Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: X2Beach Mountain Mods Pinnacle 24 Core I7
    Jul 2005
    I just couldnt Live with the high Temps my Core I7 was giving me in my Coolermaster HAF 932 so I bough all new stuff and Will start this build tommorow When my MM pinnacle 24 arrives.
    Here is what I got going in it
    Rampage 2 Extreme
    Core I7 920
    Ati 4870X2
    PCPC Turbo cool 860
    Koolance CPU-350
    xspx 4870x2 Block
    MCP 355 Pump with XSPC Reservoir Top (1st Loop)
    XSPS DUal Bay Reservoir With pump (for 2nd Loop)
    TPC 360 Rad (top) For CPU
    PA 120.2 Rad Front (GPU)
    Kaze Slip Stream Fans 1600 rpm
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Oct 2007
    socal
    be careful, you may or may not be able to mount that rad up top even with 4 fan spacings because of your rom, unless you flip the face which i even had to consider with the 18
    Mar 2006
    Los Angeles CA
    Quote Originally Posted by evil-98 View Post
    I'm confused...
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Oct 2007
    socal
    Quote Originally Posted by aspire.comptech View Post
    I'm confused...
    maybe this will help
    look at the top mounted rad, the fan is pushing up against the DVD ROM
    i dont know how much fatter a TFC 360 is but im sure there will be some conflict.
    now if you flip the face plate so the ROM is on the bottom, problem solved, or even filp just the ROM cage and mount the rom at the lowest point you may be able to mount a 4x fan RAD
    Jun 2008
    holland
    ps DON'T use the scythe slipstreams on your rads they are terrible rad fans
    (because of the smaller motor space they have verry litle static pressure)
    further this is gonna be a nice build good luck whit it
    Oct 2007
    socal
    Quote Originally Posted by dopestuff View Post
    ive used them on MCR320s, they only thing that i can see that makes a difference is how they sound aside from that, they are adequate fans for either operations (ie. as rad fan or just case fan)
    there are obviously better fans, but if he already has them, id say use them
    Jun 2008
    holland
    yeah treu they do work
    i only recently replaced mine on my rad whit some ultra kaze and wow what a diference
    Oct 2007
    socal
    your going to compare the slip streams to a ultra kaze...
    different class fans obviously, if you were to compare something within its class its not all that bad
    Jul 2005
    evil.. Thanks for the tip. I will have my case in the morning.. I take a ton of pictures. My case is the same black wrinkle as yours...
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Mar 2008
    can you post pictures? i am contemplating buying the Pinnacle 24. also looking to internally mount my 120.3 pa rad.
    ah edit:
    i see you mentioned posting pictures in the previous post.. lol oops
    Jul 2005
    The Fun Begins
    1st pics posted..
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Banned
    Apr 2008
    Brisbane, Australia
    Looks nice now that there are pictures =D.
    Jul 2005
    running into so problems.. since the front panel is for a tripple thermochill rad and I only have a double.. I got a empyty 120 hole that I can fit a fan in..
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Jul 2005
    update
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Jun 2008
    Cary, NC
    Looking good "X2Beach"... Im looking forward to see this complete... my pinnacle 24 its on its way !!!
    Jul 2005
    thanks, Its taking longer then I thought.. I will have it done tonight. Ive been to home depot 3 times buying screws and misc stuff
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Looks nice. Can't wait to see the finished product.
  18. #18
    Banned
    Apr 2008
    Brisbane, Australia
    Haha, the most annoying thing is screws because you never buy enough. I went to a couple of stores and totally lost it when they didn't' have what I wanted, further delaying my build as I needed SCREWS lolololol.
  19. #19
    Jan 2008
    New Jersey
    Can't you fit a fan there by placing the fan between the front panel and radiator?
    Something like this:
    Radiator : Fan : Front Panel
  20. #20
    Aug 2004
    Minneapolis, MN
    Mountain Mods cases eat screws like crazy. I thought 2 boxes from McMaster Carr would have been enough, but I fell short. Now if only they offered some sort of screw package, or fan grill package.
  21. #21
    Jul 2005
    quick update
    getting closer
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
  22. #22
    Jul 2005
    99% Done
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
  23. #23
    Oct 2007
    socal
    hey, sorry i couldnt get to your PM, theres really nothing we can do, i just left it open
    maybe MM could make a wrinkled finish 120mm fan cap so we could close up the holes.
    also just noticed my freaken case didnt come with the HD mount... i got ripped
  24. #24
    Jul 2005
    its all good evil, I am going to call MM and get him to make me a custom front with only 2 120MM fan holes.
    This case was tough get the cables undercontrol
    I really like the HD mount. simple and works well
    Asus Rampage II
    Core I7 920 O/C 3.8
    Mushkin 6gig 7-8-7
    ATI 4870X2
    PCP Turbocool 860
    Koolance CPU-350 AC
    FSR 360
    pa 120.2
  25. #25
    Jul 2007
    I'll second the suggestion to mount the fans on the front radiator to the case and then to the radiator. That'll push the radiator far enough back that you should be able to fit a third fan in the top space.
    Hopefully I'm on top of the screw situation for my upcoming MM build, I should have enough hardware to have everything replaced with black socket cap screws including motherboard/CD drives/RAID cage/PCI slots with enough left over for anything I forgot
