Thanks to a good friend, finally receive my I7 965 today
Since the 1366 socket kits for my cascades did not arrived yet, here are some Air OC action
Used the GB EX58-UD5 and the Tuniq Tower with "special mounting kit"that you can see in this photo:
OK - let's start with SuperPI 1M with 4 cores:
Less than 9sec quite easy![]()
Can it go even far with 2 cores?? - let's check it:
4.7 GHz Air
How about bandiwth with low timmings - 7-7-7-20 :
OK, let's turn on the 4 Cores and the HT .. does it run 2006 at 4.400Mhz .. oh yeh
8316 Air
And let's spee if run WPrime at 4.4 with 8 threads ...
A quick run in Aquamark with low clocks on vid cards - 320K easy
OK, that's it for now ...
Next I may give a try on the Rampage II .. I also love to test the EVGA X58 but they are still not available here
If the 1366 mounting kit arrived until Friday, I hope have some Cascade action in the Weekend ..
This CPU definitively have some potential
