Results 1 to 17 of 17
Thread: Guide: How to Insulate your mobo for TEC Cooling
Threaded View
    Mar 2008
    Talking Guide: How to Insulate your mobo for TEC Cooling
    Tec insulating Guide
    By omaryunus
    Well as most of you know been working hard on my comp for the past few weeks and well Ive been insulating my board along the way… so I decided I would make a little guide out of it since there really isn’t a recent one around and I want more ppl to get into this and see how easy this is This is more of a follow the pics of what I did more than this is what you have to do and blah blah :p
    Well here goes:
    First a list of things you need to insulate your mobo:
    1) NEOPRENE!! (LOATS OF IT) just in case
    2) Conformal Coating
    3) Dielectric Grease
    4) Silicone rubber Adhesive
    5) Liquid Electric Tape
    First for any good TEC block or setup you need a good… back plate
    EK makes a nice one and it works perfectly
    cut out a piece of neoprene to go along the back of the mobo so no air comes in there
    Screws in and good to go
    This is how it looks now
    Enough with the backplate moving on to the back of the board
    wipe the back of the board clean
    now with the Conformal coating (if you have a tube this is how it will go)
    here is a pic from ira-k(on OCN) which shows the conformal zone on the back of the mobo so this should help:
    a nice thick layer of conformal coating in the conformal zone (shown above)
    another view just to show you from a diff angle
    and now to the front:
    use the silicone rubber adhesive
    heres how it starts
    and done
    Diff views
    view from the top
    and now use the Dow conformal again on the front
    here is another pic from ira-k (on OCN) which shows you the Conformal zone
    heres how it should look put it on nice and thick
    Closer looks:
    and well one thing which the EK backplate is not good for is keeping the neoprene down in the back so you can use some of the electric liquid tape
    lifted up we need to bring it down
    and down
    good pic
    now to the neoprene layers :d
    second layer on and test fitted
    ready to install the CPU
    continued on next post...
