XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Benchmarking
Reply
Old 11-21-2008, 12:10 AM   #1
Tetedeiench
Talking OCCT Perestroika - 3.0.0.b04 released ! Stable : 2.0.1
As asked by alot of forum members, here's a thread dedicated to OCCT and its future updates. I'll post betas and stable versions here !
Please feel free to post comments, bug reports, as well as evolutions you'd like to see in OCCT. I'm usually very open to those suggestions, and you'll almost always get an answer
Oh, please excuse any spelling mistake i make, English isn't my native language
For people working on PC news website and such : PLEASE DO NOT MAKE A NEWS ON BETAS ! I prefer you to spread the info about the stable versions only
OCCT PT has been around for 2 years now, and was recently almost completly redone. It gave birth to :
OCCT PT 3.0.0.beta !
What's new ?
5 Tests
  • CPU OCCT : The classical OCCT CPU tests. The modes "CPU, RAM, and Mix" have been renamed to match more closely their roles to "Low, Medium and Large data sets".
  • Linpack : The very same test that Intel Burn Test, based on an Intel library, that will make your CPU hotter than never before.
  • GPU 3D : OCCT GPU, a home-made 3d program that will make your GPU hotter than anything else (even furmark), and sports an error-checking mode just as ATITool.
  • GPU Memtest : A GPU memory memtest based on CUDA. Very useful as well, but in practice, it is better at detecting manufacturing errors, and not overclocking errors.
  • Power Supply : This test is actually Linpack combined with OCCT GPU. It aims at loading your power supply, and results shows that it uses 20% more power than Crysis and 25% than 3dmark BEWARE, THIS TEST IS REALLY HARD ON YOUR POWER SUPPLY, IT COULD MELT IT EASILY ! DO NOT USE IT IF YOU HAVE A "NO NAME" POWER SUPPLY !
GUI
  • Brand new GUI, with alot of options added
  • Help panel : just move your mouse
  • Modularity : you can hide/show the Monitoring/Sysinfo/Help parts
Graphs
  • Graphs have been revamped - they'll show the test configuration in the titles (Resolution for the GPU 3D test, etc...)
  • Another line has been added showing the CPU Usage on CPU tests and Power Supply, and the FPS on the 3d test !
Monitoring
  • Engine was updated, should support more cpus
  • Added GPU temperature monitoring and autodetection
  • The CPU Usage displayed is now instantaneous (just as the task manager) instead of the average since the starts of the test - more meaningful, especially since the graphs shows the CPU usage in time.
And many, many things i am probably forgetting.
KNOWN LIMITATIONS
  • The linpack test has a 64 bits mode, but no detection of a 64 bits CPU and OS is actually don. it'll be added later on.
  • The GPU MemTest test is supporting only one Graphic card
  • There's currently no way of launching the 3d test in fullscreen mode. I know this causes some issues on ATI and SLI systems. It'll be resolved later on
  • Translations aren't up to date at all !
Thanks for your help and feedback !
Enjoy !
http://www.ocbase.com/download.php?fileext=beta
Tetedeiench is offline   Reply With Quote
Old 11-21-2008, 12:13 AM   #2
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
Does this version still have a lot of HDD activity? Last version made my HDD having constant "ticking" working noise which was annoying when browsing the internet meanwhile when testing. Older versions didn't use to do that. I guess it's due to the graphs feature which I tried disabling but with no luck.
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is offline   Reply With Quote
Old 11-21-2008, 12:19 AM   #3
Tetedeiench
Originally Posted by RPGWiZaRD View Post
Does this version still have a lot of HDD activity? Last version made my HDD having constant "ticking" working noise which was annoying when browsing the internet meanwhile when testing. Older versions didn't use to do that. I guess it's due to the graphs feature.
This is due to the monitoring engine. This tick happens whenever you have a SMART data access - unfortunatly, i can't do anything about it.
Old 11-21-2008, 12:21 AM   #4
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Can't you make the feature optional? ie checkbox if you want to use the monitoring engine or not. I don't need it so I'd gladly disable it.
