11-16-2008, 08:51 PM
#1
Xtreme X.I.P.
Core i7 Vdimm/VTT Graveyard :D
So, i7 launched and we are all sufficiently scared of using more than 1.65v vdimm alright. Looking at the real world performance boost from running high mem clocks over easily achievable clocks with 1.65v vdimm or even less, it seems high clocks and hence high vdimm isnt needed for gaming and 24/7 at all...
but THIS IS SPA... XtremeSystems!
I know there are quite some people out there pushing for more, a lot more
Please share your results here and i will do my best to update the first post and summarize the experiences. Did you kill an i7 with high vdimm? What vtt and vcore did you use? for how long? Are you running high vdimm without any problems? how high? whats your vtt? whats your vcore?
Thanks!
1.90v vdimm / 1.20v vtt = dead after 1 day (Engineering Sample CPU rev B) - rev B?
1.90v vdimm / 1.20v vtt = dead after 10 days (Retail 965 rev C) - most likely freak accident/bios/board bug
2.25v vdimm / 1.45v vtt = dead after 1 day (Engineering Sample CPU rev C) - buggy board?
1.88v vdimm / 1.50v vtt= dead after 1 week (Retail 965 rev C) - most likely freak accident/bios/board bug
1.65v vdimm / 1.20v vtt = ok forever according to intel
1.80v vdimm / 1.30v vtt = ok for 7 weeks
1.95v vdimm / 1.40v vtt = ok for 5 weeks
2.05v vdimm / 1.45v vtt = ok for 5 weeks
2.05v vdimm / 1.36v vtt = ok for 6 weeks
2.00v vdimm / 1.50v vtt = ok for 8 weeks (cold)
2.00v vdimm / 1.60v vtt = ok for 2 weks
2.00v vdimm / 1.65v vtt = ok for 8 weks
2.25v vdimm / 1.70v vtt = ok for 4 weeks
2.30v vdimm / 1.35v vtt = ok for 2 week (cold)
1.75v vdimm / 1.75v vtt = ok for 1 day (cold)
Conclusion:
Its been 6 months since Intel launched i7 and there have been less than half a dozen reported dead cpus.
Considering all the torturing those chips go through with ln2 cooling and vcores in excess of 1.7v, vdimm in excess of 2.2v and vtt in excess of 1.7v, this is very good news.
1.6v vcore, 1.6v vtt and 2v vdimm
These seem to be 100% safe, as long as the processor is cooled well enough.
I think even higher voltages are fine but there hasnt been a lot of feedback of people using high voltages 24/7 so far.
For extreme cooling there seems to be almost no limit as to what voltage is ok, as long as the cpu still scales, its probably fine
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
11-16-2008, 09:21 PM
#2
Brotherhood
nice thread saaya......I will report quickly...
11-17-2008, 06:28 AM
#3
OCTeamHungary
nice thread saaya, looking fwd to see some feedback of 2.0v+ results on C0 after some time
11-17-2008, 06:59 AM
#4
D-m.o.s.t
Don't think i can adjust that low saaya , 1.1 vtt?
__________________
s-pi 1M Air 8.625
11-17-2008, 07:02 AM
#5
very interesting topic
i think vtt is vcore.
__________________
Core i7 920, Asus Rampage 2 Extreme , 6GB OCZ reaper 15000, EVGA 260GTX SSC, X-Fi Xtremgamer
11-17-2008, 07:05 AM
#6
I am Xtreme
I hope you are wrong AlfaBoy :p
__________________
Question : Why do some overclockers switch into d*ckmode when money is involved
11-17-2008, 07:23 AM
#7
X.I.P.
Interesting one... Saaya!
Can update 2moro  tho I hope it stays alive coz I got one more board to finish
__________________
p e a c e
11-17-2008, 07:25 AM
#8
D-m.o.s.t
vtt is qpi voltage, 1.20 is minimum at the p6t and rex2
__________________
s-pi 1M Air 8.625
11-17-2008, 07:58 AM
#9
isnt vtt FSB voltage?
__________________
Corsair HX1000
MOBO's
DFI UT X58
CPU's
I7 920 D0
Cooling
Chilled by chilly1 SS, or CUST W/C 3X120MM BIXII, Duniek DICE pot
Cases
Cooler master HAF 932
Ram
Kingston 2000 Cas8
Gpu's
GTX 285,
11-17-2008, 08:12 AM
#10
isnt FSB gone?
