With the launch of the new I7 cpu's slated for Nov.17th has anyone seen any aftermarket coolers set to come out any time soon?
OS - Windows 7 PRO 64 bit
Mobo- Asus P6X58D Premium
CPU - Intel Core I7 980 with Noctua NH-U12P
Memory - Corsair PC12800 1600 12 gigs
Gpu - Evga GTX 670 , 2 Sata DVD burners
Primary HD -1 (256 gb ) Ocz SSD sata 3
2nd HD - WD 1 tb 7200rpm sata 2
3rd HD - Seagate 1T 32mb Sata 2
Antec 1200 w/ Corsair 750watt psu
Samsung P2770 HD, Logitech Z5500 speakers
True
FREEDOM ISN'T FREE
Cruncher Support:
Utnorris
DarthBeavis
DEFRANCO NATION
_____________
E6750@ 3.0ghz- evga 750i FTW- 320gb- Swiftech MCR220 compact- 8800gts 512mb KO- 620hx - 4gb Crucial 1066- CM 690- 6 yate loons
E6600- Asus striker Extreme-2 x 750gb- Igloo 5710- 8800gt- antec 850w Quatro- 4gb DDR2 800- Antec 1200- 24/7 cruncher
**Wishes for a dual- quad core cruncher**
The TRUE is ready to go and Noctua is making brackets for their existing coolers that will fit the 1366 sockets
What about Zalman 9700nt? That's an awesome cooler and I want it to 1366 socket..
Corsair Obsidian 650D - EVGA P67 FTW - Samsung F3 1Tb - 8Gb A-Data cheapest crap DDR3 - Intel Core i5 2500K w/ Corsair H50 - EVGA GTX 295 co-op - Corsair AX650
The Thermalright Ultra 120 Extreme (TRUE) is NOT currently compatible, they do not ship with the bracket required (even the new copper version does not) and the bracket is not for sale anywhere as of this writing.
The only aftermarket HSFs available right this moment are the Dynatron which is a horizontal unit that doesn't look much better than the stock cooler, and the Nexus FLC-3000 which I just received. The FLC-3000 looks marginally better than the stock Intel cooler but it's a serious pain in the ass to mount, and it does not include a backing plate for LGA1366 so it may distort the motherboard. There are LGA1366 backing plates available but they won't work with the FLC-3000.
Ironically, there IS a good water cooling block available for LGA1366 from Danger Den. Odd that water cooling should actually be out ahead of air cooling for once.
Presumably we will see more HSFs on Monday. Honestly I'm very displeased at the slow reaction by the various vendors, particularly Thermalright and Zalman. With the LGA775 launch, Zalman had mounting clips in stores well before motherboards were available.
Aha, Sidewindercomputers just got the Thermalright brackets in. Knew that was coming but didn't want to say until I got my order in, supply is short![]()
get the foxconn blood rage it uses 1366 and 775 mountings
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Gaming Rig
Intel E6300
Intel Mobo
2 Gig OCZ 800 (800 5,5,5,15)
Saphire Ati 4870
22inch LG Flatron W2230S
Thanks for the information . I guess I'll wait and see what comes out over the next few days. I 'm not much on water cooling , I've often wanted to try it but you might say I'm kinda scared that I'll screw up some expensive hardware not knowing how to install a water cooling system.
http://www.newegg.com/Product/Produc...82E16835114080
some never heard cooler![]()
Zalman is releasing the CNPS9900 for socket 1366 soon
"The New Zalman CNPS9900 LED heatsink is finally available. Zalman are back with a quiet 782gram all copper heatsink. The CNPS9900 contains 6 heatpipes, one 120mm illuminated fan that spins at 1000-2000RPM, and is compatible with socket 775/1366 and AM2+/939. "
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
It would be nice if Zalman released a new mounting bracket and backplate for the 9700NT. Don't need a long term solution and don't want to buy a new cooler for temporary use. Something better than stock air cooling would be appreciated.
Intel Xeon 3520 | eVGA Classified E759, GTX-285 SSC Tri-SLI | Corsair Dominator GT 2000Mhz 7-8-7-20 | Auzentech X-Fi Prelude | Intel 160GB X25-MG2 x 2, WDC 1TB Green Storage | Watercool HK 3.0, GPU-X² GTX285, MO-RA 2 Pro | Mips Chipset Kühler | Dual Laing 18w DDC+ | Corsair HX1000 | murderMod TJ07 #007 | Dell 3008WFP | Windows 7 Ultimate x64 |
Will the below work with my Ultra Extreme I already own on 1366 or must I use the kit from Thermalright?
http://www.sidewindercomputers.com/lga13sobbowi.html
It's out of stock everywhere I try to get it.
no i will not if you read exactly what it is, it's a replacement for stock cooler stuff :
This kit should be a direct replacement for the stock 1366 Intel CPU Cooler pushpin setup.
I found the Cooler Master V8 at Buy.com. Yesterday it was $59.99 plus shipping. Now its up to $63.XX plus shipping.
The Noctua NH-U12P (made in Austria) is supposed to be crazy quiet and cools almost even to the TRUE and better than 99% of other coolers. I got one and then ordered the 1366 bracket kit seperately.
Any reasonably priced LGA 1366-compatible coolers?
Not looking to spend $70 on an air cooler, especially when I already have a perfectly good xigmatek S1283 right here, just unfortunate that it is not compatible.
I can get a TRUE for $40-50 but then there is the 1366 mounting brackets that are nowhere to be found.
Intel Core i7 920 @ 3.8GHz - Asus P6T Deluxe X58 - 6GB (2GBx3) G. SKILL DDR3-1600 @ 8-8-8-20 - 2 x EVGA GTX 280 1GB SLI - Corsair TX750 PSU - Windows Vista HP 64-bit
True, Thermalright doesn't have this bolt-thru-kit on Newegg at the time of my posting, and its already a hot seller on Scan.
[[Daily R!G]]
Core i7 920 D0 @ 4.0GHz w/ 1.325 vcore.
Rampage II Gene||CM HAF 932||HX850||MSI GTX 660ti PE OC||Corsair H50||G.Skill Phoenix 3 240GB||G.Skill NQ 6x2GB||Samsung 2333SW
flickr
Looks decent but it doesn't seem to be any cheaper than the Ultra 120 EX anyway.
I broke down and bought the Ultra 120 EX 1366 from ncix, came out to $81 shipped.....can't believe I spent that much on an air cooler, but there isn't much choice I suppose. The Coolermaster V8 is available for $70 shipped at Directron, but it is not clear whether or not it has the LGA 1366 brackets in the box.