__________________
Old 11-21-2008, 12:21 AM   #5
Tetedeiench
As it is part of the engine i'm using for monitoring : no, it doesn't have this option
Old 11-21-2008, 12:26 AM   #6
revogamer
revogamer's Avatar
does the gpu error testing work with sli?
__________________
revogamer is offline   Reply With Quote
Old 11-21-2008, 12:26 AM   #7
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
OK, guess I'll have to stick to older versions of OCCT and/or Orthos then.
__________________
Old 11-21-2008, 12:29 AM   #8
Tetedeiench
Yes, but in windowed mode only.
That means that if your driver is well-made, both of your cards will be used. However, with ATI cards, window mode = no 3d mode (low GPU frequencies...), and no SLI used, for instance.
In later versions, i'll add a fullscreen mode in order to get around this problem
Old 11-21-2008, 12:30 AM   #9
Tetedeiench
I'll ask the guy behind CPU-Z if he could implement it, i do know it's an issue.
Sorry i can't do anything about that right now, but come back later on, it may be fixed
Old 11-21-2008, 12:31 AM   #10
emoners
emoners's Avatar
@Tetedeiench: i seem to be getting an error when i unzip the file
__________________
Project B.I.L.H.A.T.: ZOTAC® GeForce™ 9300-ITX WiFi Rev.01 (+ Noctua® NC-U6) | Intel® Core2Duo™ E7400 Wolfdale SLB9Y (+ Scythe® Shuriken™) @stock voltages | OCZ® NVidia SLI-Ready DDR2-6400 2x2Gb | PowerColor® ATI™ Radeon HD4770 | Western Digital® Caviar™ Black 1Tb | Silverstone® SG05 | Windows® 7 Ultimate 32-bit
RETIRED:
• DFI® LanParty UT P35-T2R Rev A02 (05/21 Bios) | DFI® LanParty JR P45-T2RS Rev A03 (10/07 Bios) | Intel® D945GCLF2 Little Falls-2 | Intel® Core2Duo E6850 Conroe L723A348 | Intel® Core2Duo E8400 Wolfdale Q746A446 | Intel® Core2Quad Q6600 Kentsfield L723B837 | Intel® ATOM™ 330 | XFX® NVidia GeForce 8800GTX | XFX® NVidia™ 8800GT XT Alpha Dog Edition | Creative® Sound Blaster X-Fi Fatal1ty XtremeGamer Pro
emoners is offline   Reply With Quote
Old 11-21-2008, 12:33 AM   #11
Tetedeiench
I tried it right now, it works flawlessly (using Windows built-in ZIP mecanism, and winrar). I guess you have a corrupted download there Try to download it again
Old 11-21-2008, 12:36 AM   #12
Xope_Poquar
Xope_Poquar's Avatar
Send a message via MSN to Xope_Poquar
I don't like OCCT because it shows that my CPU is unstable when it can run hours with Prime95.
Seriously, love this program, thanks!
Xope_Poquar is offline   Reply With Quote
Old 11-21-2008, 12:56 AM   #13
twwen2
twwen2's Avatar
I like OCCT, nice interface and works well. I'll be keeping an eye on this thread, thanks Tetedeiench!
__________________
Originally Posted by b@llz0r View Post
i didnt have a girlfriend before i got into watercooling....
... now I have a cat.... her name is mittens
HW: E8600@4GHz||DFI JR-P45 T2RS||ATi HD4870||4GB Corsair 8500C5DF||640GB WD6400AAKS||Vista Home Premium x64
WC: EK Supreme||EK-NB S-Max||EK-FC 4870||PA120.3||DDC3.2+Petra's top||EK 150 res
Sense and Sensibility [My build log]: http://www.xtremesystems.org/forums/...d.php?t=201235
twwen2 is offline   Reply With Quote
Old 11-21-2008, 01:02 AM   #14
Tetedeiench
Thanks for your cheers guys !