I'm running @ 1,85 for 2 day's now... QPI voltage at 1,4v
11-17-2008, 08:27 AM
#11
Xtreme Owner
Up to 2.3v for the past few months on several chips, many many hours.
No chip degradation, it wants to go faster.
I have had one on the Vapo for two months now, its at 2vmem
still scared?
11-17-2008, 08:29 AM
#12
yes.
11-17-2008, 08:30 AM
#13
tried that for regular testing..
vtt : 1.24v
vcore : 1.48v
vdimm : 1.84v
no problem at about 10hours run..
here what i see from intels datasheet,with a %10 range, i guess pushing vtt to 1.5v and vdimm to 2.1v will not be problem  [DO NOT TRY because i said]
11-17-2008, 10:57 AM
#14
Xtremely Lost
Sorry for cross posting....but:
Originally Posted by Astratuner
....big snip....Note the most important thing: While Asus and Intel (rightly) scare everyone (read: uneducated) into thinking that 1.65V on the DRAM voltage should be the absolute limit before you reach for the fire-blanket, all that's really needed it to obey this: keep the CPU uncore voltage within 0.5V difference of the DRAM voltage and there's no problem. Over this potential difference and youll greatly increase the chance of CPU death, but it certainly won't happen instantly in a big ball of fail fire if you make a mistake.....little snip....
Can anyone confirm or deny this?
Quoted from here, page 5, post #120.
11-17-2008, 11:16 AM
#15
HWbot Crew / X.I.P.
Chips used: 940/ 2x 965 (all C0 stepping)
QPIV: ~1.45V (real) all the time.
VDram: 1.7V-2.05V depending of usage (2.05V is for benching and I used this voltage 15+ hours this weekend)
Hundreds of hours of basic testing without any problems in past two months.
I would like to see others post same results, so we can cut the wings of this rumor, which is based on user reports from stepping B era.
I do know that there is reason for 1.65V limitation and you don't need much more in 24/7 use. Do not go over that limit if you don't feel that you have to.
That is the most easiest solution and you know that the risk is your own.
__________________
AOCC2008 WW #5, MOA2008 EU #5, GOOC2008 WW #1, GOOC2009 WW #3, MOA2009 EU #4, MOA2009 WW #4, GB TweaKing #"5" (4,10), Ditech International OC #2 / #2, ASUS ROG OC Showdown # semifinals
11-17-2008, 12:48 PM
#16
my87csx481 I'm doubt about but it is true. My friend told me it after some Intel presentation in Ukraine.
__________________
E8500 Q822A @6.16Ghz | 2*512 GRM,GCT,GKX;2*1Gb FatBody | Biostar I45 | 2*Sapphire HD2900XT/PRO 1024Mb DDR4 | FSP 700w
11-17-2008, 08:33 PM
#17
Xtreme X.I.P.
VTT is the Uncore voltage that powers the L3 cache, memory controller and a part of the QPI controller, plus the integrated power management processor it seems. Default vtt depends on the cpu and is assigned depending on 3 vid pins. It seems to be between 1.1 and 1.2v, though most mainboard makers seem to ignore this and set 1.2v always, which results in up to 1.25v on some boards.
still scared?
thanks charles,
roughly how many hours 2.3v have you run and with what vtt?
and roughly how many hours 2.0v with what vtt?
This was all below zero though, right?
vtt : 1.24v
vcore : 1.48v
vdimm : 1.84v
thanks for posting the pic
thats the theory, so yes, 2v vdimm should be fine 24/7, but thats apparently only with high vtt.
Our engineers killed 2 cpus with 1.9v vdimm and stock vtt after just a couple of hours of memtest86+
then again those were B stepping chips...
roughly how many hours with 2v vdimm and 1.45v vtt?
no offense, but just because your friend heard this at some intel presentation doesnt really make it official
thanks for the feedback so far guys!
__________________
11-18-2008, 04:14 AM
#18
Team ID - Indonesia
Nice saaya
My testing so far with boards from Intel Smackover and GIGABYTE X58, always using vdimm 1.8 - 1.95 volt 3 channel, and vtt 1.35 - 1.4, QPI 1.45 mostly setting i used. Using for several weeks until now and looking good.
