Page 1 of 26 123411 ... LastLast
Results 1 to 25 of 645
Thread: Shazza's Modest Mountain Mods Build
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    After months and months of collecting parts, letting them collect dust, and a couple of RMAs later - I have a working computer. This is my second MM build ... the first was a journey (some might say a nightmare) into the world of liquid cooling. This will be an abbreviated worklog, but I did want to share my progress, and posting pics of the project motivates me to keep going to to the next step. Also an opportunity to pick up advice from folks here.
    EDIT: (2/14/09) This project has turned into a monster ... it's no longer a "modest" build, and obviously no longer an abbreviated work log Many parts have been changed out, and it's still evolving.
    Hardware:
    Rampage Extreme
    Corsair HX 1000W PSU - sleeved using murderMod PSYCHOPAK sleeving kit
    E8600 (QX9650 will go in after I'm sure everything is working)
    2 x 2 GB G-Skill 1600MHz RAM
    WD 750 GB 7200RPM HD
    Sapphire 4870X2
    EDIT - this is now an i7 920 build, using an EVGA X58 mb, Corsair 3 x 2GB 1600MHz mem, and nVidia GTX 285 video cards with EK water blocks.
    LC Components:
    changing by the minute ... but here's where we are as of 12/20/08
    CPU Loop: XSPC Acrylic Res Top > MCP 355 > Thermochill PA 120.3 > Swiftech GTZ | Red Primoflex Pro Tubing 3/8" ID 5/8" OD | Bitspower Compression and Assorted Fittings
    GPU Loop: XSPC Acrylic Res Top > MCP 355 > Thermochill PA 120.3 > Danger Den 4870X2 Water Block | Blue Primoflex Pro Tubing 7/16" ID 5/8" OD | Bitspower Compression and Assorted Fittings
    NB Loop: XSPC Acrylic Res Top > MCP 350 > Swiftech MCR 220 > Swiftech NB-Max | Black Primoflex Pro Tubing 3/8" ID 5/8" OD | Bitspower Compression and Assorted Fittings
    Case:
    Mountain Mods CYO, Horizontal MB tray with Duality Front in Black Anodized Al
    Casualties to date (there are sure to be more):
    Striker II Extreme Motherboard
    2 x 2GB of G-Skill DDR3 RAM (bought it so long ago I couldn't find it when I finally started building ) edit: Found the original RAM!
    Rampage Extreme Motherboard - 1st one had issues, 2nd one seems fine
    2 x 8800 GTX video cards - using in other systems, replaced with 4870x2
    GTX water block - user error, somehow stripped the threads in the top when trying to install BP compression fittings - second one OKAY
    2 x 4870x2 video cards - still working, but replaced with GTX 285s
    2ND Rampage Extreme motherboard bit the dust when installing second 4870x2
    A few early photos:
    I said it worked ... didn't say it was pretty
    4870X2 with Danger Den Water Block:
    Swiftech GTZ Water Block - a delight to install
    I use 3DMark06 to see if everything seems to run okay...
    Temps look okay on this temporary loop (CPU and GPU on 1 PA120.3):
    And, before you get all excited, let me make a few disclaimers:
    1) Yes, the tubing is much too long -- this is my setup for leak testing outside the box, which I just set up to make sure everything worked in the case.
    2) The drive bays are sticking out of the case ... kind of a nice look, don't ya think?
    3) Wire Management - a tangled mess at the moment.
    4) Silver Screws on the front fan grills - will be replaced with black
    Banned
    Oct 2008
    Dartmouth NS Canada
    Lookin good Shazza! I saw the 8800 GTX's & got all excited lol. I'm using 3 in my build is why heheh. Are the fans for the rad behind cause I don't see them in the front? Hope you find the missing ram to! Pesky little ram gnomes lol.
    Jan 2005
    Belgium
    That's some nice equipement you've got there mate!
    Oct 2008
    The Curragh.
    Modest? Modest?! You sir, are a LIAR!
    Oh can I have all the old parts you are not using?
    Pwetty pwease!
    ( Looking good so far )
    Aug 2004
    Minneapolis, MN
    Looks good Shazza. Do you plan on cooling the northbridge? Swiftech makes a nice block specifically for that board. Put some love into it and sleeve your cables.
    Moderator
    Aug 2007
    Thanks for the kind words ... this is basically just the start, I know there is lots left to do.
    lol ... "Let me clarify," she says; "Modest in the sense that it is not EXTREME. While I'm fortunate to be able to buy good hardware, there's nothing tricky here except putting everything together. No cuts / no painting / no EXTREMELY complicated and creative work many of the folks here do. BUT, for me ... just putting it together and getting it to work is a treat."
    And yep, BlueAqua ... sleeving will be done. I will not be sleeving my PSU, as that's beyond me. But I can handle fans, pump leads, and the like. Just the simple stuff for me.
    Moderator
    Aug 2007
    Rube Goldberg came to play today:
    Apr 2007
    arizona
    Yah Shazza is a Mam
    thats three whips for YOU
    there's only a short list of girls in here, YOUR SUPPOSE TO KNOW THEM ALL
    jk :P
    I haven't seen you around lately!
    good to see you back
    FREEDOM ISN'T FREE
    Cruncher Support:
    Utnorris
    DarthBeavis
    DEFRANCO NATION
    _____________
    E6750@ 3.0ghz- evga 750i FTW- 320gb- Swiftech MCR220 compact- 8800gts 512mb KO- 620hx - 4gb Crucial 1066- CM 690- 6 yate loons
    E6600- Asus striker Extreme-2 x 750gb- Igloo 5710- 8800gt- antec 850w Quatro- 4gb DDR2 800- Antec 1200- 24/7 cruncher
    **Wishes for a dual- quad core cruncher **
    Banned
    Sep 2008
    Coffee mug installs to processor block and adds +10 to awesome speed granting the user the ability to overclock an extra 10%.
