Hi,
My bad experience with Gainward HD 4870 's stock cooler convinced me to go for a full waterblock for my graphic card, so here is the mini-review for the XSPC Razor 4870. It's my first contribution here as well as my first VGA waterblock, so this review will of course not even come close to what Martin does (http://www.martinsliquidlab.com)
Reference design HD4870 1024 Mb with the waterblock
Teh waterblock
Contact surface : zones in contact with GPU and MEM are flawless, but there are some markings elsewhere
Teh Maze, hope you like this pic
Maze close-up
Here's what the top looks like inside
Block equipped with 2 Bitspower Hi-Flow fittings, 13/19
This is what you see when you remove the stock rad, notice how messy does the thermal paste looks on the GPU ...
A few minutes later with Tuniq TX2 and a razor blade
Here we are !
Time for some temps now![]()
A few words on my setup :
- D'Tek Fuzion V2
- E8400 @ 4 GHz (500*8)
- Connect 3D HD4870 1024 Mb
- XSPC Razor 4870
- 13/19 Primochill primoflex UV Blue tubing
- 13/19 Bitspower Highflow fittings (two of them are 45 degrees)
- Swiftech MCR320-QP-K
- 3 Yate Loon D12SL-12
- Swiftech MCP355 12 VDC Pump with XSPC Laing DDC Top
- Bitspower Water Tank Z ULTRA - POM Version
Please keep in mind that i have only one loop (I know i should have one for the CPU and one for the GPU) and that the GPU gets coolant after the CPU.
The only drawback of this waterblock is the VDDC slave cooling since liquid doesn't flow above, resulting in temps that are really higher than GPU and MEM.
Advices and comments are, i hope you had a pleasant time reading this !
