Results 1 to 21 of 21
Thread: True + LianLi PCV2000
    Jan 2008
    Sao Paulo - Brazil
    HiHo
    Guys True is 100% compatible with Lian Li PCV2000?
    Cuz i bought a IFX14 and i cant install on the case because of deep
    thank you so much!
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    Lian Li V2000A Modded
    Jan 2008
    From the dimensions on thermalrights website i dont think it will fit...
    IFX-14 = Length 146.2 x Width 124 x Height 161 mm
    TRUE = Length 63.44 x Width 132 x Height 160.5 mm
    as you can see from that the TRUE is only 0.5mm shorter than the IFX
    Mobo: Foxconn Bloodrage v1.0
    CPU: Core i7 920 (stock) + TRUE Black
    RAM: G.Skill NQ 3x1GB DDR3 1600MHz
    Graphics: EVGA e-GeForce GTX 260 Core 216 SSC
    PSU: Corsair HX620
    Case: Antec 900
    Storage: Hitachi Deskstar (320GB), Samsung Spinpoint F1 (1TB)
    Optical Drive: Samsung SH-S223Q
    Sound: Sonar X-FI Audio
    Speakers: Logitech x230 2.1
    Screen: Samsung SyncMaster 226cw
    May 2006
    UK
    brai, why exactly can you not fit it, tried rotating 90 degrees?
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    Jan 2008
    Sao Paulo - Brazil
    Quote Originally Posted by Goreg View Post
    See Length 14cm true was 6.3cn
    Quote Originally Posted by LuckyNV View Post
    My mobo is 780i have nb cooler ;x
    if anyone can show me a true in lianli pcv2000,i will be very smart
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    May 2004
    No pics Im afriad, but I am currently happily using a TRUE with dual 120mm fans in an original v1 lian li v2000 - fits perfectly, doesnt touch the side panel at all.
    Nov 2007
    My old setup. I assume the IFX has a problem hitting that divider?
    Jan 2008
    Sao Paulo - Brazil
    yes it touch on painel ;x
    i need sell this ;x
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    Nov 2007
    One gripe I have w/ the v2000. Its a huge case but, the motherboard area could borrow alittle more room from the psu and hd compartment
    Aug 2007
    Kent, Washington
    When I replaced my Asus Commando with my DFI LP UT P35, I had to rotate my TRUE because the CPU socket is closer to the divider plate on the DFI.
    Jan 2008
    Sao Paulo - Brazil
    maybe i need rotate my TRUE cuz evGA 780i socket is closer?
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    Aug 2008
    I have the TRUE in my V2000, it fits just fine.
    Xtreme Mentor
    Feb 2007
    Oxford, England
    I have TRUE in my Black pearl (rebranded PCV2000) its fine worried a lil as it was very tight with the bottom
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Jan 2008
    Sao Paulo - Brazil
    can you attach a picture to see me?
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    Aug 2008
    There. Click to enlarge.
    Nov 2008
    Kansas City
    I think I saw in the V2000 thread someone put some of that sound buffering material in between the heatsink and the midplate.
    Specifically here: http://www.xtremesystems.org/forums/...=154982&page=3 about halfway down. That's a v1000 though; it might work for you.
    Jan 2008
    Sao Paulo - Brazil
    thanks DeathTyrant and archieb.. ill try cuz my mobo is 780i eVGA maybe socket is closer.. but i need see
    thanks very much all
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
    Nov 2008
    Atlanta GA
    Socket is closer to the top. My 780i, V1000, TRUE only fit like this:
  18. #18
    Jan 2008
    Sao Paulo - Brazil
    Dimensions of the pcv2000 and v1000 are the same? like mobo tray to divisor ?
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
  19. #19
    Dec 2008
    Quote Originally Posted by ATLPIMP View Post
    Bingo! That's the deal breaker right there. That is the only way it will work.
    Main Machine - ASUS CROSSHAIR Athlon 64 X2 6400+ - Liquid Cooled
    Home Theatre PC - ASUS A8N32-SLI Opteron 180
    Workstation (Audio/Video/CAD) - Tyan K7X Thunder S2468UGN MP-2800 Barton x 2
    A/V Mastering & Replication - ASUS A8N-SLI Opteron 165
    Print/File Server - ASUS A7V880 XP-3200 Barton
  20. #20
    Jan 2008
    Sao Paulo - Brazil
    no problem ;D
    Intel E8400
    XFX 9800GTX+ XXX
    Crucial Tracer 1066
    Antec 850w Modular
  21. #21
    Aug 2008
    My TRUE fitted just fine in my old V2000. It was orientated this way: ||
    rather than this way: =
Tags for this Thread
