Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Thread: i7 920+P6T DLX @ 4.2Ghz On-Air
    Oct 2008
    THAILAND
    Red face i7 920+P6T DLX @ 4.2Ghz On-Air
    INTEL Core i7 920 + ASUS P6T DLX @ 4.2Ghz On-Air Benchmark Results [ Turbo Mode ON ]
    System Test
    Intel Core i7 920 ES (20x200Mhz Bios set) + Turbo Mode ON, multiple @ 20~21 / CPU Speed 4.0Ghz - 4.2Ghz
    bios Set Vcore 1.52V , QPI/DRAM auto, PLL auto.
    CPU Cooling : TR Ultra 120 EX + Fan 3200rpm.
    MOBO ASUS P6T DLX BIOS 0310
    MEM G.Skill DDR3 F3-12800CL7D-2GB HZ x 3 @ 800mhz CL 7-7-7-18 1T Vdimm 1.9V
    VGA ASUS HD4870 TOP CF mode Core/mem @ 860/1050Mhz
    WD VelociRaptor 300GB
    PSU SilverStone OP 1000 Watt
    Results
    Super Pi 1MB & 32MB 1 Thread
    Super Pi 1MB & 32MB Multi thread
    Super Pi 32MB. Detail 8 Thread
    PCMark 05
    Everest Memory Bandwidth : Read
    CPUMark & Fritz Chess Bench
    WinRAR Bench
    Cinebench 9.5
    Cinebench R10
    Aquamark3D
    3DMark 2001SE
    3DMark 03
    3DMark 05
    3DMark 06
    Sory my ENG is bad .
    [SIGPIC][/SIGPIC]
    Nov 2007
    Toronto, Canada
    Good too see. How about some temps there chief?
    GB 790XTA UD4
    GSkill Pi Black 2000 Cas9
    ASUS 4870
    Enermax Revolution 1050+
    http://www.heatware.com/eval.php?id=67661
    May 2007
    Urbana-Champaign
    Yikes. Very nice OC.
    I think 4.2GHz for every day computing on water sounds doable.
    Oct 2008
    THAILAND
    Max Overclocking my 920 On-Air TR Ultra-120 EX
    CPUZ Valid http://valid.x86-secret.com/show_oc.php?id=436626
    Max super Pi 1MB
    Max run AM3
    [SIGPIC][/SIGPIC]
    Nov 2005
    The 130 watts limit does not seem to be troublesome
    Very nice results...
    Intel e8500@4000MHz@1.36v|OCZ Vanquisher|Asus P5e3ws Professional|2*1024 OCZ PC12800 D9GTR@1600MHz@7/6/6/x@1.92v|Point of View 8800GTS 512MB@730/1825/2000MHz|Stock Cooling|Seagate 500GB 7200.12|Enermax 460w|Creative Sound Blaster Audigy 4
    Administrator and Editor of Uranium Backup Blog
    Administrator and Editor of Hymn to Future
    Nov 2006
    Just wondering about the Vdimm. I was reading that > 1.6 Vdimm will result in CPU Damage due to the on die memory controller. Has this been debunked? I've got some 1600C7 (2 X 2048) @ 1.9v. If i7 does not have this limitation then I will wait for it, but if the limitation is applicable, then I will just stick with Core2 for now.
    Asus Rampage Extreme (1202 Q743A798)
    E8500 @ 4.2GHz 3837B215 @ 1.360v
    G.Skill 2000Mhz RipJaws 8GB DDR3 @ 1830 MHz 9 - 8 - 8 - 20 2T with 1.70v
    EVGA GTX 260 @ 725/1450/2250
    2 X WD Green 1TB (RAID 0) Intel Matrix
    4 X Seagate 1TB (RAID 5) 3ware 9500S-4LP
    LG GGC-H20L Blue-Ray Dual Layer
    Corsair 620HX
    Thermalright Kandalf
    Auzentech X-Fi Forte
    Samsung 275TPlus (Digital) and Viewsonic N3250w
    Champion
    May 2006
    Bangkok, Thailand
    Great job dude
    Welcome to Xtremesystems m8
    Sorry For My English
    OverclockZone Team
    THAILAND
    Jul 2007
    ARIZONA
    I7 looking good even the 920 looks like it worth the trouble
    thanks for the results !!
