Results 1 to 5 of 5
Thread: Problems with Asus Maximus II Formula SupremeFX X-Fi
    Xtreme Enthusiast Shocker003's Avatar
    Jul 2007
    Germany
    Hi guys,
    Does the Asus Maximus II Formula SupremeFX X-Fi audio card work on any other motherboard?
    My boards canīt detect the card when it is installed in the pci-e 1X slot. Is the card dead or is there a way to get it to function. Thanks for the advice in advance.
    MAIN RIG--:
    ASUS ROG Strix XG32VQ---:AMD Ryzen 7 5800X--Aquacomputer Cuplex Kryos NEXT--:ASUS Crosshair VIII HERO---
    32GB G-Skill AEGIS F4-3000C16S-8GISB --:MSI RADEON RX 6900 XT---:X-Fi Titanium HD modded
    Inter-Tech Coba Nitrox Nobility CN-800 NS 800W 80+ Silver--:Cyborg RAT 8--:Creative Sound BlasterX Vanguard K08
    Xtreme Cruncher
    Jan 2008
    Finland
    This card will only work in your Asus Maximus II Formula.
    Intel i7 2600k, Asus p8p67 EVO, Thermalright Archon, G.Skill RipjawsX 8GB, Asus EAH6970 DCII, Corsair AX850W, Asus xonar essence ST, Coolermaster HAF 932,
    Crucial C300 128GB, WD Caviar Black 1 TB, Samsung F3 1TB.
    The world needs your support.
    Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
    Jul 2007
    Germany
    Quote Originally Posted by nemowish View Post
    Thanks for your reply. Do you know if there is a way to get it working on another motherboard, like hacked driver or sometime.
    MAIN RIG--:
    Oct 2005
    MA/NH
    question about this mobo/card, as far as drivers are concerned, which ones can you use ? can you use the ones off of creatives site? or does it have to be the asus ones or some form of the mobo xf-i driver ?
    Mpower Max | 4770k | H100 | 16gb Sammy 30nm 1866 | GTX780 SC | Xonar Essence Stx | BIC DV62si | ATH AD700 | 550d | AX850 | VG24QE | 840pro 256gb | 640black | 2tb | CherryReds | m60 | Func1030 |
    HEAT
    Aug 2008
    Edmonton, Canada
    normal drivers wont work, you would need hacked drivers if they are even out there (not worth the trouble). i tryed using my Striker 2 formula sound card on my older computer but i couldnt get it to work. tryed every diver i found. and different slots,
