Results 1 to 25 of 97
Thread: ASUS BIOS Update Area
Threaded View
    Mar 2004
    Taiwan
    ASUS BIOS Update Area for (P5 P6 Series)
    IntelŽ X58
    ASUS P6T Deluxe 1504 Final Bios
    [ 1504 ]
    1. Fixed the key may lag in BIOS setup when a Turbo Mode ratio was selected.
    2. Supported EIST function when CPU ratio is in manual mode.
    3. Adjusted max value of CPU ratio setting according to the number of cores active in BIOS setup.
    4. Fixed setup item "CPU Ratio Setting" may disappear if down CPU ratio.
    5. Fixed Vista may loading slowly when populated memory size is larger than 3GB and with high-end VGAs.
    ASUS P6T 0403 Final Bios
    [0403]
    ASUS Rampage II Extreme 1204 Final Bios
    [ 1204 ]
    Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us
    ASUS P6T WS Pro 0504 Final Bios
    [ 0504 ]
    1. Added CPU micro code(s).
    ASUS Rampage II Gene 0503 Final Bios
    [ 0503 ]
    Fix system may not able to resume from S3 if Base Clock is set over 170MHz
    ASUS P6T Deluxe V2 0406 Final Bios
    [ 0406 ]
    ASUS P6T SE 0203 Final Bios
    [0203]
    ASUS P P6T6 WS Revolution 0407 Final Bios
    [ 0407 ]
    1. Updated CPU micro code(s):
    * M03106A5_0000000F - Intel Nehalem-EP D-0 Nehalem-WS 1S D-0 Bloomfield D-0
    * M03106A4_0000000F - Intel Nehalem-EP C-0 Bloomfield C-0
    2. Support i920 CPU ratio up to 21 and i940 up to 23 in BIOS setup.
    3. Increased the boot block version from 24 to 25.
    IntelŽ B43
    ASUS P5QL VM DO 0218 Final Bios
    [0218 ]
    First BIOS
    IntelŽ P45
    ASUS P5Q Deluxe 2005 Final Bios
    [ 2005 ]
    1. Fix pc probe II will show 0 RPM when chassis fan_3 speed is lower than 700RPM.
    2. Fix system may take too long time to boot when cerian optical disc drive is connected and no disc is inside.
    3. Update the DriverXpert option ROM to support 48bit LBA addressing.
    ASUS P5Q 2002 Final Bios
    [ 2002 ]
    ASUS P5QC 2002 Final Bios
    [ 2002 ]
    Update Express Gate to v1.4.4.1
    ASUS P5Q-E 2101 Final Bios
    [ 2101 ]
    ASUS P5Q Pro 2102 Final Bios
    [ 2102 ]
    update Express Gate to v1.4.6.2.
    ASUS P5Q-E Wifi-AP 1702 Final Bios
    [ 1702 ]
    1. Fix chassis fan mode can't be saved after resume from S3.
    2. Fix display priority is not correct when plugs two PCIE VGA cards.
    3. Enhance the compatibility with certain memory.
    ASUS Maximus II Formula 2104 Final Bios
    [ 2104 ]
    ASUS Maximus II Gene 0504 Final Bios
    [ 0504 ]
    Support OC Station
    ASUS P5Q3 Deluxe 1901 Final Bios
    [ 1901 ]
    Modified the copyright date.
    ASUS P5Q3 0603 Final Bios
    [ 0603 ]
    IntelŽ G45
    ASUS P5Q-VM 1602 Beta Bios
    [ 1602 ]
    1. Improve the compatibility with some memory.
    2. Fix a bug that the Fan speed may decrease after waking from S3 mode
    IntelŽ X38
    ASUS P5E 1102 Beta Bios
    [ 1102 ]
    Fixed use 2 pieces of ATI4870X2 VGA Card can't display from Primary slot display monitor
    ASUS P5E WS Professional 1203 Final Bios
    [ 1203 ]
    1. Update CPU microcode.
    ASUS Maximus Extreme 1202 Beta Bios
    [ 1202 ]
    ASUS Maximus Formula 1302 Beta Bios
    [ 1302 ]
    ASUS P5E3 Deluxe 1409 Final Bios
    [1409 ]
    ASUS P5E 1201 Final Bios
    [ 1201 ]
    IntelŽ X48
    ASUS P5E3 Premium 0803 Final Bios
    [ 0803 ]
    Support New version Express Gate
    ASUS P5E3 Pro 0308 Bios
    [0308 ]
    First BIOS
    ASUS P5E Deluxe 0304 Final Bios
    [ 0304 ]
    ASUS Rampage Formula 0902 Final Bios
    [ 0902 ]
    ASUS Rampage Extreme 1202 Final Bios
    [ 1202 ]
    Fix system may hang if use with some USB Mouse
    IntelŽ P35
    ASUS P5K Pro 1303 Final Bios
    [ 1303 ]
    1. Adjust Option ROM scanning order such that the southbridge RAID volume would not disappear when plugging an add-on SCSI card.
    2. Fix display priority may be incorrect when plugging two PCIE VGA cards.
    3. Fix sometimes the system may wait about 30 seconds to boot into OS when many USB
    devices are connected to the system.
    ASUS P5K Deluxe 1005 Final Bios
    [ 1005 ]
    1. Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx
    2. Fix the display priority may be incorrect when plugging two PCIE VGA cards.
    3. Fix the system make take about 30 seconds to boot into OS when all USB ports are in use.
    ASUS P5K3 Deluxe 1203 Final Bios
    [ 1203 ]
    2. Fix the system may take about 30 seconds to boot into the OS when all USB ports are in use.
    3. Fix the Realtek LAN may stop functioning under Windows XP and Vista when AI-NET2 option is changed to Disabled.
    ASUS P5K3 Premium 0805 Final Bios
    [ 0805 ]
    3. Fix Realtek LAN may stop functioning under Windows XP and Vista when the AINet option is changed to DISABLED.
    IntelŽ 975X
    ASUS P5W DH Deluxe 2901 Final Bios
    [ 2901 ]
    1. Fix the system may BSOD after upgrading to Vista Service Pack 2.
    IntelŽ P965
    ASUS Commando 1901 Final Bios
    [ 1901 ]
    Enhance the CPU compatibility with certain CPUs.
    ASUS P5B-E 1807 Final Bios
    [ 1807 ]
    Fix wrong HDD size is detected by BIOS when the size is over 1000GB.
    IntelŽ 945P
    ASUS P5LD2 2001 Beta Bios
    [ 2001 ]
    V2001
    NVIDIA nForce 680i SLI
    ASUS P5N32-E SLI 1701 Beta Bios
    [ 1701 ]
    Fix PCIE VGA card might fail to function when being plugged in the third PCIEx16 slot.
    NVIDIA Dual X16 SLI (C55+MCP55P; a.k.a. nForceŽ650i SLI & nForceŽ570 SLI)
    ASUS P5N32-E SLI Plus 1301 Final Bios
    [ 1301 ]
    1.Change CopyRight year from 2008 to 2009.
    2.Update EZ-FLASH2 to B334
    NVIDIA nForce 790i Ultra SLI
    ASUS Striker II Extreme 1202 Beta Bios
    [ 1202 ]
    NVIDIA nForce 780i SLI
    ASUS P5N-T Deluxe 1402 Beta Bios
    [1402 ]
    ASUS Striker II Formula 2102 Beta Bios
    [ 2102 ]
    Enhance the stability of certain memory.
    NVIDIA nForce 650i SLI
    ASUS P5N-E SLI 1402 Final Bios
    [ 1402 ]
    Improve the stability of certain CPU.
