Results 1 to 5 of 5
Thread: Intel Core i7 Overclocking Database
Threaded View
    Sep 2008
    Down the rabbit hole
    ALERT: I AM VERY BUSY THE NEXT COUPLE OF WEEKS SO UPDATING WILL BE SLOW TO NON EXISTANT. PLEASE KEEP NOTE OF THIS!
    This is the database for overclocking of the Intel Core i7 920, 940, and 965. Please post in the following format:
    1) Username:
    2) System name if applicable:
    CPU
    1) Processor Model
    2) Overclocked Speed (Please list full speed in mhz [e.g., 3600.00mhz] and FSB * Multiplier [400*9])
    3) Stable or Unstable (boots but crashes during applications)
    4) Your cooling system
    5) Idle and Load temps (if available)
    6) CPU Stepping
    7) Vcore
    Cooling
    1) Method
    2) Cooling parts (if water please list whether custom or kit; if air please note number of fans and fan models if available)
    Motherboard
    1) Motherboard model (Full name including manufacturer)
    2) Motherboard Chipset
    3) BIOS revision
    4) OS (include whether x86/32 bit or x64/64 bit)
    RAM
    1) RAM model (i.e., OCZ Platinum)
    2) RAM type (i.e., PC3-16000)
    3) RAM speed in mhz
    4) RAM Timings/Latency
    5) Amount of RAM in GB
    6) Voltage
    7) Cooling type (water, air, or passive heatsink)
    Please post CPU-Z screenshots to be counted in verified overclocking.
    Please post CPU stress testing screenshot of 8hrs+ on all cores (screenshot must show stress testing running; crashed or stopped will not be accepted into verified database). If not posted, the overclock will still be accepted, but not as a stable OC.
    If you have it, please post PCMark Vantage CPU score and total score (if you want you can post the rest of your system specs, but this is just for bragging rights so it is not necessarily needed).
    Stock speeds are as follows:
    Intel Core i7 920:
    133*20 | 2667.00mhz
    Intel Core i7 940:
    133*22 | 2993.00mhz
    Intel Core i7 965:
    133*24 | 3200.00mhz
    Thanks and happy overclocking!!!
    Core i7 920
    Core i7 940
    Core i7 Extreme Editition 965
    Ba da dum dum dum.