11-18-2008, 04:26 AM
#19
Xtreme Owner
My notes from another thread.
vcore ~1.5v, this is a "leaky" high IDV chip, scaling up with higher voltage is possible at a cost of runaway amp phenomena.
vmem ~2.2v for benching 2v on Vapo, compensate voltage with cooling to be safe.
vqpi ~1.35v depending on the board/bclock, upwards of 1.55v if I am pushing bclock, I run a low bclock so I usually leave it on stock.
vmem is the secret to uclk, 2.2v gets you 4.7Ghz ulck. uclk is also known as uncore.
general ratios
Stock QPI on i7 965 is x48 @ 133 bclock, if you raise the bclock to 160ish you would need to drop qpi ratio to X44 to continue raising the bclock to 180ish, drop qpi again to X36 again and that will get you out the theoretic max bclock of 220. That is not set in stone, some chips/board combos have exceeded these numbers but this rule is pretty close to what you will see on C stepping.
The uclk ratio I prefer to use is (the lowest possible) 1:2 of my ram speed (uclk runs at twice the speed of memory) and at lower speeds there are plenty more ratios to scale higher without running the sick memory speeds that I do, this is a huge gain in performance but for me it requires a lot of vmem and high end memory to run upwards of 2300Mhz (4700Mhz uclk) the memory controller has exceptional is its stability at this speed, I have not reached top speed and it will take even faster ram and more vmem to achieve that.
Runaway amp phenomena, I hook an amp meter to the four yellow wires on eight pin power cable that connects near the CPU. Watching this you will see that yes you can keep scaling up with more voltage but your chip has a limit with all cores loaded that it will runaway on amps till it crashes. I know exactly what range to stay in with cores loaded to know not to hit this runaway threshold. Keeping vcore down and disabling HT lets me run at the chips max speed, HT has an added power load on the CPU, disabling it helps gain critical Mhz.
11-18-2008, 10:33 AM
#20
Maybe raising vtt from 1,1 to 1,2 prevent to kill some i7, when raising the vdiimm, i believe that may exist some combination from vtt and vdimm to prevent killing i7 but isn't easy to now, i which this thread help us
It is very strange to see max vcore 1,55 in that image, something strange i fond in the P6T is the minimum PLL is set to 1,8 with 920.
__________________
11-18-2008, 10:46 AM
#21
Xtreme Guru
nevermind, got my answer.
__________________
11-18-2008, 11:07 AM
#22
Captain Jinx
Cue BenchZOwner's 24/7 2.2v Prime95 marathon.
__________________
I put on my shoes before I put on my pants.
11-18-2008, 12:14 PM
#23
HWbot Crew / X.I.P.
I haven't heard, that there is any dead C0 stepping cpu's. (High Vdram)
If there is, please tell us how it happened.
And Sascha.. 2.05V was used 15+ hours in my last weekend bench session. No problems.. nothing. 1.45V VQPI is for 24/7 and memory voltage between 1.8-1.95V.. no signs of problems so far.
__________________
11-18-2008, 10:08 PM
#24
Xtreme X.I.P.
Originally Posted by Benny Lodewijk
Nice saaya
thanks
so you ran 2.2v vdimm with 1.35v vtt?
yeah looking forward to benchzowners high voltage marathon sessions on i7!
nope, havent heard of any at all...
ok, thanks!
__________________
11-19-2008, 08:13 PM
#25
nobody
I've been testing my retail i7 920(C0 stepping) + MSI X58 Eclipse for 1 straight week now, I'm using 1.35V VCore, 1.38V QPI Voltage, and 1.85V VDimm,
No problems so far , still up & running @ 200 x18 for daily gaming use, OCCT CPU test(8 thread load) 30 min passed
* Well, if there's should be any problem, it's probably the TEMPs, it's so hot that even my Cooler Master Hyper-Z600 with 2 fans(push-pull) only managed to hold the load temps to around 70-ish , I don't know if the Core Temp is faulty, but the Z600 feels hot to touch for me  *
__________________
I'm Just Lucky !
Originally Posted by Lucky_n00b,2004
"The ONLY thing that LIMITS my overclocking is not my cooling, nor my hardware...but ME . That's why I call myself a n00b. "
Originally Posted by Lucky_n00b,2009
I bought my Graphic Cards to play 3DMarks, not Games
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
