Hey
Just got this rig
Q9550 (E0)
P5Q-E -1406 Bios
PC2-6400 OCZ Reaper 4-4-4-15
BFG 9800 GTX+ OC
Asus 900 Case
Tuniq Core Contact (blowing up with the antec case fan)
Corsair 520w PSU
I have the following settings
I cant get better than 475. I'd like to hit higher, I'd love to his 500fsb which i know is alot to ask for. But E0 is supposed to hit 4ghz to 4.4ghz right?Code:AI Overclock tuner : Manual CPU Ratio Setting : 8.5 FSB Frequency : 475 PCI-E Frequency : 100 FSB Strap to North Bridge : 333 DRAM Frequency : DDR2-951 DRAM CLK Skew on Channel A1 : AUTO DRAM CLK Skew on Channel A2 : AUTO DRAM CLK Skew on Channel B1 : AUTO DRAM CLK Skew on Channel B2 : AUTO DRAM Timing Control : Manual 5-5-5-18-3-50-6-3 DRAM Static Read Control : Auto DRAM Read Training : Auto MEM. OC Charger : Auto AI Clock Twister : Auto AI Transaction Booster : Manual Common Performance Level : 10 CPU Voltage : 1.36875 CPU GTL Voltage Reference (0/2) : 0.610 CPU GTL Voltage Reference (1/3) : 0.650 CPU PLL Voltage : 1.52 FSB Termination Voltage : 1.32 DRAM Voltage : 2.20 NB Voltage : 1.38 NB GTL Reference : Auto SBridge Voltage : 1.20 PCIE SATA Voltage : Auto Load Line Calibration : Enabled CPU Spread Spectrum : Disabled PCIE Spread Spectrum : Disabled CPU Clock Skew : Delay 400ps NB Clock Skew : Delay 400ps CPU Margin Enhancement : Optimized
I ran IBT for 5 loops on the above settings and it passed. Ill post screenie later.
Saaya yupp, I agree
flashed to the newer, modded bios
