Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 200
Thread: Nanofluid tested with three different temperatures on a Q6600
    Jul 2008
    Winterthur, Switzerland
    Nanofluid tested with three different temperatures on a Q6600 (Update!)
    Finally, I get to publish some more testing results here on XS. It's been a while since the "sandwich-thread" (still working on more testing for that) but today I can present you something... that you've already heard of dozens of times...
    If you visit the forums regularly, I'm sure you have seen reference to and testing done with Nanofluid. I can present nothing groundbreakingly new here but IMO verification of testing that has already been done is just as important as the new and groundbreaking stuff.
    Before I get into testing methods and resulst, I want to thank relttem for being so generous and shipping a bottle of Nanofluid half way around the world so I can play with it.
    Nanofluid
    Here's what the Nanofluid looks like:
    Visually, it resembles milk very much. The viscosity of the fluid is more or less like that of water, i.e. it's very much just a liquid even though it looks like it might be denser than water.
    This is an important factor since we're using the Nanofluid with components that were designed to be used with water. More on this later.
    Testing method
    I decided to test the fluid with three different radiator setups.
    Some of you might remember that Skinnee used different flow-rates and got different results from those. Using the different radiator setups amounts to something similar: three different fluid temperatures.
    Radiator-Setup 1:
    The first setup simply consists of one Magicool Slim 120 radiator and a Nanoxia FX-1250 fan set to run at 1030 rpm. This is very little cooling and will provide high liquid temperatures.
    Radiator-Setup 2:
    For the second set of test-runs, I use the same radiator but add a second fan (also @ 1030 rpm) so that I get a two fan push-pull on the radiator. This lowers liquid temperatures.
    Radiator-Setup 3:
    Finally, I use an Aqua Computer airplex pro 240 radiator with two Nanoxia fans @ 1030rpm to achieve lower liquid temperatures again.
    I run a loop with a Laing DDC, EK X-Res top, the radiator and an EK Supreme sitting on a Q6600 @ 1.5V VCore.
    There are two thermal sensors in the fluid (after the radiator, before the waterblock) and several digital sensors measuring ambient temperatures. Each test-run consists of 45 minutes warmup followed by 20 minutes of temperature logging. The CPU is loaded using Prime95 during the entire test-run.
    I gather all the data from all internal and external sensors in a log-file and average them out to get the results.
    Results
    First, let's look at the liquid temperature minus ambient temperature (scale is in Kelvin, one Kelvin being one degree Celsius of temperature difference):
    As we can see from these results, the two setups with lower temperatures don't show a clear difference between straight distilled water and Nanofluid. Taking into account a margin of error due to imperfect measurement, the 0.4 and 0.1 K differences shown with the dual-fan setups could just as well be caused by chance.
    However, in the setup with only one fan on a 120 radiator, we see a very distinct difference in performance between the two fluids.
    If we look at the absolute temperatures of the different test runs, it seems that somewhere around 33 degrees Celsius, Nanofluid "overtakes" water as a coolant. I'm not sure whether it's the absolute or relative temperatures that matter though it's just clear that Nanofluid performs well in temperature ranges where water no longer performs well.
    Let's have a look how the Nanofluid affects the CPU-Temperature:
    Here, we see the same effect: At lower temperatures, the Nanofluid doesn't do any better than distilled water, but at higher temperatures, we see a clear advantage of the Nanofluid.
    Further thoughts
    Filling, bleeding draining and cleaning the loop when using Nanofluid is basically the same as when using water. I had a filter and the EK Supreme in the loop and found no signs of clogging, no residues and no coloration of the tubing caused by Nanofluid. The pump ran just like it does with water. In short: There seems to be absolutely no problem with using Nanofluid. I didn't do any long-term testing yet (since it's not that long since I got the fluid), but from what I've done with it I can say that it's easy to work with.
    Conclusion
    I usually do all my testing as described above: Open test-rig, only one heating component in the loop, etc. This is to make sure that error margins remain as small as possible.
    Reading these test-results, you might be thinking: "What the hell should I do with a coolant that only has an advantage over water when I use tiny radiators? I like BIG radiators!"
    To this, I reply: "Yes, so do I. But you might also like multiple GPUs, overclocking and cramming all you hardware and cooling inside a case."
    What I'm trying to say with this is that I can imagine the Nanofluid showing significant benefit in systems with high heat-loads. In a multi-GPU-setup, fluid-temperatures can reach the kind of hights that Nanofluid benefits from in no time. I'd be very interested in seeing the Nanofluid's performance in a real life system with very high heatload as opposed to a test-rig. Unfortunately, I don't have such a system (sponsor me! ).
    Apart from the temperatures, there's one more thing to consider with Nanofluid: It allows you to fill your loop with a completely white, opaque liquid. It looks very nice and certainly doesn't have a negative impact on the temperatures. As much can't be said of many flashy UV- color-additives.
    I leave you with some pics showing the loops filled with Nanofluid.
    Hope you enjoyed reading. Cheers,
    Shane
    P.S.: Here's the link to the original, German article on DeXgo.
