XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 11-22-2008, 08:59 PM   #1
tbone8ty
tbone8ty's Avatar
custom Xigmatek S1283 AMD mounting bracket
in the process of making a custom mounting bracket for my S1283 so i can mount it vertically on my AMD mobo.
did it on a very old bridgeport milling machine with probably the wrong endmill. plus it didnt have a digital read out. finished up with a hand file.
then i had to file down the screw heads because the out diameter of the head was to big and hit the sidewall of the heatsink. im sure other people have run into this problem using the intel mounting brackets.
gotta drill 4 holes next
__________________
Athlon II X4 620 @ 3.25ghz 1.4v Xigmatek s1283 cooler
Asus M3A32-MVP (1903 bios)
Corsair Dominator 8500C5D (4x1gb) 5-5-5-15-22 2.1v
XFX 5770 @ 1000/1250/1.2v (V1 cooler)
Corsair 520hx psu
CM690 PowderCoated Candy Red
Win7 64bit
http://farm5.static.flickr.com/4009/...b1b080f4_b.jpg
tbone8ty is offline   Reply With Quote
Old 11-24-2008, 06:03 AM   #2
Cooper
Xtreme Workhorse
Cooper's Avatar
Material and thickness ? And what Xigmatek model is it ?
Cooper is offline   Reply With Quote
Old 11-24-2008, 09:31 AM   #3
Kaldor
Looks to be Aluminum around 1/8" and probably a 1283. But Im just guessing.
Kaldor is offline   Reply With Quote
Old 11-24-2008, 10:10 AM   #4
Gurr
That looks good, I wish I had access to a milling machine so I could do it.
Gurr is offline   Reply With Quote
Old 11-24-2008, 11:55 AM   #5
Sgrios
Send a message via MSN to Sgrios
then i had to file down the screws because the out diameter of the head was to big and hit the sidewall of the heatsink. im sure other people have run into this problem using the intel mounting brackets.
Looks great Tbone. Do you plan on lapping it?
Sgrios is offline   Reply With Quote
Old 11-24-2008, 12:38 PM   #6
illidan
betrayed
illidan's Avatar
Send a message via MSN to illidan
it's hard to lap dht.. easy to damage heatpipes
__________________
illidan is offline   Reply With Quote
Old 11-28-2008, 09:11 PM   #7
tbone8ty
tbone8ty's Avatar
aluminum, 4.5" x 2.5" x 1/8" and i put the model# in the title ;-)
thanks guys ill be down with it soon and post pics
__________________
Corsair 520hx psu
Win7 64bit
Old 11-30-2008, 12:59 PM   #8
tbone8ty
tbone8ty's Avatar
drilled holes and polished it alittle
working on backplate and mounting screw/nut setup....
__________________
Corsair 520hx psu
Win7 64bit
Old 12-01-2008, 06:29 PM   #9
tbone8ty
tbone8ty's Avatar
backplate issue
fixed!
mounted: it doesnt cover the first DIMM slot! horrah!
whoa close call!
looks pretty sexy
i used thermalright paste. i wanted to try it out compared to the antec formula 5 paste i was using.
I haven't done any testing yet but its idling at 32C right now, which is alot better than the zalman 8700 which idled at like 40C
over all im very please with this bracket, i feel more comfortable being able to tighten down the heatsink with screws than using the stock AMD clip.
plus now that it doesn't cover my DIMM slots i can upgrade my ram by buying another 2 x 1gb kit instead of having to buy a 2 x 2gb kit
Woot!
__________________
Corsair 520hx psu
Win7 64bit
Old 12-17-2008, 08:45 PM   #10
tbone8ty
tbone8ty's Avatar
fan rpm at 1250.....cpu @ 3.0ghz with 1.3875 Volts........ idles at 38-40C
OCCT run for 1hr.... never got above 58C
__________________
Corsair 520hx psu
Win7 64bit
Old 12-18-2008, 11:03 AM   #11
DualCore
DualCore's Avatar
nice , put a list of materials that u use in this
__________________
AMD X2 6000+ | Xigmatek Achilles
DFI Lanparty DK 790FX-M2RS | 2x2 GB Corsair XMS2 800mhz
Sapphire ATI 4870 | Acer Al2223W 22"
On the table... | Corsair TX750w
SoundBlaster X-FI Xtreme Music | Z-2300 thx
OVERCLOCKERS GUATEMALA
DualCore is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
