Page 1 of 3 123 LastLast
Results 1 to 25 of 68
Thread: Heatkiller Rev3.0 internals at Cooling Masters
    Feb 2006
    Sweden
    Heatkiller Rev3.0 looks kinda like EKs Supreme. Let's hope the performance is similar too because the delrin version is pretty cheap.
    Mar 2006
    Los Angeles CA
    Yeah because that isn't a blatant copy...
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Oct 2007
    socal
    well heatkiller had a block like that since 06 the supreme came out in 07
    the second rev of the heatkiller came out sometime in March 07 as were the supreme was announced sometime in October 07
    rev 2.0
    rev 2.5
    couldnt find a pic of rev 1, anyways looks like a good block, and i like the design
    Mar 2005
    Slovenia - EU
    Hi.
    Everyone takes what is the best of the competition and implements that into their product.
    There is similarity between previous heatkiller versions and supreme, and this 3.0 version has also the unique features of Supreme.
    So I am really interested how well it performs
    Awaiting for good review and comparison.
    Quote Originally Posted by creidiki
    EKs are like waterblock pr0n
    Oct 2007
    socal
    thanks for that Eddy
    Feb 2008
    Buenos Aires - Argentina
    nice water blocks......... have you tested already??? This are for Intel or AMD socket?
    Intel C2D E8400 @ 4Ghz // Asus Maximus Formula x38 @ FSB 500Mhz// G.Skill Pi 2x2GB 1000Mhz // 9800GTX+ SSC eVGA // WD Raptor X 150GB + Samsung Spinpoint 2TB // DVD-RW DL Asus // Powercooler 850W // CM Cosmos S // Samsung T260N / Edifier R251 // Logitech G9 // Logitech G15 Rev2
    Cooling System: Swiftech Apex Ultra H2O Kit + MCW60
    Jun 2007
    Bloomington, IN
    Quote Originally Posted by ShArKo View Post
    They have versions for 1366, 775, 754, 939, AM3.
    Those appear to be some awfully thin channels, pretty nice looking blocks.
    Dec 2006
    The supreme land of rules and regulations
    They look a lot nicer on the inside than on the outside.
    Feb 2006
    Sweden
    Quote Originally Posted by Snowfortrick View Post
    I don't really trust those results.
    I don't belive it's possible to be less restrictive than the Supreme while still performing better.
    Just look at martins block roundup, every block performs within a few degrees of each other. I just don't see how a block could perform several degrees better than the best of all of those blocks. Although I really hope to be proved wrong, then I'll have to build a new core i7 rig just to use this block!
    I suppose if one were to do only one mount of each block and the supreme caught a really bad mount while heatkiller 3 got a really good one it would be possible to get these results.
    Quote Originally Posted by century child View Post
    Beauty is a very subjective thing, I for one like the angly shapes and love the copper top!
    Jun 2007
    Bloomington, IN
    You raise a good point, that's quite an improvement. Through it would be possible to have less restriction and better performance depending on how many channels there are and the size/height of fins. As always more independent tests are appreciated.
    Hamster Powered
    Apr 2006
    Virginia, USA [Krunching since 2001]
    Quote Originally Posted by Eddy_EK View Post
    Hi.
    Eddy,
    You are a class act sir.
    XSWCG Disclaimer:
    We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
    Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
    Banned
    Oct 2008
    Dartmouth NS Canada
    I believe these are the guys that hooked Langer up with his blocks in his PrometheusCU build. They make some nice blocks for sure!
    Yes Eddy nice way of looking at things as well.
    Jul 2006
    Quote Originally Posted by andersson.j View Post
    http://www.schwarz-muenchen.de/pics/...iag_dfm_53.jpg
    http://www.schwarz-muenchen.de/pics/...iag_dfm_85.jpg
    http://www.schwarz-muenchen.de/pics/.../diag_k_53.jpg
    http://www.schwarz-muenchen.de/pics/.../diag_k_85.jpg
    Looks like they used a low head Eheim pump. not really the ideal setup for the EK block
    “You Americans are so gullible. No, you won’t accept communism outright, but we’ll keep feeding you small doses of socialism until you’ll finally wake up and find you already have communism. We won’t have to fight you. We’ll so weaken your economy until you’ll fall like overripe fruit into our hands." Nikita Khrushchev
    Banned
    Apr 2008
    Brisbane, Australia
    Hi.