Feel free to post bugs you found, features you want to add here, i'll be following this post
Old 11-21-2008, 01:04 AM   #15
halo112358
halo112358's Avatar
The concepts behind each test are awesome, when you resolve the dual GPU stuff I'm all over this
halo112358 is offline   Reply With Quote
Old 11-21-2008, 01:07 AM   #16
LOE
Send a message via ICQ to LOE
these guys should really HIRE a designer, I've seen better looking apps 15 years ago
LOE is offline   Reply With Quote
Old 11-21-2008, 01:10 AM   #17
v0dka
Hardware addict
v0dka's Avatar
Thanks for the update, I switched to OCCT some time ago. It just saved tme compared to prime.
But now I'm using Linpack as a primary stability test. It's even faster. any flaws that I dont catch with a couple of Linpack runs will get ironed out eventually.
Great that Linpack is part of OCCT now. Is 32-bit only a problem?
__________________
Antec P180 Mini - DFI JR X58 T3H6 - Xeon W3570 - 6GB G.Skill 1333C7 - TRUE120 lapped & modded - GTX285 - Intel X25-M (G2) & Samsung F1 640GB
v0dka is offline   Reply With Quote
Old 11-21-2008, 01:12 AM   #18
v0dka
Hardware addict
v0dka's Avatar
This is about making a program that works, not looking 1337. Go away.
__________________
Old 11-21-2008, 01:21 AM   #19
halo112358
halo112358's Avatar
I really like the design, it's clean and functional. It gets +1 in my aesthetics book.
edit: don't you have a bridge to hide under? it's daylight out.
Old 11-21-2008, 01:35 AM   #20
LOE
No need to go personal, I do design for living, and I think I have pretty high standards. If you like it - good for you, if you have problems with opinions that differ from yours - I cant help you sorry
There are many many apps out there that have great functionality, hidden behind very "basic" user interface, but the matter of fact is a good looking UI won't make a good app worse - it will only make it better. And this particular UI is full of things that really annoy my eyes, just overall it looks flawed, it might work flawlessly, but visually it doesn't look OK to me. Professional opinion.
Old 11-21-2008, 01:38 AM   #21
Tetedeiench
Absolutly not YOu can use the 64 bit Linpack test, just check the box. But make sure you do that with a 64 bits CPU & a 64 bits OS It's just that right now i don't disable the checkbox if you can't use it.
Old 11-21-2008, 01:42 AM   #22
Tetedeiench
I did hire a designer, making him work on the "CCCP" idea, which has been the idea behind OCCT for years now.
I like it as it is just because it's easily recognizable - you see a big red square in a screenshot, OCCT is there. I'll keep the design as is, with minor modifications, but i like it the way it is
oh, and BTW, i'm alone behind this program, and it is not my main job, i do it for fun only ( i have a full-time job and a girlfriend to deal with while developing).
I find the app good looking enough the way it is - it is much better that the grey-ish apps you see around, or the interfaces of Prime95 and orthos... Just say you don't like the design, not that i should hire a designer, and i guess people will understand more clearly what you said
Old 11-21-2008, 01:44 AM   #23
bowman
bowman's Avatar
A new designer, what, so it could look like the utilies mobo manufacturers ship with their products, and MP3 playback software from the 90's? ..no thanks. Looks great as it is.
Anyway, program seems to work flawlessly from some small testing.. But here's a quibble, and maybe I'm just blind, but the LINPACK test doesn't show the measured GFLOPS. That's kinda half the appeal of running LINPACK.
__________________
bowman is offline   Reply With Quote
Old 11-21-2008, 02:12 AM   #24
twwen2
twwen2's Avatar
A hard day at work?
Sure you're entitled to your opinion, and so are the rest of us. I reckon it looks fine. Nice and simple, i know where everything is. But most importantly, it just works.
__________________
Old 11-21-2008, 02:13 AM   #25
WheelMan
Talking of GFLOPS, u should implement a FLOP-test for GPU
and/or the whole system, like the PSU-test.
__________________
Laptops and gaming is like riding a tricycle through Tour de France..
WheelMan is offline   Reply With Quote
Reply
Tags
occt
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
