X-Fi Titanium Fataility Championship Series | Intel 510 Series SSD 250GB + 1.5TB Seagate Barracuda | Corsair AX1200
    • Cooling: HWLabs GTX560, Four Silverstone AP141, EK Supreme Plexi CPU, DangerDen Full Cover GPU, D5 with bitspower top and male-male direct connect to DD Monsoon
    • Mountain Mods Monticle 24 w/Custom cut panels, Anodized black, Acrylic panel on Reverse ATX setup | Tripple ASUS VH238H 23" 1080p LED | Logitech G500+Leopold Cherry Reds | Ultrasone H-FI 780
  23. #23
    Feb 2007
    MA, USA
    Methinks its time for an MM with an inverted horizontal mobo
  24. #24
    Jan 2004
    somewhere in Massachusetts
    If this just uses the MCW60 base, is there any chance that the 'shell' will be released at a lower price? Or that in a year hte 5870 X2 (guessing at the name) will have a new 'shell' for sale (say $50) and we can just pop the bases into it?
  25. #25
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    SNiiPE, I see you have a 4870x2 + single 4870. How's is that working for you ?
    I am thinking of doing that for our demo system (which I also use for some gaming whenever I have time)?
    CEO Swiftech
