Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: i7 920 Multi Problems
    Feb 2007
    Germany
    Hi guys,
    got a few problems here with my i7 setup.
    Mobo is Asus P6T Deluxe (Bios 0804), i7 920 and 2GB corsair 1333 Ram.
    i7 is cooled by chiller so temp problems cant be
    Setup is 19x211 prime stable, but i cant prime the 20x200. Above around 170 BLCK i only got freezes in prime after few seconds at multi 20.
    I dunno which Problem that is
    More Voltag on IO or QPI doestn help. Multi 19 is all fine no Problems
    Anyone got help for me ? seems im the only one with this prob.
    Nov 2005
    Germany
    Quote Originally Posted by aNNixP View Post
    i donīt think so
    Sep 2006
    I thought the 920 was locked?
    Biostar T-Power I45 Motherboard
    P45AA918 BIOS
    E8600 450x9 1.35V
    Danger Den Water Cooled
    2x1Gig Super Talent PC6400 5-5-5-15
    EVGA 7800GS
    WD SATA 120GB
    Rosewill 750W
    Dec 2007
    the 920 IS locked. i think that the chip just cant clock that high (4GHz).
    CPU........................QX6850 @ 3.7GHz
    MOBO.....................P5E-Rampage
    Video......................GTX280 @ 670/1400/2400
    RAM........................6GB (Mushkin Redlines 2x 2GB PC2-8000 + OCZ Platinum 2x 1GB PC2-8500)
    HDD........................2x WD2500KS (RAID0), 1x WD5000AAKS, 2x WD6400AAKS, 1x HD103UJ
    Optical Drives...........1x Sony 830A + 1x Pioneer 116D
    Case.......................TJ07 BW
    PSU........................Corsair TX750
    Cooling....................Xigmatek S1283
    Monitor....................Samsung 2693 (25.5")
    Aug 2008
    Nope, it has some options. This is why we should ignore Fud. It gets stated as fact, when the things they post are in fact fiction.
    Nov 2005
    Germany
    CPU is "locked" (20 is default, 21 & 22 are turbo multipliers). The problem is that some i7-920 canīt run 20x200 (4Ghz) stable but 19x211 (also 4Ghz).
    all outta gum
    Dec 2006
    Poland
    Try turning Turbo and EIST off. Also make sure TDP limit is turned off.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Feb 2007
    Germany
    Sry Chrisch i forgot you
    Exactly that problem which Chrisch confirmed, 19x211 all fine 20x200 no go
    Quote Originally Posted by xoqolatl View Post
    All done already
    Xtreme Cruncher
    Nov 2005
    Netherlands
    My guess is the memory controller or a form of NB strap. Hows performance on 9*211 compared to people running 20*10?
    all outta gum
    Dec 2006
    Poland
    aNNixP, how do you run your uncore (NB speed in CPU-Z Memory tab)?
    All three CPUs I tested have had problems running core in sync with cache at above 3600MHz. Try lowering your uncore multi or increasing core multi by one step. I tried to test performance of sync vs async and it seems to make no difference. Fast uncore is very good for Pi and Wprime, +133MHz on cache gives you more than +133 on core.
    www.teampclab.pl
    Test bench: empty
    Nov 2005
    Germany
    @ xoqolatl
    i tried all, lowest Uncore + lowest memory multiplier. But it doesnīt help! I can prime 19x200 over 3 hours, but if i set the multi from 19 to 20 and
    raise the vcore it isnīt stable. If i lower se multiplier to 19 and raise the BCLK to 211Mhz is it stable
    I can also bench 19x218 but not 20x212
    all outta gum
    Dec 2006
    Poland
    PLL voltage then? My 920 needed 2.0V PLL, 1.5V core, 1.475 vtt to be stable at 4000 core, 3800 uncore.
    www.teampclab.pl
    Test bench: empty
    Nov 2005
    Germany
    My 920 need 1.8v PLL, 1.36v VCore and 1.24v VTT(QPI) for stable 4Ghz Core and 3.16Ghz Uncore.
    But this is with 19 multiplier and 211Mhz BCLK. Only the 20 multiplier doesnīt work
    and i donīt think that the CPU need more VCore, PLL & QPI voltage with lower BCLK / Uncore / QPI clock.
    for example:
    4Ghz: 19x211 / 3.8Ghz QPI (multiplier 18) / 3.16Ghz Uncore (multiplier 15) / 633Mhz Mem (multiplier 3/6) / 1.4125v VCore (Bios) / 1.24v QPI/VTT (Bios) / 1.60v vDimm (Bios) / 1.80v PLL (Bios) <- primestable
    4Ghz: 20x200 / 3.6Ghz QPI (multiplier 18) / 3.00Ghz Uncore (multiplier 15) / 600Mhz Mem (multiplier 3/6) / 1.4125v VCore (Bios) / 1.24v QPI/VTT (Bios) / 1.60v vDimm (Bios) / 1.80v PLL (Bios) <- not stable (restart after 15sek)
    Nov 2007
    Toronto, Canada
    Probably still needs a lot of bios maturity as well.
