NDA is upHere are some Tri-Channel results with A-DATAs mainstream line memory!
Test system specification
Intel Core i7 965 Extreme Edition
ASUS Rampage II Extreme
8500GT 512MB
Silverstone Olympia 1200W
Manufacturer specification
* DDR3-1600+ & 1333+ 3GB/6GB tri-channel module kits are tested at 1600MHz/1333MHz
* Test in tri-channel configuration at latency settings 8-8-8-24 2T for DDR3-1600+ and 7-7-7-20 2T for DDR3-1333+ at 1.65V-1.75V
* SPD (Serial Presence Detect) programmed at JEDEC standard for basic system booting
* All memory chips are verified using overclocking criteria for better quality
* High quality 6 layers PCB (Printed Circuit Board)
* Optimized for 64-bit OS (operating system)
* Backward compatible with DDR3-1333, 1066
* Lifetime limited warranty
The rams and packaging
A-DATA 1600+ Tri-channel
Results
CPU-Z reads CAS-latency a bit wrong so look at the report from Everest when it comes to that.
7-7-7-20-1T 1.95V
7-7-7-20-1T 2.1V
8-7-7-20-1T 2.0V
8-7-7-20-1T 2.05V
I was quite amazed with these rams as they are the meainstream series and clocks high enough to match most high end kits out there. More results will follow!
A-DATA Product Page