    [SIGPIC][/SIGPIC]
    PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
    FOXCONN MARS
    COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
    BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
    OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
    Quattro 1000W
    Radeon 2-4850's in crossfire
    OCZ Vertex SSD thanks Tony!
    ALL PIPED INTO HOUSE AIRCOND ;}
    *QUANTUM FORCE* saaya & sham rocks !
    *REAL TEMP*
    At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
    *MEMSET* Felix rocks !
    *SUPER TEC MAN* UncleJimbo rocks !
    OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
    Xtremely Addicted
    Dec 2004
    NL
    Welcome, nice tests, thanks for sharing
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    HAHAH thats one EVIL 920
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    /dev/zero
    Nov 2002
    Germany, Berlin
    Great CPU it seems.
    Very detailed testing, too. Keep up the good work, mate.
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
    Jul 2007
    Sofia, Bulgaria
    Great job mate. What is max stable frequency ?
    24/7 Asrock P67 Extreme4|2500K @ 4600 @ 1.38v|2x2GB A-data value|XpertVision 8500GT 600/450|WD 6400AAKS|CM 690 + 3 x 140mm + 2 x 120mm|Zalman CPNS-10X Performa|Chieftec 750-14C|Zalman MFC1 Plus
    Jan 2004
    North America
    Nice results, looks like the 920 clocks rather well.
    Xtreme Legend
    Mar 2005
    Australia
    nice man
    does your multi drop to 20x when running 8xinstances of SuperPi or maybe 3DMARK06?
    Team.AU
    Got tube?
    GIGABYTE Australia
    Brotherhood
    Apr 2005
    Land Of KADISOKA
    Cool man keep pushing.....nice work on turbo V mode...
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Xtreme X.I.P.
    Aug 2004
    Chile
    you get more performance than a QX9770 (USD1400) with a USD 300 CPU this is really amazing.
    Jun 2008
    So there is no over clock lock? Awesome.
    Cause i was just reading a Toms hardware article that says "all standard models are equipped with an overclocking lock."
  18. #18
    Oct 2008
    THAILAND
    Red face
    Quote Originally Posted by dinos22 View Post
    nice man
    Yes. the multiple Drop to 20 when running multi-thread.
    And i have Benchmark 920 20x200 with out turbo mode resualts for sharing.
    System Test
    Intel Core i7 920 ES (20x200Mhz Bios set) @ 4.0Ghz
    bios Set Vcore 1.45V , QPI/DRAM auto, PLL auto.
    MEM G.Skill DDR3 F3-12800CL7D-2GB HZ x 3 @ 800mhz CL 8-8-8-24 1T Vdimm 1.6V
    Results
    PCMark 05
    WinRAR Bench
    Cinebench 9.5
    Cinebench R10
    Aquamark3D
    3DMark 2001SE
    3DMark 03
    3DMark 05
    3DMark 06
    [SIGPIC][/SIGPIC]
  19. #19
    Banned
    Feb 2008
    Buffalo, NY
    very nice testing! thank you for sharing, 32M is so nice with these i7
  20. #20
    Jun 2006
    good old Germany
    nice scores! but why do you disables CrossFire when you put two cards to your system ?
  21. #21
    Oct 2008
    THAILAND
    Red face
    Quote Originally Posted by Kabauterman View Post
    I test in CF Mode but GPU-Z 0.2.8 check disable CF.
    For PCMark05 I test VGA single card mode.
    [SIGPIC][/SIGPIC]
  22. #22
    Oct 2008
    THAILAND
    Quote Originally Posted by ReverendMaynard View Post
    @ 4.0Ghz - 4.2Ghz Vcore 1.45V - 1.52V CPU Idle ~45c & run Pi 32mb 8 thread full load @ 80c - 98c.
    Sometime I see temp @ 100c check for coretemp 0.99.3
    [SIGPIC][/SIGPIC]
  23. #23
    Jun 2008
    Ok, so the chips aren't overclock locked?
  24. #24
    Jun 2006
    good old Germany
    Quote Originally Posted by StrangerS View Post
    are you sure?
    I think you 05 score is to low for CF enabled
  25. #25
    Oct 2007
    Budapest,Hungary
    5300+kb/sec winrar
    thats a hell of bandwith
    I7 920 D0 5362 1.627v
    980X retail 3003A258 - 6683mhz 1.85v
    ASUS R3X 265bclk
    ASUS R3BE 266bclk
    ________________________
    _______________
    Xtreme 3D Team Hungary