    Ok that was unexpected so on with the EK SUPREME V2 OWNAGE RRR FTW EDITION.
    Banned
    Oct 2007
    I have been playing with the Supreme for some time, I have 20 accelerator plates that are stock and some of the custom ones Eddy made, I have modified the plates alot, and on cooler running blocks having no plate improves performance of the block, as with low flow pumps, but the big shock is by cutting out 2 of the fins in the middle, you improve performance even on high flow pumps! so by having a freeing up the plate a little bit you gain some performance
    I would still be testing but I have no CPU to test with atm, and im not pulling apart any of my current rigs just to test with, but im looking at a quad core or even an old P4 3.2 or somthing that runs amazingly hot
    as soon as I have the new CPU I will start testing again and start showing off my different designs of the Plate
    Mar 2007
    Hi.
    Good post.
    Laminar flow designs and pin matrices were in use in the industrial sector for watercooling long before the modern personal computer came into being. I would say nearly every, if not every PC waterblock ever conceived is a copy (whether intentional or accidental).
    Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
  18. #18
    Jul 2008
    Winterthur, Switzerland
    Quote Originally Posted by MomijiTMO View Post
    I'd buy it.
  19. #19
    Xtreme Enthusiast Shocker003's Avatar
    Jul 2007
    Germany
    Nice block and uber decent preformance. I bet Micky64´s block will kick ars..es if he ever gets it produced.
    MAIN RIG--:
    ASUS ROG Strix XG32VQ---:AMD Ryzen 7 5800X--Aquacomputer Cuplex Kryos NEXT--:ASUS Crosshair VIII HERO---
    32GB G-Skill AEGIS F4-3000C16S-8GISB --:MSI RADEON RX 6900 XT---:X-Fi Titanium HD modded
    Inter-Tech Coba Nitrox Nobility CN-800 NS 800W 80+ Silver--:Cyborg RAT 8--:Creative Sound BlasterX Vanguard K08
  20. #20
    Nov 2007
    Italy
    I agree,too much gap...but i'll buy it for test it personally,because i already have a supreme on my system
  21. #21
    OC Jedi (on stand-by)
    Jan 2005
    Germany
    Cooling performance wise, the Heaetkiller 3.0 is the second best water block I ever tested. Due to new tubing for my test equipment, flowrate cannot be compared to old tests, but temperature seems to be within 0.2C with the little higher flowrate, I retested 2 blocks and the measures temps were within 0.2C, but other blocks might behave differently with a change in flowrate, so don't blame me for the results posted below.
    Temperature delta:
    HK 3.0:
    38.8 C (Eheim 1046)
    37.2 C (Laing DDC-1T)
    EK Supreme:
    42.8 C (Eheim 1046)
    42.7 C (Laing DDC-1T)
    Testing mythology:
    Asus Maximus Formula, QX6700 @ 3.46 GHz, 1.5 V, 30 minutes Prime 95, 3-5 mounts depending on variation, listed values are the difference of the average water and the average CPU temperature.
    オタク
    "Perfection is a state you should always try to attain, yet one you can never reach." - me =)
  22. #22
    Nov 2007
    Italy
    omg
  23. #23
    Feb 2008
    Cancun
    Now that is impressive, might have to get me one of these.
  24. #24
    Jan 2005
    Germany
    Surprisingly the new SCW-Rev.A from Enzotech was even slightly better than the HK 3.0.
    オタク
  25. #25
    Feb 2006
    Sweden
    Quote Originally Posted by Fr3ak View Post
    The same Enzotech as in Martins review?