    UPDATE: New results from a mini-test here.
    Xtreme Mentor
    Sep 2006
    I'm actually thinking of doing a WC rig for my next build. I was also thinking of doing it right to the nines, and making it Canadian themed in all red and white. This nano fluid would be fantastic. Availability? Price?
    For my part I know nothing with any certainty, but the sight of the stars makes me dream.
    Jul 2008
    Nice idea for a canada-inspired rig!
    Availability: Don't know.
    Price: Don't know.
    Ask relttem via PM, he knows more than me. :-)
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    that is bizarre
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Banned
    Jun 2006
    in a Red Rage D....
    HES thats a nice colored liquid you have there...
    nice results too...
    i need my glass of milk now... goin to raid the fridge...
    Moderator
    Mar 2006
    Quote Originally Posted by Nanometer View Post
    that is bizarre
    How?
    Xtreme Mentor
    Jun 2007
    Chicago
    Thanks for the results!.
    It seems from the radiator temp results (cpu link isn't working) that this fluid might work wonders for those that are limited to a single radiator/single fan setup.
    Asus P6T, I7-920, 6gb ocz xmp, 4890, Raid 0-1 Terabyte, full watercooled - Triple Loop 5 radiators
    Xtreme Mentor
    Jun 2007
    Chicago
    screen captured and image shacked the cpu results
    Jul 2008
    Thanks for pointing that out, Eddie! (How could I not notice that myself?) I reuploaded and replaced the link. Now it seems to work again.
    I hope to get the chance to do some long-term testing with the Nanofluid to check for things like coloration, corrosion etc. But it's quite difficult since I'm constantly changing loops and setups for new tests. Maybe I can run the Nanofluid on a different system for a while. Has anyone else here done long-term testing?
    Nov 2007
    Illinois
    A shame they don't use additives that have an oligodynamic effect. That would effectively make it a perfect liquid. Alumina isn't antibacterial, no?
    E7200 @ 3.4 ; 7870 GHz 2 GB
    Intel's atom is a terrible chip.
    Xtreme Mentor
    May 2008
    cleveland ohio
    any one willing to try cooking oil like canola, soy bean, vegetable ?
    I know it sounds weird but it's oil.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    Xtreme Mentor
    Jun 2007
    Chicago
    What exactly is nano-fluid made out of? I once saw a watercooling setup on ebay that had pre-filled barium inside.
    Apr 2005
    Best I can discover from my research, it's micro-sized aluminum oxide (once it has oxidized fully, it's nonreactive-we call this sapphire when it gets bigger) in solution in water.
    I wanna play with some for Mithril. A white loop and a black loop would be awesome...
    Nov 2007
    Illinois
    Alumina fluid (1 um) used for polishing applications is qualitatively quite similar. But they claim sizes in 30-40 nm range, more than an order of magnitude smaller.
    Xtreme Mentor
    Jun 2007
    Chicago
    Hmm.. if it does contain aluminum, wouldn't it be bad for copper watercooling? I'd have to see the long term effects.
    Nov 2007
    Illinois
    It's a ceramic, so you won't have free ions floating around.
    Apr 2005
    That would make it a microabrasive, though...
  18. #18
    Never go full retard
    Feb 2008
    Vegas
    Nice testing HES!
    For those wondering about longer term loop conditions...
    I did run Nanofluid for an extended period of time, and I will say the tube staining was quite bad. I ended up having to clean every component in the loop including fittings to get the residual nanofluid off.
  19. #19
    Apr 2005
    Still got your stuff, skinnee? I'l take it off your hands...
  20. #20
    Xtreme Cruncher
    Jul 2007
    @ the computer
    i'm gonna pour milk in the loop and call it nanofluid
    i wonder how milk will compare to water....
    [SIGPIC][/SIGPIC]
  21. #21
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by [XC] Kayin View Post
    Thats what I was getting at in the other thread.. never really got a reply that quite satisfied me but I didnt want to push the issue. It probably wouldnt be an issue given the particulate size though, if anything it would have a polishing effect.
    All along the watchtower the watchmen watch the eternal return.
  22. #22
    Aug 2006
    Oklahoma
    HRMM? I like milk.
    I may have to order clear tubes and get some of that.
    _______________
    Q66@3.8ghz
    Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
    4890,s CF Dual loop rocketfish case.
    ^^^^^All shaken, (from the earthquake) not stirred^^^^^
    Quote Originally Posted by Vapor View Post
    There's a lot less voodoo in watercooling than is assumed
    The only thing future proof in electronics, is the electricity itself.
    Any one who relies on only one source of information is a fool.
  23. #23
    Apr 2005
    STEvil, is that what it turned out to be? If so, I can get the stuff, I bet...
  24. #24
    Xtreme Mentor
    Sep 2007
    Ohio
    Quote Originally Posted by HESmelaugh View Post
    Thanks for the post. Neet stuff!
    Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
  25. #25
    Mar 2006
    Los Angeles CA
    Quote Originally Posted by demonkevy666 View Post
    Oil has hugely inferior heat transfer and capacity properties compared to water.
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