    Jun 2007
    Melbourne, Australia
    Well i think it looks awesome!
    Anodised black aluminium FTW
    Never go full retard
    Feb 2008
    Vegas
    glad to see you finally started another worklog shazza...best of luck on the build ahead!
    Moderator
    Aug 2007
    Thanks for the encouragement, guys. Worked all day ... got the CPU loop all hooked up and it leaked (during leak testing, fortunately). Tried compression fittings on my Apogee GTZ ... leaky, leaky, leaky. It worked fine yesterday with regular barbs, but I think I borked the threads in one of the holes. Every thing I try to screw in now goes in crooked, so can't get a good seal. I'll have another go this week.
    Got a few odds and ends on order, so gotta wait before I can do much more.
    Dec 2004
    Lovely as always. Miss your worklogs elsewhere shazza. =(
    Moderator
    Aug 2007
    A little update ... got my replacement GTZ block and everything is working - still not sure I'll use the compression fittings because I'm not sure I can get a good seal.
    But ... thought I'd share a little diversion. Some of you may remember my first adventure in water:
    This machine stayed at our house in Florida when we unexpectedly moved to Arizona in January. Back in Florida for the Holidays and decided to do an upgrade. Having a liquid cooled machine at a house I only get to every few months is not practical, so decided to stick with air until I move back here permanently.
    Some fun stuff arrived:
    Here she is, my new plain Jane setup. The X58 and i7 920 build was a breeze, especially compared to my early nightmares with my Rampage Extreme X48 board. Definitely have to fill those bays. My MM case looks so empty now!
    And, this will make you all cringe ... some of you may have never seen a stock Intel HSF installed It will be replaced, but works ok for now.
    Thanks for looking.
    Banned
    Apr 2008
    Brisbane, Australia
    D=
    What is that . . . .. thing?
    Oh now I know what hell is like. Stock Intel coolers everywhere. Make it stop, oh make it stop it hurts.
    Awesome stuff dude.
    Apr 2008
    Looking great as always shaz !
    Moderator
    Aug 2007
    Quote Originally Posted by Hulioni View Post
    You shamed me into it, Hulioni!
  18. #18
    MDPC
    Dec 2007
    Munich
    Shazza - nice blue tone on your tubing!
  19. #19
    Banned
    Oct 2008
    Dartmouth NS Canada
    Heheh nice goin Shazza! Yeah don't feel bad I am going to be using my stock hsf for the first time ever using a stocker to I might add. Oh well it'll hold us over till we get the proper gear what? Looks good though keep up with the nice build. Are you going back to water eventually or staying with air? A nice True Copper would look some sweet sitting on top of that i7 I think if you are staying air.
  20. #20
    Oct 2008
    NY
    Great build man!
    heat
    TJ07-Ultra 1200W-E8400-Rampage Formula-4870-4gb G.skill-74gb Raptor-500gb Seagate-Windows 7
    Apogee GTZ-XSPC Razor-DDC3.2 w/ XSPC top-PA120.3-MCR220-EK 250 res
  21. #21
    May 2008
    Philippines
    I really envy these MM builds. The cases are really versatile. Keep up the good work! And btw, MOAR PICS PLX
    Project RAE
    Intel Q9550 @ 3.4GHZ | Foxconn Blackops X48 | 2x1GB Team Xtreem DDR3 1600mhz | Powercolor Radeon 4870 in Crossfire | 250GB Western Digital 16MB SATA |Corsair HX1000W Modular PSU
    Watercooling:
    Dtek Fuzion V1 with Quad-Core Insert
    Swiftech MCW30
    HWLabs GTX II 360
    Feser 1/2 ID 3/4 OD UV Blue
    Swiftech MCP655
    Alphacool 10" Reservoir
  22. #22
    Banned
    Oct 2008
    Dartmouth NS Canada
    Quote Originally Posted by MomijiTMO View Post
    D=
    Awesome stuff dude.
    Quote Originally Posted by atomic ferret View Post
    Great build man!
    Shazza's a Lady fellas!
  23. #23
    Banned
    Apr 2008
    Brisbane, Australia
    I use dude and guy as universal terms .
  24. #24
    Nov 2007
    Toronto, Canada
    I like the MM Horizon sooooo much.
    RIG 1 (in progress):
    Core i7 920 @ 3GHz 1.17v (WIP) / EVGA X58 Classified 3X SLI / Crucial D9JNL 3x2GB @ 1430 7-7-7-20 1T 1.65v
    Corsair HX1000 / EVGA GTX 295 SLI / X-FI Titanium FATAL1TY Pro / Samsung SyncMaster 245b 24" / MM H2GO
    2x X25-M 80GB (RAID0) + Caviar 500 GB / Windows 7 Ultimate x64 RC1 Build 7100
    RIG 2:
    E4500 @ 3.0 / Asus P5Q / 4x1 GB DDR2-667
    CoolerMaster Extreme Power / BFG 9800 GT OC / LG 22"
    Antec Ninehundred / Onboard Sound / TRUE / Vista 32
  25. #25
    Banned
    Oct 2008
    Dartmouth NS Canada
    They are nice I agree but a U2-UFO with a Pedestal would be pretty sexy to wouldn't it? lol
