Of course, it is air cooled with Coolermaster Hyper 212.
CPU is prime stable at 3.46-3.48 Ghz @ 1.5v
At 3.52 Ghz it won't boot into the windows. Max voltage for air is 1.5-1.52v.
"That which does not kill you only makes you stronger." ---Friedrich Nietzsche
PCAXE
why you didn't gave people hole validation ?
you gave screen from it
can you show spi on 3500 ?
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
biohead I saw it morning
but thanks for share for other people![]()
Here is some spi 1m screenshots...![]()
PCAXE
100mhz more then tricore/hhhhmmm
Finally, KUMA has arrived.
It's about time AMD. Finally you have something to compete with the lousy core2duo.
Anyone know the Kuma prices?
drfedja, try spi at div 800 and 4-4-4-12 and oc it by htt to 3500![]()
I will try SPI at 800 div, but with 4-5-4-12 timings![]()
My DFI LP DK 790FXB can push HTT up to 295 Mhz with Phenom 9950 BE.
In the meantime see that 3DMark06 CPU score.... at 3.4 ghz with standard HTT, and memory at 1066 CL4.
PCAXE
I have some results for 7-zip 32-bit, ScienceMark 2.0 32-bit and world in conflict 800x600 lowest and 1280x1024 medium. GPU is nVidia XFX 9600GSO 384MB, 725/1755/2100.
PCAXE
Ive got one running at 3.38 with 1.45v! Still tweaking but seems like a decent chip! Anyone have suggestions on what levels of ACC these chips like?
ASROCK 970 Extreme 3 // FX-6200 @ 4.65 (245x? 64bit os) 1.45v,2200 nb/HT //8GB Mushkin DDR3 @833 8-8-8-24 cmd1 1.55v // HD7850// Silverstone 650w // ~32inch portal // WDgreen and blue // Kingston v300 120GB SSD // watercooled with Swiftech storm rev2, Fez 240 , 655 pump not packed into a Corsair Obsidian 650D///
I hit 3.4 with no ACC 1.44v. I don't ACC will help any on mine, I might give it a try later. It will vary on each chip tho.
~1~
AMD Ryzen 9 3900X
GigaByte X570 AORUS LITE
Trident-Z 3200 CL14 16GB
AMD Radeon VII
~2~
AMD Ryzen ThreadRipper 2950x
Asus Prime X399-A
GSkill Flare-X 3200mhz, CAS14, 64GB
AMD RX 5700 XT
when he made that post the price was hvering around 80+. But deffinently a better buy now.
~1~
AMD Ryzen 9 3900X
AMD Radeon VII
~2~
Asus Prime X399-A
AMD RX 5700 XT
LOL, Ya, I didn't rea;ize at first either. I paid 77 as well.
~1~
AMD Ryzen 9 3900X
AMD Radeon VII
~2~
Asus Prime X399-A
AMD RX 5700 XT
It was a whopping $55 a couple of days ago
And I thought it was strange to see people hyping up kuma until I see the date. Oh![]()
This chip is an awesome gaming chip. I cant believe the performance for the money. Great way to dabble in phenom clocking. Gonna try and do a super pi run at 3.5 today since its cold![]()
Rock solid! Need water cooling again! Not bad for $63!![]()
I paid 59 from Amazon, put it into my Ubuntu machine, clocked it to 3Ghz easily. Fasted linux machine I've ever had. To bad linux is marginally useless![]()
Asus M3A79-T W/ PII 720@3.6Ghz DTek Fuzion Water Block
Raptor X 150G Boot Device & 3 X WD 500GB in RAID 5 Load Device
8G OCZ Reaper @1066
2xVisiontek 4870 Xfire @790/1080Mhz w/XPSC Water Blocks
Razer Barracuda Sound System
Windows Vista 64 Bit SP1
LG 24" 1920X1200
That's a nice background you got there. Where did you get it?