    RIG 1 (in progress):
    Core i7 920 @ 3GHz 1.17v (WIP) / EVGA X58 Classified 3X SLI / Crucial D9JNL 3x2GB @ 1430 7-7-7-20 1T 1.65v
    Corsair HX1000 / EVGA GTX 295 SLI / X-FI Titanium FATAL1TY Pro / Samsung SyncMaster 245b 24" / MM H2GO
    2x X25-M 80GB (RAID0) + Caviar 500 GB / Windows 7 Ultimate x64 RC1 Build 7100
    RIG 2:
    E4500 @ 3.0 / Asus P5Q / 4x1 GB DDR2-667
    CoolerMaster Extreme Power / BFG 9800 GT OC / LG 22"
    Antec Ninehundred / Onboard Sound / TRUE / Vista 32
    May 2008
    Land of Koalas and Wombats
    Quote Originally Posted by Chri$ch View Post
    for example:
    higher multi always needs more vcc, its the nature of squeezing more clock phases into the same cycle.
    you raise the bclk and lower the multi you are reducing phases and decreasing the clock period by adding more frequency on each multipliers phase.
    the opposite happens when you raise multi, decrease base clock. clock period on each phase increases, as does amount of clock phases. more phases requires more voltage and steadier supply. the cpu itself might not be able to throughput valid data with the heavier load of increasing the multi with such high base clock.
    its much like we're used to with fsb. you can run a low multiplier, high fsb and need less voltage and encounter less difficulty than with a higher multi and lower fsb producing same out put frequency. all to do with phases and alignment.
    you can always whack Vcpu_pll up and see if its enough to lock the phases in alignment with each other.
    Vcpu_pll and Vcc would be in my humble opinion the way to start looking for answers.
    DFI LT-X48-T2R UT CDC24 Bios | Q9550 E0 | G.Skill DDR2-1066 PK 2x2GB |
    Geforce GTX 280 729/1566/2698 | Corsair HX1000 | Stacker 832 | Dell 3008WFP
    Apr 2007
    Anyone else not a fan how Intel took AMDs locking route here. Are we going to see like "Blue editions" come out?
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
    Nov 2002
    Houston
    for example:
    24/7 stable at 21x191 here (20x191 POST with turbo enabled), you need to raise VQPI, it needs to be kept within .0250~.0375V of VCore depending on VCore gates, try VCore at 1.3975V to start with VQPI at 1.375V, PLL works best on Auto right now on the ASUS board. Also, blck over 200 is a problem in the BIOS you have at 20x multi on POST.
  18. #18
    Feb 2007
    Germany
    Ok ill try it later thx. But i dont think that it will help.
    I testet already all since the last 3 nights.
  19. #19
    Xtreme Guru
    Aug 2005
    Burbank, CA
    20x200 is not stable for me, my chip is a good chip, runs 3.2ghz with only 1.08v, so i know 4ghz should not be a problem.
  20. #20
    Nov 2005
    Germany
    try 19x211
  21. #21
    Feb 2007
    Dallas, TX
    Similar story, 19 x 200 is fine but 20 x 200 is no go (920 + P6T Deluxe). 20 x 195 works at low vcore (1.35 bios) so I feel sure 4 ghz is within reach. I haven't tried 19 x 211 yet but will do that tonight, thanks for the tip guys!
    2600K | Maximus IV Formula | 12G Corsair 1600 C8 | 2x 6950 | Coolermaster Scout
  22. #22
    Feb 2007
    Germany
    Seems that im not the only one with the Multi Problem
    Any Solutions yet ?
  23. #23
    Xtreme Guru
    Aug 2005
    Burbank, CA
    Any Solutions yet ?
    I got the problem as well, if anyone has a solution please post, used bios 0903 as well, no help tho, my cpu is stable at 3.8ghz with 1.25v, so im sure 4ghz is attainable.
  24. #24
    Feb 2007
    Dallas, TX
    With 0903 bios I can run stable at 4 ghz in Turbo mode (21 x 191), but still not 20 x 200.
  25. #25
    May 2008
    Vancouver, BC, Canada
    Well, I'm gonna resurrect the dead here but I want to know if this is only occuring on Asus boards? It sure as heck sounds like it is, which would be indicative of either a propagating BIOS fault or a motherboard engineering fault...
    Any ideas?
