I curious how the new Nehalems are doing compared to other multicore/Dual processor systems
Asus z7s with 2x Xeon L5410@2,8Ghz, Vista 64, 4x2Gb FBDimm
iMac 24''
BNDMOD @ Cruz Alta (Cba.) Argentina
Intel skulltrail platform @4400 aircooled.
2x 9775 exreme edition
2x 2gb kingston fbdimm
geforce 9800gx2
Nehalem UP, still at stock.
Single- and multicore scores, and multicore speedup are completely off tangent due to the Nehalem quirks.. One, the single core runs at a higher frequency than all the cores do due to Turbo mode. Two, Hyper-Threading. So Hyper-Threading is actually yielding more than 0.11x higher thread parallelism, it's just that the one core is clocked up when it works alone so that number is useless.![]()
W7 Home Edition 64-bit SP1
24/7 setup:
Motherboard: Asus Maximus IV Extreme B3
Bios: 1303
Cpu: Intel 2600k 3,4@4,7Ghz stabile with Aquaduct 360 eco+
Gpu: 2x HD5870 1024Mb CF
Ram: 2x4Gb G-Skill Ripjaws 1600Mhz CL7
Hdd: 1TB and 80gb SSD
Psu: NZXT 1000W
Cabinet: NZXT Phantom white
Screen: Samsung Synchmaster P2450 24"
Mouse: Logitech G9x
Mousemath: Icemat.com
Keyboard: Logitech G19
3DMark with 24/7 settings:
3DMark06: P34038
3DMark Vantage: P32440
3DMark11: P8159
5.0Ghz :
3DMark11: P9159
5.2Ghz settings and CrossFire:
3DMark06: P36917
3DMark Vantage: P36015
3DMark11: P9080
here's my QX9650 and 4.4Ghz vs i7 920 at 3.7Ghz no turbo
Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
LSI series raid controller
SSDs: Crucial C300 256GB
Standard drives: Seagate ST32000641AS & WD 1TB black
OSes: Linux and Windows x64
just a qwick test whit a singel qx9775.
need a beter psu to use the second qx9775.
all @ stock, mem ar 4 x 1 gb kingstone @ 319,2 mhz, 5:4 , 5-5-5-15-20
how do you test with cinebench? do you just push start all tests? this is what I get and it looks weird. My setup is
CPU: intel e6750 2.66ghz
Mobo: gigabyte p35 ds3r
Gfx: 320mb evga 8800gts
RAM: 2gb crucial ballistix at 666 mhz 4-3-4-12 (stock can't really remember the timings)
I got:
2217 - Rendering 1 CPU
5198 - Rendernig X CPU
1.91 - Multiprocesser speedup
OpenGL - 117 (The opengl one is really low...)
Edit: NVM! Just realized there's no OpenGL support for Windows 7. What about the CPU scores?
Btw I"m on windows 7 is that maybe why...
crazlunatic, you need to post scrteenshots when posting benches. Just click "Run All Tests". Run it at default settings. You can OC if you like. That's up to you how far you wanna push it. Hope that helps you. BTW, Win7 is a beta. There's no real reason to run benches on beta's as there is nothing to compare them to. They will have bugs with no fixes, and any comparisons drawn would just be guessing. I;d install XP or Vista or both and run these benches. You want to bench with release software. Beta's could cause anything.
Now here is one I just did, and wow are those 8 threads a beast with this program...
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
CINEBENCH R10
Tester : shane
Processor : Intel(R) Xeon(R) CPU X5450 @ 3.00GHz
MHz : 3.6
Number of CPUs : 8
Operating System : WINDOWS 32 BIT 6.0.6001
Graphics Card : ATI Radeon HD 4800 Series
Resolution : <fill this out>
Color Depth : <fill this out>
Rendering (Single CPU): 8990 CB-CPU
Rendering (Multiple CPU): 56769 CB-CPU
Multiprocessor Speedup: 6.31
Shading (OpenGL Standard) : --- CB-GFX
Thats with the R11 Engine,
this is base r10
CINEBENCH R10
Tester : Shane
MHz : 3.6
Number of CPUs : 8
Operating System : WINDOWS 64 BIT 6.0.6001
Rendering (Single CPU): 4424 CB-CPU
Rendering (Multiple CPU): 25876 CB-CPU
Multiprocessor Speedup: 5.85
so to compare, r11 32bit is almost double what r10 is in 64bit.
Asus Z7s WS
2 x5450 Xeon @ 4.015ghz
Quad channel DDR2 FBDIMM 8GB
2 ATI 4850 1gb in Crossfire
4 250gb SataII in Raid0
1TB SataII
Sata DVDRW
BluRay-Rom
Windows Vista Ultimate x64/OSX Leopard 10.5.5(Video cards dont work correctly)
Competing in "The Raptor Bowl", over at The Raptor Pit, and came up with this last night on water cooling...
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
Here is mine:
Asus Maximus Formula (Rampage Conversion Bios 0403)
Q6600 G0 stepping@4.05 Ghz
8GB G. Skill 1066 @ 1081 Mhz
EVGA 280 GTX
Auzentech Prelude
2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
Thermaltake Toughpower 1200W
DTek Fuzion V2 in a custom CPU only water loop
Coolermaster Stacker 830
Hanns-G 28" widescreen
Klipsh Pro-Media 2.1
G15 Keyboard and G9 Laser Mouse
Q9650 @ 4.2GHz , Kingston Hyper-X 4GB @1117MHz ,P5Q pro turbo , HD5770 crossfire , Custom cooling .
I may as well jump in here with my Quad !!!!
4.2 470fsb and 2gb of ram at 470 4-4-4-12
I have to retest now i have some GOOD RAM
edit of topic but i see my 2900xt is scoring higher in the openGL everone else's cards and there is 280gtx's in some of the rigs whats gives there !!!!!
this is whit 2 qx9775 @ stock
^^^ Um, this section is call "Xtreme Benchmark" - please keep stock scores out of here (regardless how impressive they look)![]()
Heat Team IRONMODS
Here's my Phenom II 940 @ 3.75Ghz (NB @ 2500, ram at 500Mhz 4-5-5-12).
--Matt
My Rig :
Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
HMM, looks like Rol-Co's 32,282 is the number to beat yes?![]()
